MSI K7N2 GL ervaringen?
  • 47 views sinds 30-01-2008
Ik wou men pc upgraden, en ik had de volgende onderdelen uigezocht :
MSI K7N2 GL
Amd Athlon 2600+
2 x 512 MB DDR 333
Nu boeit dat niet zo, ik wil gewoon weten of dit een lekker mobo'tje is, en of er mensen zijn hier die er ervaring mee hebben, ook eventueel met overclocken ed
Hier ff de specs :
Afbeeldingslocatie: http://www.choicedirect.com/Merchant2/graphics/00000001/K7N2GL-200.jpg
Description: Supports Socket A for AMD Athlon/Athlon XP/Duron processors @FSB 100/133/166, Supports 600MHz up to Athlon XP 2700+ processor or higher, nVIDIA nForce2 IGP Chipset, integrated TV encoder.
Specifications:
MODEL- K7N2-GL VENDOR- MSI COMPUTER CORP.
FEATURES- ATX nVIDIA AMD Motherboard
High Performance nForce Gaming Platform with Powerful GeForce4 MX
Graphics.
nForce2 IGP + nForce2 MCP
266/333 MHz FSB, Socket A, AMD Athlon/Athlon XP 3000+ or up.
Ultra DMA 100/133, 3 PC266/333/400 DDR up to 3GB, Support Dual
Channel DDR.
ATX Form Factor, 5 PCI, 1 ACR, AGP 4x/8x, Onboard VGA, TV-Out, 6 USB
2.0.
Ethernet 10/100 LAN, 6 Channel Audio
Live Update2, Fuzzy Logic4, i-Speeder, D-Bracket2
* AGP 8X - AGP 3.0 graphics standard, also backwards compatible with
AGP 2.0. 2.1 GB/s (data Transfer Rate) at 1.5 voltage.
* Fuzzy Logic 4
- The most complete overclocking utility based on Windows OS.
- System information auto detect.
- Optimized CPU automatically or manually.
- The 4th generation new feature: adjustable AGP ration and Vcore
* Live Update 2
- The ultimate combo of MSI exclusive Live BIOS, Live Driver, Live VGA
BIOS, Live VGA Driver, Live Utility and the brand new Live Monitor.
- Online update BIOS/Driver/Utility.
- Live Monitor auto-detects and suggests the latest BIOS/Driver/
Utilities information.
* i Speeder
- Monitor internet conncection status
- Optimizes cable modem/xDSL speed
- Online synchronize system time
CPU - Supports Socket A for AMD Athlon/Athlon XP/Duron processors
@ Front Side Bus 100/133/166
Supports 600MHz up to Athlon XP 2700+ processor or higher.
100/133/166 (200/266/333) MHz clocks are supported.
BIOS - The mainboard BIOS provides "Plug & Play" BIOS which detects
the peripheral devices and expansion cards of the board
automatically.
The mainboard provides a Desktop Management Interface (DMI)
function which records your mainboard specifications.
CHIPSET - nVIDIA nForce2 IGP Chipset
- Integrated TV encoder
- Supports DDR266/333 with internal graphic core,
DDR266/333/400 with external add-on card
- AGP 3.0 8x interface at 533MHz
nVIDIA nForce2 MCP Chipset
- AC97 Interface supporting up to two concurrent codecs
- Ultra ATA133 for the fastest hard disk throughput
- USB 2.0 EHCI/1.1 OHCI controller
MEMORY - 0 MB on board, Supports six memory banks using three 184-pin DDR
DIMMs for up to 3GB PC3200/2700/2100/1600 DDR SDRAMs.
Supports both 64-bit and 128-bit DDR SDRAM
SLOTS - (5) Five 32-bit PCI bus slots (support 3.3v/5v PCI bus
interface).
(1) AGP (Accelerated Graphics Port) 1.5V 4X/8X slot
(1) ACR (Advanced Communication Riser) slot
AUDIO - Realtek ALC650 6-channel audio
VIDEO - Integrated nVIDIA nForce2 IGP Chipset
Integrated TV-out encoder, through external bracket
LAN - Chipset integrated 10/100 Base-T Ethernet/Fast Ethernet.
PCI IDE - An IDE controller on the MCP2 chipset provides IDE HDD/CDROM
with PIO, Bus Master and Ultra DMA133/100/66 operation modes.
Can connect up to four IDE devices.
I/O PORTS- (1) One floppy port that supports two FDD with 360KB, 720KB,
1.44MB and 2.88MB.
(1) RS-232 Serial port
(1) 15-pin VGA port
(1) Parallel port supports SPP/EPP/ECP mode
(3) audio ports in vertical
(6) USB 2.0/1.1 ports (Rear x 4/Front x 2)
(1) RJ-45 port
(1) RCA Composite TV-out port
PCB SIZE - ATX form factor, 30.5cm x 23.0cm, 6 mounting holes
Oja, gaat deze combo wel goed werken? maw, is dit een goed systeem?
De rest van de onderdelen komen gewoon uit mijn oude bak ( GF4Ti4400, WD 30 GB, SG 80 GB, Plex 24x10x40,... )
  • dion_b
dion_b
say Baah
Volgens mij kan dit prima in deze topic:
[rml][ Ervaringen] MSI K7N2 op 166MHz+ FSB[/rml]
(vooral omwille van je CPU/mobo combo)
/dubbel - dicht
Oslik blyat! Oslik!
