when the Darkness fell upon us
when the Evil Ones came!
Creatures from the darkest pits of hell they were.
Trinsec's Journal
Trinsec's Journal
Zo ziet XP er bij mij ook altijd uit als het net geïnstalleerd is.
Volgens mij verdwijnt het zodra je de extenties van zip en rar etc. aan winrar toewijst.
edit: te laat...
[ Voor 7% gewijzigd door zetje01 op 11-08-2003 21:14 ]
Trinsec's Journal
Bron: http://www.tech-forums.net/computer/topic/3168.html# Disable XP's built-in Zip Support
With Windows XP, Microsoft have given us a built-in Zip
feature. This new XP feature however just tends to get in the way
and is no where near as feature laden as WinZip. So the good news is that you can disable the Windows XP built-in Zip support! (and enable it again if you ever want to.)
To Disable:
1) Start Menu > Run
2) Type:
regsvr32 /u %windir%\system32\zipfldr.dll
To Enable It Latter:
1) Start Menu > Run
2) Type:
regsvr32 %windir%\system32\zipfldr.dll
[ Voor 68% gewijzigd door jpiscaer op 11-08-2003 21:17 ]
Trinsec's Journal
Trinsec's Journal
You can disable the XP zip folder capability by executing:
regsvr32 /u zipfldr.dll
You can re-enable it by running:
regsvr32 zipfldr.dll
If this fails you may have to try sfc/scannow or the repair console From the XP cd
boot.
Trinsec's Journal
