problemen met microsoftservers
  • Hbeez
  • Laatst online: 22-10-2025
Als ik bij MSN probeer in te loggen dan krijg ik de error dat mijn wachtwoord/loginnaam onjuist zijn. Met elke MSN-versie heb ik dit. De services zijn wel in orde volgens messenger.msn.nl.
als ik naar hotmail.com ga met IE, dan laad hij de website gewoon .. maar als ik probeer in te loggen staat er:
The page cannot be displayed
The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings.
Please try the following:
Click the Refresh button, or try again later.
If you typed the page address in the Address bar, make sure that it is spelled correctly.
To check your connection settings, click the Tools menu, and then click Internet Options. On the Connections tab, click Settings. The settings should match those provided by your local area network (LAN) administrator or Internet service provider (ISP).
If your Network Administrator has enabled it, Microsoft Windows can examine your network and automatically discover network connection settings.
If you would like Windows to try and discover them,
click Detect Network Settings
Some sites require 128-bit connection security. Click the Help menu and then click About Internet Explorer to determine what strength security you have installed.
If you are trying to reach a secure site, make sure your Security settings can support it. Click the Tools menu, and then click Internet Options. On the Advanced tab, scroll to the Security section and check settings for SSL 2.0, SSL 3.0, TLS 1.0, PCT 1.0.
Click the Back button to try another link.
Cannot find server or DNS Error
Internet Explorer
wat moet ik doen?! :(
met andere browsers kan ik m'n e-mail daar wel ophalen. ( me l/p kloppen dus ook )
[ Voor 3% gewijzigd door Hbeez op 18-07-2003 23:21 ]
  • momania
  • Laatst online: 09-09 17:26
momania
iPhone 30! Bam!
Komt we vaker voor dat de verschillende MSN/pasport services eruit liggen bij MS.
Zeker rond deze tijd, omdat dan heel amerika wakker is.
Neem je whisky mee, is het te weinig... *zucht*
  • Hbeez
het is al een paar weken zo :S
  • PipoDeClown
PipoDeClown
Izze Zimpell
op een andere compie msnen gaat wel goed?
heb je dan een proxy cq. vuurmuur oid. aan?
God weet alles, want hij is lid van de Mosad. To protect your freedom i will take that away from you. Mijn drankgebruik heeft ernstig te lijden onder mijn gezondheid.
  • Illegal_Alien
Illegal_Alien
PanzerAirlines.nl Rulezzzz
PipoDeClown schreef op 19 July 2003 @ 07:14:
Als je zonealarm hebt, zet deze dan op medium ipv high, dan doet windowsupdate het ook weer :)
Officieel AchtbaanFreak ©2004
  • Hbeez
Nee ik heb geen proxyy/vuurmuur ..
  • Illegal_Alien
Illegal_Alien
Son_Gohan schreef op 19 juli 2003 @ 12:39:
XP? Daar firewall aan? Je bent onduidelijk...
  • momania
momania
iPhone 30! Bam!
Son_Gohan schreef op 18 July 2003 @ 23:20:
Dan moet je het toch in IE zoeken.
Heb je wel de instructies uit die foutmelding opgevolgd?
  • Hbeez
Ik heb windows98. Geen firewall. En ik heb de instructies opgevolgd/de msn-faq gelezen maar het mocht niet baten.
  • Han
Han
Staat je datum/tijd wel goed op je PC? :)
  • Hbeez
XceeD heb je een scriptje die automatisch een reply doet met 'datum/tijd' zodra ik een topic post? o_0
Hij loopt een paar minuten achter.
Ik kan trouwens via IE nergens m'n e-mail ophalen .. :s
Cookies enabled? Security level op medium bij Internet Options? Dat soort dingen allemaal nagekeken?
  • Hbeez
Ja ik heb alles al weer op default gezet etc ..
