[W2K] Perflib probleem na installtie SP4
Afgelopen zaterdag heb ik SP4 geïnstalleerd op 1 van mijn servers.
In de eventviewer komen steeds deze meldingen te staan:
Event Type: Warning
Event Source: Perflib
Event Category: None
Event ID: 2003
Date: 21-7-2003
Time: 6:03:15
User: N/A
Computer: VM-S1
Description:
The configuration information of the performance library "C:\WINNT\system32\w3ctrs.dll" for the "W3SVC" service does not match the trusted performance library information stored in the registry. The functions in this library will not be treated as trusted.
Event Type: Warning
Event ID: 2003
Date: 21-7-2003
Time: 6:03:15
User: N/A
Computer: VM-S1
Description:
The configuration information of the performance library "C:\WINNT\system32\ftpctrs2.dll" for the "MSFTPSVC" service does not match the trusted performance library information stored in the registry. The functions in this library will not be treated as trusted.
Event Type: Warning
Event ID: 2003
Date: 21-7-2003
Time: 6:03:15
User: N/A
Computer: VM-S1
Description:
The configuration information of the performance library "C:\WINNT\system32\infoctrs.dll" for the "InetInfo" service does not match the trusted performance library information stored in the registry. The functions in this library will not be treated as trusted.
Event Type: Warning
Event ID: 2003
Date: 21-7-2003
Time: 6:03:15
User: N/A
Computer: VM-S1
Description:
The configuration information of the performance library "C:\WINNT\system32\aspperf.dll" for the "ASP" service does not match the trusted performance library information stored in the registry. The functions in this library will not be treated as trusted.
Nu heb deze link wel gevonden http://support.microsoft.com/?kbid=267831
Maar dan genereed hij weer deze fouten:
Event Type: Error
Event Source: LoadPerf
Event ID: 3009
Date: 22-7-2003
Time: 9:29:40
User: N/A
Computer: VM-S1
Description:
Installing the performance counter strings for inetinfo failed. The Error code is DWORD 0 of the Record Data.
Data:
0000: b7 00 00 00 ·...
Event Type: Error
Event ID: 3000
Date: 22-7-2003
Time: 9:29:00
User: N/A
Computer: VM-S1
Description:
The performance strings in the registry do not match the index values stored in the Perflib key. The Record Data contains the last index value from the Perflib key in DWORD 0 and the index of the last string used as DWORD 1.
Data:
0000: e7 17 00 00 bb 19 00 00 ç...»...
En dan 3 of 4x per onderdeel.
Ik heb de server niet herstart maar maakt dat nog wel uit dan want hij laadt ze nu ook al niet.
Zlef na de herstart blijft die melding terug komen....... :'( :'(
  • ReLight
  • Laatst online: 12-10 20:40
ReLight
echo("What Now ? !")
Het is geen oplossing maar ik kwam er alleen vanaf door de performance keys van die services te verwijderen,.. Hij laad ze dan niet meer.
'k weet het. =2 wrong way. Maar ik kwam er niet vanaf. Begon na installatie van PCAnywhere bij ons.
Mijn zoon & dochter zijn de toekomst, de rest is tijdsvermaak. Home assistant & & Nibe S2125-12/SMO-S40, RMU-s40 & Tado - Volvo C40 ER, SE
  • Predator
  • Laatst online: 06:54
Predator
Suffers from split brain
http://www.eventid.net/di...ntid=3009&source=LoadPerf
http://www.eventid.net/di...ntid=3000&source=LoadPerf
en deze 2 bovenstaande dingen had je ook al gevonden, en had je niets aan :?
Everybody lies | BFD rocks ! | PC-specs
ik heb deze fouten (overigens alleen de www service; maar ik gebruik geen ftp) ook op alle servers die ik geupgrade heb... maar het zijn maar perf counters, niks om je druk over te maken...
  • Dromer
  • Laatst online: 26-10 17:51
Ik heb ze ook, zelfs al voor sp4.
Inderdaad gewoon de counters uitgezet.
Niet de beste oplossing mischien maar wel de makkelijkste.
Wel grappig dat ik na elke fix vanuit MS er wel wat anders was wat begon te brullen.
Geen flame naar MS overigens maar wel gewoon heel opvallend.
Mijn conclusie, je maakt je leven prettiger door ze er gewoon uit te halen :)
Verwijder PERFLIB events met
Extensible Performance Counter List
http://www.microsoft.com/...s/existing/exctrlst-o.asp
Of hack de registry:
Het MS KB article dat hierover gaat is 226494:
http://support.microsoft.com/?scid=kb;en-us;226494
[ Voor 10% gewijzigd door Verwijderd op 23-07-2003 22:27 ]
  • Dromer
Dat tooltje wat smiley zegt heb ik dus ook gebruikt.
En werkt dus ook gewoon perfecto.
  • ReLight
ReLight
Mod +2 @ Smiley
>En ik die keys maar om zeep helpen,... Naja, hoeft dus nooit meer.
Smiley....bedankt!!
Ik heb de libraries die zaten te fokken uitgezet...Dat zou toch voldoende moeten zijn?
Ik ga ervan uit dat het helpt :*)
[ Voor 16% gewijzigd door Verwijderd op 24-07-2003 09:54 ]
  • mutsje
  • Laatst online: 21-10 10:45
mutsje
Certified Prutser
beide urls toegevoegd aan datacrash.net is weer informatie waarde.
Verwijderd schreef op 24 July 2003 @ 09:49:
Smiley....bedankt!!
Smiley ???????????????
Bij mijn server werkt die tool niet of moet ik de service ook uit zetten???
Melding komt nml nog steeds terug.... 8)7
Dan dus toch maar de reg hacken????
[ Voor 6% gewijzigd door Verwijderd op 24-07-2003 11:36 ]
heb je wel een engelse versie? zo nee lees de site nog eens een keer :)
Verwijderd schreef op 24 July 2003 @ 12:44:
Ik heb de Engelse versie....
Geen tips meer?????
  • Question Mark
  • Laatst online: 26-10 16:09
Question Mark
Moderator SSC/WOS
F7 - Nee - Ja
Kleine opmerking. Na het monitoren van een uitgeschakelde counter via de performance monitor worden de counters automatisch weer aangezet.... Ook al werken deze niet...
Na het aanklikken van de counter in de performance monitor staat de counter weer aan en verschijnen de foutmeldingen weer in de event log.
Nou, ik ga de reg wel hacken..kijken of ik dan die melding kwijt raak....
