[php] Grote bestanden uploaden niet goed
Voor mijn site, (justmental): doe maar niet, is het de bedoeling dat geregistreerde leden drivers kunnen uploaden. Nu gaat dit goed tot ong. 5 MB, maar daarboven (ik heb het geprobeerd met een 15 MB file) gaat het fout.
Nu gebruik ik er een class voor, vanaf phpclasses.org, dat is deze:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
Class Upload
    var $maxupload_size = 500000;
    var $_FILES;
    var $errors;
    function Upload($_FILES)
        $this->HTTP_POST_FILES = $_FILES;
        $this->isPosted = false;
    function save($directory, $field, $overwrite,$mode=0777)
        $this->isPosted = true;
        if ($this->HTTP_POST_FILES[$field]['size'] < $this->maxupload_size && $this->HTTP_POST_FILES[$field]['size'] >0)
            $noerrors = true;
            // Get names
            $tempName  = $this->HTTP_POST_FILES[$field]['tmp_name'];
            $file      = $this->HTTP_POST_FILES[$field]['name'];
            $all       = $directory.$file;
            // Copy to directory
            if (file_exists($all))
                if ($overwrite)
                    @unlink($all)         || $noerrors=false; $this->errors  = "Upload class save error: unable to overwrite ".$all."<BR>";
                    @copy($tempName,$all) || $noerrors=false; $this->errors .= "Upload class save error: unable to copy to ".$all."<BR>";
                    @chmod($all,$mode)    || $ernoerrorsrors=false; $this->errors .= "Upload class save error: unable to change permissions for: ".$all."<BR>";
            } else{
                @copy($tempName,$all)   || $noerrors=false;$this->errors  = "Upload class save error: unable to copy to ".$all."<BR>";
                @chmod($all,$mode)      || $noerrors=false;$this->errors .= "Upload class save error: unable to change permissions for: ".$all."<BR>";
            return $noerrors;
        } elseif ($this->HTTP_POST_FILES[$field]['size'] > $this->maxupload_size) {
            $this->errors = "File size exceeds maximum file size of ".$this->maxuploadsize." bytes";
            return false;
        } elseif ($this->HTTP_POST_FILES[$field]['size'] == 0) {
            $this->errors = "File size is 0 bytes";
            return false;
    function saveAs($filename, $directory, $field, $overwrite,$mode=0777)
            $noerrors = true;
            // Get names
            $all       = $directory.$filename;
                if ($overwrite)
                    @unlink($all)         || $noerrors=false; $this->errors  = "Upload class saveas error: unable to overwrite ".$all."<BR>";
                    @copy($tempName,$all) || $noerrors=false; $this->errors .= "Upload class saveas error: unable to copy to ".$all."<BR>";
                    @chmod($all,$mode)    || $noerrors=false; $this->errors .= "Upload class saveas error: unable to copy to".$all."<BR>";
            } else{
                @copy($tempName,$all)   || $noerrors=false; $this->errors  = "Upload class saveas error: unable to copy to ".$all."<BR>";
                @chmod($all,$mode)      || $noerrors=false; $this->errors .= "Upload class saveas error: unable to change permissions for: ".$all."<BR>";
            return $noerrors;
            return false;
            return false;
    function getFilename($field)
        return $this->HTTP_POST_FILES[$field]['name'];
    function getFileMimeType($field)
        return $this->HTTP_POST_FILES[$field]['type'];
    function getFileSize($field)
        return $this->HTTP_POST_FILES[$field]['size'];
Maar volgens mij ligt de fout niet aan de class..
Iemand enig idee ? :/
[ Voor 12% gewijzigd door justmental op 05-08-2003 15:45 ]
  • marty
  • Laatst online: 27-03-2023
Verwijderd schreef op 05 August 2003 @ 14:56:
Voor mijn site, driverfiles.net, is het de bedoeling dat geregistreerde leden drivers kunnen uploaden. Nu gaat dit goed tot ong. 5 MB, maar daarboven (ik heb het geprobeerd met een 15 MB file) gaat het fout.
Class Upload
Zie vetgedrukte text :)
volgende keer ff tussen php-tags zetten trouwens, dat leest wat prettiger dan gewone code tags
  • Kippenijzer
  • Laatst online: 12-10 07:23
Kippenijzer
McFallafel, nu met paardevlees
het zijn gewoon settings van php zelf die bepalen wat het maximum hier is, alleen weet ik zo die setting niet uit mijn hoofd... Zijn wel al meerdere topics die hierover struikelden met oplossingen en verdert zou het natuurlijk ook op php.net te vinden zijn, zijn gewoon instellingen van php zelf, en die zijn vast terug te vinden in hun online manual. Succes!
