Abit IS7 (-E,-G) I865PE [Ervaringen]
  • TheGreatCornholio
  • Laatst online: 27-07 15:37
Hallo en welkom bij het grote Abit IS7 topic.
Eindelijk een topic over wat [H]ard|ocp noemt ' The best bang for the buck we will see this year. And that is simply hard to argue with.'
Show je benchmark resultaten, stel je vraag, laat je probleem zien oftewel, laten we elkaar helpen een zo snel en stabiel mogelijk systeem te bouwen rond dit bordje. :)
De specs :
(CPU)
- Supports Intel Pentium 4 Socket 478 processors with 800/533/400 MHz FSB
- Supports Intel Hyper-Threading Technology Chipset
(CHIPSET)
- Intel 865PE / ICH5-R
- Supports Dual Channel DDR 400 Memory
- Supports Advanced Configuration and Power Management Interface (ACPI)
(MEMORY)
- Four 184-pin DIMM sockets
- Supports 4 DIMM Single/Dual Channel DDR 400 memory (Max. 4GB)
(AGP)
- Accelerated Graphics Port connector supports AGP 8X/4X (0.8V/1.5V)
(SATA RAID)
- On board 2 channels Serial ATA 150MB/s data transfer rate
- Supports RAID 0
(LAN)
- On board 10/100Mb LAN
(IEEE 1394)
- Supports IEEE 1394a at 100/200/400 Mb/s transfer rate
(USB 2.0)
- 8 ports USB 2.0 Supports 480 Mb/s data transfer rate
(Audio)
- 6-Channel AC 97 CODEC on board
- Professional digital audio interface supports S/P DIF optical In / Out
(Media XP (Optional))
- Supports card reader function for Memory Stick™, Secure Digital™ and Type I/II CompactFlash™
- Supports Wireless Remote Control and S/PDIF Out / Mic In / Headphone Out / USB 2.0 / IEEE 1394
(System BIOS)
- SoftMenu™ Technology to set CPU parameters
- Supports Plug-and-Play (PNP)
- Supports Advanced Configuration Power Interface (ACPI)
- Write-Protect Anti-Virus function by AWARD BIOS
(Internal I/O Connectors)
- 1 x AGP, 5 x PCI slots
- 1 x IrDA
- 1 x Floppy Port supports up to 2.88MB
- 2 x Ultra DMA 33/66/100 Connectors
- 4 x Serial ATA 150 Connectors (2 x Optional)
- 2 x USB 2.0 headers, 2 x IEEE 1394a header (Optional)
- 1 x CD-IN, 1 x AUX-IN
(Back Panel I/O)
- 1 x PS/2 Keyboard, 1 x PS/2 mouse
- 1 x Printer Port, 1 x COM port
- 1 x S/PDIF In connector, 1 x S/PDIF Out connector
- 1 x Audio connector (Front Speaker, Line-in, Mic-in)
- 1 x Audio connector (Center/Sub, Surround Speaker)
- 2 x USB 2.0, 1 x IEEE 1394a (Optional)
- 2 x USB 2.0, 1 x RJ-45 LAN Connector
(Miscellaneous)
- ATX form factor
- Hardware Monitoring - Including Fan speed, Voltages, CPU and System temperature
De verschillen :
Afbeeldingslocatie: http://img.hexus.net/IS7/865.jpg
de pics :
Afbeeldingslocatie: http://202.168.194.118/abit/upload/products/IS7_pic6.jpg
Afbeeldingslocatie: http://202.168.194.118/abit/upload/products/IS7-E_pic6.jpg
Afbeeldingslocatie: http://202.168.194.118/abit/upload/products/IS7-G_pic6.jpg
Afbeeldingslocatie: http://202.168.194.118/abit/upload/products/IS7-M_pic6.jpg
De reviews :
Hexus
PCstats
OCworkbench
Ninjalane
Techreport
Anandtech 865PE/875P Motherboard Roundup
[H]ard|ocp
UkGamer
De nieuwste bios :
is7g15.exe
BIOS ID: 1.4 Released Date: 7/2/2003
1# Fixed the problem that no effect during POST if change "Delay IDE Initial" in BIOS setup.
2# Revised the wording of IEEE1394 controller in PCI device listing.
3# Fixed the problem that DOS4GW.EXE causes system hang-up in DOS environment.
4# Added function that automatically detects CPU operation speed after discharging CMOS data.
5# Added SATA RAID 1 function for Intel ICH5R south bridge. The IAA RAID driver should be updated to v3.5 or later to support RAID 1 in Windows XP. http://downloadfinder.int...r35_enu.exe&ProductID=961
6# BIOS Compile date: 7/14/2003.
De forums :
*** Official ABIT IS7/G/E (865PE) Thread *** (anandtech)
Intel Chipset Socket 478 motherboards (abit usa)
[ Voor 14% gewijzigd door TheGreatCornholio op 12-08-2003 01:45 ]
Krijg de indruk dat er meer mensen zijn die voor de IC7 kiezen gezien de niet al te hoge meerprijs en de ervaringen die daar wel al aardig aan het binnenstromen zijn. Ik hoop echter wel dat er ook hier wat post binnenstroomt want ikzelf zit een beetje te denken om dit bordje aan te schaffen (...maar de IC7 is ook nog niet van de baan...).
