mrtg geeft foutmeldingen
  • 55 views sinds 30-01-2008
Ik heb 2 weken geleden mijn server geinstalled met Linux Redhat 9 en nu wou ik met mrtg mijjn status van mijn Accesspoints uitlezen maar nu zegt MRTG doe het zelf maar weet iemand hoe ik dit probleem kan oplossen.
dit met de commando: mrtg
Malformed UTF-8 character (unexpected continuation byte 0xa4, with no preceding start byte) at /usr/bin/../lib/mrtg2/locales_mrtg.pm line 248.
Malformed UTF-8 character (unexpected non-continuation byte 0xc6, 1 byte after start byte 0xe5, expected 3 bytes) at /usr/bin/../lib/mrtg2/locales_mrtg.pm line 248.
Malformed UTF-8 character (unexpected continuation byte 0xa7, with no preceding start byte) at /usr/bin/../lib/mrtg2/locales_mrtg.pm line 248.
Malformed UTF-8 character (unexpected continuation byte 0xaa, with no preceding start byte) at /usr/bin/../lib/mrtg2/locales_mrtg.pm line 248.
Malformed UTF-8 character (unexpected non-continuation byte 0x0a, immediately after start byte 0xcc) at /usr/bin/../lib/mrtg2/locales_mrtg.pm line 248.
Malformed UTF-8 character (unexpected non-continuation byte 0xee, immediately after start byte 0xcb) at /usr/bin/../lib/mrtg2/locales_mrtg.pm line 267.
Malformed UTF-8 character (unexpected non-continuation byte 0xea, immediately after start byte 0xee) at /usr/bin/../lib/mrtg2/locales_mrtg.pm line 267.
Malformed UTF-8 character (unexpected non-continuation byte 0xe0, immediately after start byte 0xea) at /usr/bin/../lib/mrtg2/locales_mrtg.pm line 267.
Malformed UTF-8 character (unexpected non-continuation byte 0xeb, immediately after start byte 0xe0) at /usr/bin/../lib/mrtg2/locales_mrtg.pm line 267.
Malformed UTF-8 character (unexpected non-continuation byte 0xe8, immediately after start byte 0xeb) at /usr/bin/../lib/mrtg2/locales_mrtg.pm line 267.
Malformed UTF-8 character (unexpected non-continuation byte 0xe7, immediately after start byte 0xe8) at /usr/bin/../lib/mrtg2/locales_mrtg.pm line 267.
Malformed UTF-8 character (unexpected non-continuation byte 0xe0, immediately after start byte 0xe7) at /usr/bin/../lib/mrtg2/locales_mrtg.pm line 267.
Malformed UTF-8 character (unexpected non-continuation byte 0xf6, immediately after start byte 0xe0) at /usr/bin/../lib/mrtg2/locales_mrtg.pm line 267.
Malformed UTF-8 character (unexpected non-continuation byte 0xe8, immediately after start byte 0xf6) at /usr/bin/../lib/mrtg2/locales_mrtg.pm line 267.
Malformed UTF-8 character (unexpected non-continuation byte 0xff, immediately after start byte 0xe8) at /usr/bin/../lib/mrtg2/locales_mrtg.pm line 267.
Malformed UTF-8 character (byte 0xff) at /usr/bin/../lib/mrtg2/locales_mrtg.pm line 267.
Malformed UTF-8 character (unexpected non-continuation byte 0xe0, immediately after start byte 0xed) at /usr/bin/../lib/mrtg2/locales_mrtg.pm line 267.
Malformed UTF-8 character (unexpected non-continuation byte 0x20, immediately after start byte 0xe0) at /usr/bin/../lib/mrtg2/locales_mrtg.pm line 267.
Malformed UTF-8 character (unexpected non-continuation byte 0xfa, immediately after start byte 0xe1) at /usr/bin/../lib/mrtg2/locales_mrtg.pm line 267.
Malformed UTF-8 character (unexpected non-continuation byte 0xeb, immediately after start byte 0xfa) at /usr/bin/../lib/mrtg2/locales_mrtg.pm line 267.
Malformed UTF-8 character (unexpected non-continuation byte 0xe3, immediately after start byte 0xeb) at /usr/bin/../lib/mrtg2/locales_mrtg.pm line 267.
Malformed UTF-8 character (unexpected non-continuation byte 0xe0, immediately after start byte 0xe3) at /usr/bin/../lib/mrtg2/locales_mrtg.pm line 267.
Malformed UTF-8 character (unexpected non-continuation byte 0xf0, immediately after start byte 0xe0) at /usr/bin/../lib/mrtg2/locales_mrtg.pm line 267.
Usage: mrtg <config-file>
mrtg-2.9.17 is the Multi Router Traffic Grapher.
If you want to know more about this tool, you might want
to read the docs. They came together with mrtg!
Home: http://people.ee.ethz.ch/~oetiker/webtools/mrtg/
en dit met een clean instal van een goede distro :'(
bijvoorbaat dank,
Johan
  • RupS
  • Laatst online: 30-08 20:49
Je gebruikt iig het mrtg commando verkeerd, syntax is namelijk:
mrtg <config file>
Wat betreft de meldingen:
Via google kwam ik hier terecht. Daar wordt gezegd dat
export LANG=en_US
de oplossing is...
[ Voor 7% gewijzigd door RupS op 07-08-2003 16:28 ]
  • blaataaps
Foutmelding dumpen en hopen dat iemand het antwoord roept is hier niet helemaal de bedoeling, zie ook de sticky topics bovenaan aan NOS. Eerst zelf zoeken/proberen, vertellen waarom dat niet lukt in een eventueel nieuw topic. Heb je de suggestie al geprobeerd 'lees de docs' en google afgestruind?
succes!
