RH8.0 :Willen jullie even mijn conf checken ?
  • 54 views sinds 30-01-2008
Hiya ,
ik wil me rh8.0 servertje instellen met dhcp en internet sharing dmv iptables
Alle client pcś krijgen nu een ip-adres via dhcp alleen me internet delen doet hij nog niet .
Ik kan wel pingen naar server-client en vice versa
Hier me configs
[root@kbl-gs4104 root]# cat /etc/dhcpd.conf
ddns-update-style interim;
ignore client-updates;
subnet 192.168.0.0 netmask 255.255.255.0 {
# --- default gateway
option routers 192.168.0.0;
option subnet-mask 255.255.255.0;
option nis-domain "hilfinger.org";
option domain-name "hilfinger.org";
option domain-name-servers 212.115.192.193,212.115.192.195;
option time-offset -18000; # Eastern Standard Time
# option ntp-servers 192.168.1.1;
# option netbios-name-servers 192.168.1.1;
# --- Selects point-to-point node (default is hybrid). Don't change this unless
# -- you understand Netbios very well
# option netbios-node-type 2;
range dynamic-bootp 192.168.0.3 192.168.0.20;
default-lease-time 21600;
max-lease-time 43200;
<Dit is mijn netwerk config eth0=lan eth1=internet
[root@kbl-gs4104 root]# ifconfig
eth0 Link encap:Ethernet HWaddr 00:E0:06:FC:04:C2
inet addr:192.168.0.1 Bcast:192.168.0.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:530 errors:0 dropped:0 overruns:0 frame:0
TX packets:151 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:100
RX bytes:69300 (67.6 Kb) TX bytes:109839 (107.2 Kb)
Interrupt:3 Base address:0xd400
eth1 Link encap:Ethernet HWaddr 00:00:B4:C2:B6:E4
inet addr:62.238.80.40 Bcast:62.238.95.255 Mask:255.255.224.0
RX packets:90187 errors:0 dropped:0 overruns:0 frame:0
TX packets:2318 errors:0 dropped:0 overruns:0 carrier:0
collisions:17 txqueuelen:100
RX bytes:7086077 (6.7 Mb) TX bytes:265101 (258.8 Kb)
Interrupt:3 Base address:0xaf00
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:14 errors:0 dropped:0 overruns:0 frame:0
TX packets:14 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:1028 (1.0 Kb) TX bytes:1028 (1.0 Kb)
<<<<<<<<<<<<<<< DIT IS ME FIREWALL CONFIG >>>>>>>>>>>>>>>>>>>>>>>>>>>>>
[root@kbl-gs4104 root]# cat /etc/rc.d/rc.ffw
#!/bin/sh
# rc.firewall-2.4
FWVER=0.62
# Initial SIMPLE IP Masquerade test for 2.4.x kernels
# using IPTABLES.
# Once IP Masquerading has been tested, with this simple
# ruleset, it is highly recommended to use a stronger
# IPTABLES ruleset either given later in this HOWTO or
# from another reputable resource.
# Log:
# 0.62 - Fixed a typo on the MASQ enable line that used eth0
# instead of $EXTIF
# 0.61 - Changed the firewall to use variables for the internal
# and external interfaces.
# 0.60 - 0.50 had a mistake where the ruleset had a rule to DROP
# all forwarded packets but it didn't have a rule to ACCEPT
# any packets to be forwarded either
# - Load the ip_nat_ftp and ip_conntrack_ftp modules by default
# 0.50 - Initial draft
echo -e "\n\nLoading simple rc.firewall version $FWVER..\n"
