[beamer] iiyama LPX100 Projector
  • 134 views sinds 30-01-2008
  • ReseTTim
  • Laatst online: 19-08 16:11
ReseTTim
Chocolate addicted
Afbeeldingslocatie: http://www.mycom.nl/f2/images/dut/zomerstunt/monitor_liiyamabeamer.gif
Model LPX100 Projector
Weight 2.5 kg
Dimensions Height: 74 mm, widthfront: 260 mm, widthback: 210 mm
System Three primary colour, liquid crystal, shutter projection method
LCD 3 x 0.9 polysilicon TFT LCD panels
Number of pixels 3 x 786,432 (2,359,296 in total)
Resolution (VGA) True resolution of 1024 x 768, compressed display of 1600 x 1200
Aspect ratio 4:3
Projection lens F =2.3 -2.6,f =36 -43.2mm
Projection lamp 150W super high pressure mercury lamp
Brightness 1000 ANSI lumens
Contrast ratio 350:1
Uniformity 85% (TYP)
Power zoom ratio 1:1.2
Focus Adjustment Projection lens manual adjustment
Projection image size 25" – 252" diagonal
Projection distance 1.15m – 11.5m
Gate angle 9:1 (no keystoning distortion to the vertical screen)
Keystone correction +/-20 º
Menu controls Contrast, brightness, colour depth, auto sync, clock &phase, horizontal &vertical position, keystone, auto off, tint, colour, sharpness, save, load, volume, language selection, projection mode, video select
Computer input AUTO, PAL, M-PAL, N-PAL, PAL 60, NTSC3.58, NTSC4.43, SECAM
Video connector RCA jack, S-video
Video/audio input x 2 RCA jack
Composite audio input 3.5mm stereo mini jack
Audio 1 x 1W stereo
Scanning frequentie Horizontal:15-80kHz,vertical:50-70Hz
Voltage AC 90-132V, 50/60Hz
Power consumption 230W
Lamp life 1500hrs
Ergonomics Tilt adjustment 0-7 º
Accessories Remote control, power cable, user manual, lens cap, VGA cable, S terminal cable, video cable, RS-232C conversion cable, soft case for main body, lamp replacement (UMPRD 150NAA)
mijn vraag is nu wat vinden jullie van deze beamer? aanrader? mooie prijs voor die beamer?
Mijn profiel - Te koop: Overzicht van spullen..
waaro ? :P
Naar mijn mening is een beamer pas goed als hij bij vol daglicht een mooi helder beeld kan projecteren.
Zijn 1000 ANSI lumens daar genoeg voor? Volgens mij is voor huiskamer gebruik met geopende gordijnen dit toch echt te weinig. Denk dat je met 1500 ANSI lumens toch beter zit.
/EDIT:
Hij zal niet voor niets zo sterk afgeprijsd zijn. :X
[ Voor 11% gewijzigd door Verwijderd op 16-07-2003 00:17 ]
  • ReseTTim
ReseTTim
Chocolate addicted
ja maar ik zit dus op zolder en daar komt ie ook te hangen.. zeker met zonlicht hebt ik altijd 1 kant of 2 kanten de rolgordijn naar beneden.. dus is het aardig donker.. is ie dan nogsteeds te donker?
AR van 4:3, wat houd dat nou in...kan deze beamer niet 16:9 beamen ?
contrast 350:1 - is dit ook niet wat laag...
  • Dnc1n
  • Laatst online: 18-11-2025
volgensmij is 1000 best wel voldoende, met daglicht kun je bij iedere beamer nog wel fatsoenlijk kijken dus lijkt mij geen probleem. daglicht zie je het gewoon goed genoeg in het donker beter.
mediamarkt duitsland verkoopt btw ook een best betaalbare beamer:
http://shop.mediamarkt.de...reId=5000&categoryId=1020
1200 ansilumen
[ Voor 5% gewijzigd door Dnc1n op 16-07-2003 00:22 ]
  • ReseTTim
ReseTTim
Chocolate addicted
Verwijderd schreef op 16 July 2003 @ 00:19:
kan wel dat ie op 16:9 beamed alleen krijg je dan zoals een 4:3 tv..
en wat betreft contrast.. geen idee daarom vraag ik aan mensen die verstand ervan hebben of dit intressant is..