Die IC7 is toch wel een stukje duurder. Als ik een 865PE mobo zou halen gaat mijn voorkeur eerder uit naar die MSI 865PE Neo2. Dit vanwege o.a. de zeer positieve reviews en ook mijn persoonlijke voorkeur voor MSI :)
Ik vul het lijstje van reviews nog even aan:
Ik heb ze hier vandaan http://www.techview.nl/products/910 kan een dode link tussen zitten.
3dXtreme http://www.3dxtreme.org/Abit_IS7-G_p1.shtml
The Tech Report http://www.tech-report.co...3q3/abit-is7/index.x?pg=1
MBReview http://www.mbreview.com/is7g.php
HotHardware http://www.hothardware.co...springdale_showdown.shtml
Overclockers Australia http://www.overclockers.com.au/article.php?id=186225
Tom's Hardware http://www17.tomshardware...board/20030707/index.html
Viper's Lair http://www.viperlair.com/...obo/abit/p4/is7/is7.shtml
Intelforums.net http://www.intelforums.net/viewtopic.php?t=246
ClubOC.net http://www.cluboc.net/rev...ards/abit/is7_g/index.htm
VR-Zone http://www.vr-zone.com/reviews/Intel/865PE/
3DGameMan http://www.3dgameman.com/vr/abit/abit_is7g/video_review.html
LostCircuits http://www.lostcircuits.com/motherboard/abit_is7/
PCStats http://www.pcstats.com/articleview.cfm?articleID=1410
VR-Zone http://www.vr-zone.com/reviews/ABIT/ICS7G/
OCWorkbench http://www.ocworkbench.com/2003/abit/is7g/is7g-1.htm
HardOCP http://www.hardocp.com/article.html?art=NDgw
AnandTech http://www.anandtech.com/mb/showdoc.html?i=1831&p=1
HEXUS.net http://www.hexus.net/review.php?review=572
Legit Reviews.com http://www.legitreviews.com/Reviews/is7_1.shtml
TBreak.com http://www.tbreak.com/reviews/article.php?id=210
Ninjalane http://www.ninjalane.com/display.aspx?docname=abit-is7
OCAddiction http://www.ocaddiction.com/reviews/mobos/abit_is7/
Extreme Overclocking http://www.extremeoverclo...herboards/ABIT_IS7_1.html
AnandTech http://www.anandtech.com/chipsets/showdoc.html?i=1823
  • 418O2
418O2
u mad?
Okkk...
Mijn micingang piept kraakt en stoort als de nete, iemand hiervoor een oplossing?
//edit
Mic Boost uit == minder ruis
[ Voor 19% gewijzigd door 418O2 op 04-08-2003 21:56 ]
  • TheGreatCornholio
418O2 schreef op 04 August 2003 @ 21:49:
Okkk...
//edit
Beetje late reaktie maar dit schijnt een probleem te zijn van ic-7/ is-7 mobo's.
http://forum.abit-usa.com...=is7%20sound&pagenumber=1
[ Voor 7% gewijzigd door TheGreatCornholio op 12-08-2003 01:54 ]
Hallo iedereen,
Graag hulp bij volgend probleem.
Ik heb een Abit-ic7 moederbord gekocht maar, als ik de stroom uitrek en terug insteek of, als ik een uitschuifbare harde schijf insteek of uitrek, kan ik de computer de eerste 20 keren niet meer opstarten.
Deze blijft steeds hangen bij Memory (Memory test). Ook de cpu wordt op dat moment verkeerd weergegeven 1.30 i.p.v. 2.80.
Na een keer of 20 terug proberen op te starten lukt het uiteindelijk.
Het is zeker niet plezierig om telkens ik een uitneembare harde schijf insteek of uithaal, ik een keer of 20 moet opstarten.
Weet iemand raad?
Alvast hartelijk dank voor jullie hulp.
Mvg
  • Tao
  • Laatst online: 27-10 16:08
Tao
DPC DE_KOMETEN
Verwijderd schreef op 16 september 2003 @ 22:40:
Ik heb een Abit-ic7 moederbord gekocht .... etc.
Dit topic gaat over de Abit IS7. Tiebvaud of een ander mobo?? (Gelet de datum is deze reply denk ik overbodig...)
Ik heb net een Abit IS7-E gekocht. Samen met een boxed P4 2.6Ghz (800 FSB versie). Verder 512 MB Twinmos PC3200 en een MX440 kaartje.
Out-of-the-box ingebouwd, gelijk met grof geschut de FSB op 250 gezet -> niet booten :( (jaja, ik weet het. Ben ook te gretig :) )
Tikkie terug, met VCore licht verhoogd op 1.575 en FSB weer op 250.
Voorlopig brand ik hem zo in. Temp cpu schommelt rond de 51 graden C.
Draait nu al een week stabiel 24/7 max gestressed (ingezet op UD).
Bios vind ik prima instelbaar met veel mogelijkheden.
Kortom: een prima en goedkoop bordje wat ook goed overklokbaar is.
Diablo3