  • Wolfboy
Wolfboy
ubi dubium ibi libertas
er zit ergens in de php.ini zo'n setting die dit bepaald, niet boven de 5mb dacht ik.
standaard is dat de max, als je meer wilt dan moet je het veranderen
Blog [Stackoverflow] [LinkedIn]
  • Arnout
  • Laatst online: 23:09
php.ini >> upload_max_filesize verhogen.
  • Apache
  • Laatst online: 19-10 19:09
Apache
amateur software devver
afaik moet je de max memory limits in je php.ini verhogen maar ook in je httpd.conf omdat de files eerst naar het geheugen worden geupload. Ik vrees dat je hosting provider hier niet zo gelukkig mee zal zijn.
If it ain't broken it doesn't have enough features
ok bedankt voor de info =] ik ga het mijn hosting provider even vragen, maar ik vrees dat die het niet zal verhogen ..
  • Arnout
Apache >> ik heb 15M upload limit gezet zonder aan httpd.conf te sleutelen, gaat prima.
digitalghost >> Vergeet niet dat het uploaden van grote bestanden (> 5 MB) erg lang *kan* duren (16kb/sec upload gem.) zonder dat de gebruiker "progress" ziet.
[ Voor 15% gewijzigd door Arnout op 05-08-2003 15:18 ]
Er is een upload script wat de progress laat zien.
Zie bijv:
http://www.faqchest.com/p...22/php02090920_31400.html
of zoek op google naar php upload progress bar
[ Voor 5% gewijzigd door Verwijderd op 05-08-2003 15:22 ]
  • Wolfboy
Wolfboy
je kan ook dat invision file manager php scriptje gebruiken.
werkt wel prettig maar das meer voor de lol denk ik, niet om professioneel in te zetten.
  • Janoz
  • Laatst online: 22-10 08:54
Janoz
Moderator Devschuur®
!litemod
Verwijderd schreef op 05 augustus 2003 @ 15:22:
Zie bijv:
Het gegeven script laat niet 'de progress' maar dat er progress is. Gewoon een soort 'even geduld'. Het laat niet zien hoe ver hij al is. Dit is met php niet mogenlijk zonder flink in apache te hacken of gebruik te maken van een (untrusted) activeX component.
  • marty
Janoz schreef op 05 augustus 2003 @ 15:39:
wat versta jij onder 'flink inhacken' ?
je kunt toch gewoon de grootte van de temporary file die wordt aangemaakt uitlezen en die om de zoveel seconde weergeven
  • Arnout
marty schreef op 05 augustus 2003 @ 16:03:
Hoe wil je dat doen? php komt pas om de hoek kijken als file upload 100%, dus klaar is.
Hacken in Apache, als in: met mod_perl aan de slag.
  • Rense Klinkenberg
  • Laatst online: 21-10 20:25
Er is iemand die een php extensie heeft gemaakt, waarmee wel de voortgang kan worden weergegeven.
Met een beetje geluk wordt die ook opgenomen in een van de komende php releases of in pecl.
Ok, het is dus geen extensie, maar een patch voor php: http://www.zend.com/lists/php-dev/200306/msg00075.html
[ Voor 26% gewijzigd door Rense Klinkenberg op 05-08-2003 16:41 ]
  • Evilbee
  • Laatst online: 22:33
Met zo'n progress-bar heb je altijd de groote van het bestand nodig. En die groote weet je alleen als je het hele bestand binnen hebt. De enige manier is denk ik de gebruiker de groote van het bestand laten opgeven.
LinkedIn - Collega worden?
  • Rense Klinkenberg
Toch werkt die progress bar perfect. Waarschijnlijk wordt bij de request van de browser ook een content-length header meegestuurd, zoals de server die ook vaak naar de browser terug stuurt.
  • Hmmbob
  • Laatst online: 18:44
wat ook kan zijn, om even terug naar het probleem van TS te gaan, is dat de max-execution-time in het geding komt. Dat was bij een van mijn file-uploads.
  • marty
MetHod schreef op 05 August 2003 @ 16:06:
Je kunt toch een windowtje laten open-poppen die zichzelf iedere 5 seconde refreshed met daarachter een php scriptje dat de bestandsgrootte van die tijdelijke file uitleest? Of denk ik nu te simpel?
  • Arnout
marty schreef op 05 August 2003 @ 22:35:
Welke tijdelijke file? :)
Kijk maar eens op google, php en upload progress bars is zo eenvoudig nog niet.
/offtopic.
