Chaintech Apogee 9PJL [Ervaringen]
  • sailor_ej
  • Laatst online: 26-10 21:57
Ik heb dit topic gemaakt omdat der nog geen centraal topic over was.
Post hier al u vragen over het Chaintech Appogee 9PJL mobo.
De Manual
Bios Updates
Versie 1.0
versie 2.0
Plaatjes van het MoBo
Afbeeldingslocatie: http://www.chaintechusa.com/tw/images/Products/Motherboard/9PJL_L.jpg
Afbeeldingslocatie: http://www.octools.com/articles/chaintech/springdale/9PJL_B.jpg
Specs
Form
Factor
ATX (305mm x 244mm)
CPU
Supports Intel Socket 478 CPU with Hyper-Threading Technology
Supports Intel Pentium4/Celeron system bus at 400/533/800MHz
Chipset
Intel 865PE + ICH5, supports Hyper-Threading Technology
Main Memory
Four 184-pin DDR DIMMs up to 4GB
Supports Dual-Channel DDR266/333/400 memory
Expansion
Slots
One 1.5V AGP slot for 8X/4X AGP
Five 32-Bit PCI slots (v2.2 compliant)
Audio Subsystem
Full-duplex operation for simultaneous recording and playback
6 channel speaker audio supports
Embedded 32OHM 5w earphone amplifier
Supports MIDI and Game port
32 Voice HRTF 3D positional audio, CRL 3D supports MS Direct
Sound3D, Aureal A3D and Creative EAX APIs
Video
Subsystem
Video 4X/8X AGP
UltraDMA IDE Ports
Supports PIO Mode 4 up to 16.6 Mbps, Multi-Word DMA Mode 2
and Ultra DMA mode 5 up to 100MB/s with Bus Mastering
Bus-Mastering software drivers for all common multitasking
operating systems
Embedded USB Controller
Three EHCI USB 2.0 Controllers support total 8 USB 2.0/1.1 Ports
Support USB 2.0 High-Speed Device @480 Mb/s Transfer Rates
Optional USB adapters for additional USB2.0/1.1 ports
On Board Super I/O
Controller
ITE 8712 LPC I/O with system monitors hardware
Two UARTs support serial ports and IR function (up to 115.2Kbps)
for HPSIR and ASKIR
One SPP/ECP/EPP parallel port
One floppy disk drive connector supports up to 2.88MB
Embedded
system monitoring
8 external voltage inputs
2 temperatures sensing for CPU and system
3 Fan speed (CPU, System and Case) monitoring
Boot-Block Flash ROM
Award system BIOS support PnP, APM, DMI, ACPI, & Multi-device booting
features
Software
Driver CD (Chipset Autodetect)
Value Pack 2003
APOGEE Overclocking
Other Feature Back panel I/O
connector
One PS/2 mini-DIN mouse and keyboard ports
Four USB Ports and one RJ45 connector
Two 9-pin D-SUB male Serial ports
One 25-pin D-SUB female Parallel port
Audio Line-in, Line-out and Mic-in jacks
On-board SATA Controller
Build-in ICH5 supports 2 Serial ATA devices for the highest data
transfer rates (1.5Gbps burst)
On-board VIA VT6306 IEEE1394 Host Controller
Serial bus data rates of 100, 200 and 400Mbps
IEEE P1394a compliant and IEEE 1394
Programmable ATA/ATAPI interface supporting PIO modes 0-4, DMA modes
0-2 and Ultra DMA modes 0-4
On board connector for external device
Three 3x1 pin fan connectors
2x1 pin fan connector with housing for Northbridge
Two 5x2 pin USB connectors for additional 4 USB2.0 ports on CBOX2
6x1 pin Infrared connector
3x1 pin wake on LAN connector with housing
3x1 pin wake on Modem connector with housing
Two 4x1 pin CD-in connectors with 2.54mm pitch housing
4x1 pin Aux-in connector with 2mm pitch housing
4x2 pin Sub-Woofer connector for Surround and Center/Sub-Woofer
phone jacks on CMK
9x2 pin front panel connector
5x2 pin front side audio connector for Headphone and Microphone
jacks on CBOX2
5x2 pin Segment display connector for 2-digits Debug LED on CBOX2
Three 8x1 pin IEEE1394 connectors with housing for additional
IEEE1394 ports (One connector for front IEEE1394 port on CBOX2;
two connectors for two IEEE1394 ports on CMK)
8x2 pin connector for D-SUB female Game/MIDI port on CMK
17x2 pin floppy connector
Review
OC tools New Zeeland
Prijs
E & E Internet Solutions Online Shop (€ 156.19)
Mocht ik nog iets vergeten zijn dan hoor ik het wel
We cannot direct the wind, but we can adjust the sails
  • Sluuut
  • Laatst online: 30-10 21:36
Ondersteund dit bord geen S-ATA Raid, en dan Raid0 en/of Raid1 ??
Op de site van Chaintech kan ik er ook niets over vinden...
57696520646974206c65657374206973206e657264
