[exchange2000] log files worden niet gepurged
  • Grolsch
  • Laatst online: 20:26
Mensen,
Een win2k server met sp3
exchange 2k met sp3
veritas backup software versie 9 incl. exchange agent.
dit is m'n config:
Exchange
Exchange server backup method: FULL - Database & Logs (flush committed logs)
Maibox backup method: FULL - Back up messages - Reset archive bit
Enable single instance backup for message attachments: Yes
officieel hoort ie dus de logs te flushen, maar dat doettie dus niet.
de vraag is waarom dan niet, ik zal ff wat logs ophalen
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
Set Detail Information - Verify \\EX2KAL\Microsoft Exchange Mailboxes
Set type               : Verify
Set status             : Completed
Set description        :
Resource name          : \\EX2KAL\Microsoft Exchange Mailboxes
Logon account          :
Agent used                     : No
Advanced Open File Option used : NoImage used                     : No
Start time             : Wednesday, July 02, 2003 11:13:44 AMEnd time               : Wednesday, July 02, 2003 11:21:15 AM
Files                  : 0Directories            : 0Skipped files          : 0Corrupt files          : 0Files in use           : 0
Byte count             : 474,734,463 bytesRate                   : 60.00 MB/Min
Set Detail Information - Verify \\EX2KAL\Microsoft Exchange Public Folders
Set type               : Verify
Set status             : CompletedSet description        :
Resource name          : \\EX2KAL\Microsoft Exchange Public Folders
Logon account          :
Agent used                     : No
Start time             : Wednesday, July 02, 2003 11:21:15 AM
End time               : Wednesday, July 02, 2003 11:21:16 AM
Files                  : 0
Directories            : 0
Skipped files          : 0
Corrupt files          : 0
Files in use           : 0
Byte count             : 4,668 bytes
Rate                   : 0.00 MB/Min
Set Detail Information - Verify \\EX2KAL\Microsoft Information Store\First Storage Group
Set type               : Verify
Set description        :
Resource name          : \\EX2KAL\Microsoft Information Store\First Storage GroupLogon account          :
Agent used                     : No
Image used                     : No
Start time             : Wednesday, July 02, 2003 11:21:16 AM
End time               : Wednesday, July 02, 2003 11:28:32 AM
Files                  : 0
Directories            : 0
Skipped files          : 0
Corrupt files          : 0
Files in use           : 0
Byte count             : 587,309,624 bytes
Rate                   : 77.00 MB/Min
volgens mij is dit allemaal interesant om te weten.
search levert niks op hier.
op de veritas site geven ze ook geen oplossing.
telefonisch net 40 minuten in de wacht gestaan, werkt dus ook niet.
PVOUPUT - 13.400WP - Twente
  • ZeRoC00L
Agent used staat op no, lijkt me vreemd. Maak je remote een backup, of op de machine zelf ?
Volg je bankbiljetten
  • mutsje
  • Laatst online: 21-10 10:45
mutsje
Certified Prutser
je hebt open file options uit staan je exchange agent niet geinstalleerd??? vage setup dit. wat voor events krijg je?
  • Zwelgje
  • Laatst online: 17-08 09:02
dus in c:\program files\exchsrvr\mdbdata heb je nog veel .log files staan :?
laat eens een overzichtje zien van die directory,
  • Grolsch
ZeRoC00L schreef op 05 August 2003 @ 19:16:
ik heb hem toch echt geinstalleerd en ik kan ook geen optie's vinden om hem te en-ablen/disablen.
zwelgje schreef op 05 August 2003 @ 19:37:
idd, in de transactionlog database (e:\exchange\mdbdata bij mij) staan allemaal bestanden van ca. 5 MB vanaf de dag van installatie, er staat nu 1 GB aan data in.
Wat een scheit support van veritas zeg, ik betaal gewoon 300 € voor support, en ik heb nog NOOIT iemand aan de lijn gehad na ca. 1 UUR !!!!!!! in de wacht te hebben gestaan tot 2 x toe!
  • Brahiewahiewa
  • Laatst online: 30-09-2022
Brahiewahiewa
boelkloedig
Hoe ziet je database/storage group ontwerp er uit? 'k Vind 't een b-tje vreemd dattie eerst je First Storage Group doet en daarna nog eens je Public Folders. Zit je Public store niet in je First Storage Group?
QnJhaGlld2FoaWV3YQ==
  • Grolsch
Brahiewahiewa schreef op 06 August 2003 @ 16:08:
1 server
1 storage group met 2 stores:
mailboxes
public.
transaction log files horen bij de storage group, en daar geeftie ook een foutmelding zie.
Dit zegtie bij de storage group backup:
Set type               : Backup
Set description        :
Logon account          : CITRIXNON\Administrator Default Account
Error code             : a000848c
[b]HEXError description      : Unable to attach to one of the drives.[/b]
Agent used                     : Yes
Image used                     : No
vooral bold gedeelte vind ik vreemd
dat de agent nu op yes staat komt omdat ik iom een helpdesk medewerker een registry key op 1 heb gezet.
[ Voor 3% gewijzigd door Grolsch op 07-08-2003 10:49 ]
  • Brahiewahiewa
Brahiewahiewa
boelkloedig
Als je op http://support.veritas.com/menu_ddProduct_BEWNT.htm zoekt op a000848c vind je een twaalftal artikelen. De interessantste
Error Text in Job Log: - "Unable to attach to"
Reason 1: The user account specified in Backup Exec to backup/restore the resource does not exist on the resource being backed up/restored
Solution: Verify the user account specified exists on the resource being backed up/restored. Edit the backup/restore job on the Job Setup tab and select Resource Credentials. Verify the user account listed next to the resource exists on the resource being backed up/restored.
Reason 2: The password for the user account specified in Backup Exec to
backup/restore the resource is incorrect
Solution: Verify the password for the user account specified is correct. In Backup Exec, edit the backup/restore job on the Job Setup tab, select Resource Credentials and select the "Change" button. Select the "Backup Exec Logon Account" used to backup/restore the resource and select the "Edit" button. Select the "Change password" button and retype in the password for the user account. Make sure the password typed in matches the password for the user account on the resource being backed up/restored.
Reason 3: The resource the backup/restore job is trying to attach to is offline or no longer exists.
Solution: Verify the resource being backed up/restored exists and is online.
  • Grolsch
Brahiewahiewa schreef op 07 augustus 2003 @ 12:03:
had ik idd ook al gevonden, maar ik heb alles 300 % gecheckt, alles draait en alles werkt, en nog geeftie die melding.
Ik hang alweer bij veritas in de wacht op het moment :r, al een half uur