# The location of the 'iptables' program
# If your Linux distribution came with a copy of iptables, most
# likely it is located in /sbin. If you manually compiled
# iptables, the default location is in /usr/local/sbin
# ** Please use the "whereis iptables" command to figure out
# ** where your copy is and change the path below to reflect
# ** your setup
IPTABLES=/sbin/iptables
#IPTABLES=/usr/local/sbin/iptables
#Setting the EXTERNAL and INTERNAL interfaces for the network
# Each IP Masquerade network needs to have at least one
# external and one internal network. The external network
# is where the natting will occur and the internal network
# should preferably be addressed with a RFC1918 private address
# scheme.
# For this example, "eth0" is external and "eth1" is internal"
# NOTE: If this doesnt EXACTLY fit your configuration, you must
# change the EXTIF or INTIF variables above. For example:
# EXTIF="ppp0"
# if you are a modem user.
EXTIF="eth0"
INTIF="eth1"
echo " External Interface: $EXTIF"
echo " Internal Interface: $INTIF"
#== No editing beyond this line is required for initial MASQ testing ==
echo -en " loading modules: "
# Need to verify that all modules have all required dependencies
echo " - Verifying that all kernel modules are ok"
/sbin/depmod -a
# With the new IPTABLES code, the core MASQ functionality is now either
# modular or compiled into the kernel. This HOWTO shows ALL IPTABLES
# options as MODULES. If your kernel is compiled correctly, there is
# NO need to load the kernel modules manually.
# NOTE: The following items are listed ONLY for informational reasons.
# There is no reason to manual load these modules unless your
# kernel is either mis-configured or you intentionally disabled
# the kernel module autoloader.
# Upon the commands of starting up IP Masq on the server, the
# following kernel modules will be automatically loaded:
# NOTE: Only load the IP MASQ modules you need. All current IP MASQ
# modules are shown below but are commented out from loading.
#Load the main body of the IPTABLES module - "iptable"
# - Loaded automatically when the "iptables" command is invoked
# - Loaded manually to clean up kernel auto-loading timing issues
echo -en "ip_tables, "
/sbin/insmod ip_tables
#Load the IPTABLES filtering module - "iptable_filter"
# - Loaded automatically when filter policies are activated
#Load the stateful connection tracking framework - "ip_conntrack"
# The conntrack module in itself does nothing without other specific
# conntrack modules being loaded afterwards such as the "ip_conntrack_ftp"
# module
# - This module is loaded automatically when MASQ functionality is
# enabled
echo -en "ip_conntrack, "
/sbin/insmod ip_conntrack
#Load the FTP tracking mechanism for full FTP tracking
# Enabled by default -- insert a "#" on the next line to deactivate
echo -en "ip_conntrack_ftp, "
/sbin/insmod ip_conntrack_ftp
#Load the general IPTABLES NAT code - "iptable_nat"
# - Loaded automatically when MASQ functionality is turned on
echo -en "iptable_nat, "
/sbin/insmod iptable_nat
#Loads the FTP NAT functionality into the core IPTABLES code
# Required to support non-PASV FTP.
echo -en "ip_nat_ftp, "
/sbin/insmod ip_nat_ftp
# Just to be complete, here is a list of the remaining kernel modules
# and their function. Please note that several modules should be only
# loaded by the correct master kernel module for proper operation.
# ipt_mark - this target marks a given packet for future action.
# This automatically loads the ipt_MARK module
# ipt_tcpmss - this target allows to manipulate the TCP MSS
# option for braindead remote firewalls.
# This automatically loads the ipt_TCPMSS module
# ipt_limit - this target allows for packets to be limited to
# to many hits per sec/min/hr
# ipt_multiport - this match allows for targets within a range
# of port numbers vs. listing each port individually
# ipt_state - this match allows to catch packets with various
# IP and TCP flags set/unset
# ipt_unclean - this match allows to catch packets that have invalid
# IP/TCP flags set
# iptable_filter - this module allows for packets to be DROPped,
# REJECTed, or LOGged. This module automatically
# loads the following modules:
# ipt_LOG - this target allows for packets to be
# logged
# ipt_REJECT - this target DROPs the packet and returns
# a configurable ICMP packet back to the
# sender.
# iptable_mangle - this target allows for packets to be manipulated
# for things like the TCPMSS option, etc.
echo ". Done loading modules."
