[Wolf:ET] Unusual high ping problems
  • 130 views sinds 30-01-2008
Like many others I installed the great game Wolfenstein: Enemy Territory.
After playing it for a while i noticed my ping going up frequently (every few seconds) to the max (999+). I use the same connection and (when it's not going up) have the same ping as my friends in the neighborhood. First I thought it was my system so installed it onto my other. Same problem here. Still laggy as hell. When I try to ping a website/server from windows everything looks fine. No interruptions and nice results. I followed the advice from others here in the forum. They suggested turning of Punkbuster and/or change the "/rate" ingame to 25000 (in stead of 5000).
None of this worked. I tried it on 3 different systems now.
All sugestions are welcome..
sys1: AMD TB 1.4, 512MB RAM, Gforce2 GTS, 40GB HD
sys2: Intel P4 2.6, 512MB RAM, ATI RAEDON 9600, 120GB HD
sys3: Intel P4 2.0, 512MB RAM, Mobility RAEDON 32MB, 40GB HD.
  • _Drake_
  • Laatst online: 11:29
Welkom op got :)
First of al this is a dutch forum, so if it is possible please speak dutch
i have played ET a while and although i have adsl the game laggs very much.
i have never search for a solution sinds after a while i did't like the game anymore.
The difficult we do right away, the impossible takes slightly longer.
so let me get this straight,
you get this on all the 3 computer systems? (ping to 999+?)
or is it a particular one?
and do you have the same problems with other games?
if thats so, then it might be your Internet Connection,
I had similar problems & couldn't figure out what was happening. Tried many re-installs but none of the where succesfull. Solution for me was updating Punkbuster (goto the pb map, there you'll find a small tool called pbweb.exe, run it & restart the game when it's done). Before I did this I could log on to every server, play for about 30 seconds and then my ping would go up till I got a server disconnect.
Hope this will solve your problem, it's a fun game.
  • M@NIC
  • Laatst online: 23-09 09:24
@home.nl is Nederlands ;)
Welkom op GoT, zoals je kunt zien is dit een Nederlands forum als je niet de moeite neemt om je berichten te vertalen neem ik de moeite niet om je topic open te houden.
Probeer het eens in het Nederlands.