#CRITICAL: Enable IP forwarding since it is disabled by default since
# Redhat Users: you may try changing the options in
# /etc/sysconfig/network from:
# FORWARD_IPV4=false
# to
# FORWARD_IPV4=true
echo " enabling forwarding.."
echo "1" > /proc/sys/net/ipv4/ip_forward
# Dynamic IP users:
# If you get your IP address dynamically from SLIP, PPP, or DHCP,
# enable this following option. This enables dynamic-address hacking
# which makes the life with Diald and similar programs much easier.
echo " enabling DynamicAddr.."
echo "1" > /proc/sys/net/ipv4/ip_dynaddr
# Enable simple IP forwarding and Masquerading
# NOTE: In IPTABLES speak, IP Masquerading is a form of SourceNAT or SNAT.
# NOTE #2: The following is an example for an internal LAN address in the
# 192.168.0.x network with a 255.255.255.0 or a "24" bit subnet mask
# connecting to the Internet on external interface "eth0". This
# example will MASQ internal traffic out to the Internet not not
# allow non-initiated traffic into your internal network.
# ** Please change the above network numbers, subnet mask, and your
# *** Internet connection interface name to match your setup
#Clearing any previous configuration
# Unless specified, the defaults for INPUT and OUTPUT is ACCEPT
# The default for FORWARD is DROP
echo " clearing any existing rules and setting default policy.."
$IPTABLES -P INPUT ACCEPT
$IPTABLES -F INPUT
$IPTABLES -P OUTPUT ACCEPT
$IPTABLES -F OUTPUT
$IPTABLES -P FORWARD DROP
$IPTABLES -F FORWARD
$IPTABLES -t nat -F
echo " FWD: Allow all connections OUT and only existing and related ones IN"
$IPTABLES -A FORWARD -i $EXTIF -o $INTIF -m state --state ESTABLISHED,RELATED -j ACCEPT
$IPTABLES -A FORWARD -i $INTIF -o $EXTIF -j ACCEPT
$IPTABLES -A FORWARD -j LOG
echo " Enabling SNAT (MASQUERADE) functionality on $EXTIF"
$IPTABLES -t nat -A POSTROUTING -o $EXTIF -j MASQUERADE
echo -e "\nrc.firewall-2.2 v$FWVER done.\n"
  • Zwerver
Verwijderd schreef op 30 July 2003 @ 12:56:
..... alleen me internet delen doet hij nog niet .
zoek het verschil, en post dan even hier waarom jij denkt waarom het zou moeten werken? Of heb je het gewoon niet gezien?
Woonachtig Down Under. Ik negeer je insults niet, maar tegen de tijd dat ik ze lees zijn ze meestal niet relevant meer
Mmm. ik heb nu van eth0 ( me lan kaart ) het ip adres veranderd naar 192.168.0.0 ,
Weer kan ik client-server vice versa pingen maar mijn internet delen doet hij nog steeds niet ...
  • cowgirl
  • Laatst online: 20-08 12:45
EXTIF="eth0"
INTIF="eth1"
EXTIF moet eth1 zijn en INTIF eth0.
Kan je niet beter van routers 192.168.0.1 maken?
[ Voor 28% gewijzigd door cowgirl op 30-07-2003 13:28 ]
  • WHiZZi
  • Laatst online: 11-09 17:21
WHiZZi
Museumdirecteurtje
Verwijderd schreef op 30 July 2003 @ 13:25:
TIP: Lees je boeken over TCP/IP nog es na ;)
192.168.0.0 als IP voor een PC is onmogelijk, dat is namelijk het netwerk
192.168.0.255 is ook niet mogelijk.
Hint voor je probleem: Het IP van de Router in dhcpd.conf gelijk zetten met die van je server (192.168.0.1)
HomeComputerMuseum - Interactief computermuseum waar wij de geschiedenis van de thuiscomputer preserveren. Centraal gelegen in de Benelux.
Mensen ik dank u zeer :-)
problem solved
  • blaataaps
Mooi :)
typo + tcp/ip basics + problem solved = slotje denk ik :p