Dnc1n schreef op 16 juli 2003 @ 00:22:
1200 ansilumen
die is dus wel 400 euro duurder..
[ Voor 42% gewijzigd door ReseTTim op 16-07-2003 00:25 ]
  • ReseTTim
ReseTTim
Chocolate addicted
[url=][/url]
[ Voor 98% gewijzigd door ReseTTim op 16-07-2003 00:25 ]
  • Overspeed
  • Laatst online: 02:57
De afbeelding is gelinkt van www.mycom.nl, dus zal ie daaro wel te koop zijn... ;)
Er is in Nederland niets beter beveiligd dan de snelwegen m.b.v. mobiele flitsteams, flitspalen, (on)opvallende surveillance-auto's, etc. Als er in mijn huis wordt ingebroken, dan kan ik beter de A2 oprennen dan 112 bellen.
  • ReseTTim
ReseTTim
Chocolate addicted
maakt dat constrast wat uit eigenlijk waar iemand op wijst?
  • TwoR
  • Laatst online: 07-09 07:39
TwoR
Gekleurde stippen
1000 Lumen zijn zeker wel wat weinig ik heb er laatst 1 gekocht die kan op 2000 en 1600 lumen projecteren en 1600 is net genoeg bij daglicht maar dan moet je wel goede ogen hebben zeg maar. met 2000 lumen gaat het ook overdag wel goed. Ook de lamp is te zwak met 150 watt om overdag te beamen.
Ik denk niet dat ik deze zou kopen ook niet voor deze prijs. Je kan beter iets goeds kopen dan er straks spijt van hebben.
Zelf heb ik deze Klik Die bevalt echt mega goed alleen zit niet helemaal in dezelfde prijs categorie.
[ Voor 54% gewijzigd door TwoR op 16-07-2003 13:51 ]
Veel lumen zijn imo juist heel irritant als je dan weer in het donker een film wilt kijken. Dan wordt je bijna scheel van het licht, en daarom is dit ook echt wel genoeg.
handig topic:
Enige uitleg voor mensen die een projector willen kopen !
  • Elektronicanet
  • Laatst online: 10-08 16:26
Elektronicanet
Leds do it!
Verwijderd schreef op 16 July 2003 @ 13:56:
handig topic:
Volgens dat topic is 350:1 als contrast ratio dus wel heel weinig...
Nederlander in België
Ik denk dat je gewoon moet gaan kijken (als dat natuurlijk kan in de winkel waar ie zo goedkoop is) en daaruit zelf moet opmaken of het wat voor jou is. Want je kan wel allemaal dingen lezen over wat voor de een het minimum is enz, en wat die en die weer belangrijk vindt, maar misschien zijn die punten voor jou helemaal niet interessant oid.
Lichtopbrengst is dus echt wel voldoende, wie gaat er nou gezellig midden op de dag van een film genieten, dat doe je doorgaans toch 's avonds of in ieder geval als het wat donkerder is ;)
Een vriend van mij heeft een Philips met 800 lumen en die kun je met schemering prima hebben :)
  • pyravex
  • Laatst online: 15-03-2023
pyravex
wa jij bob,stoel moet er staan
heeft iemand ervaring met deze beamer??
als je dat topic leest wat hier eerder aangegeven word is de contrast ratio erg laag?
betekend dit dat deze beamer erg slecht is in zwart???
is dit echt zo erg en zou je door sparen voor een andere ?
of zeg je van ga voor deze aanbieding het is een goed apparaat?!
ik heb namelijk NU het geld er voor...
het ligt nu naast me
|we live in the history of a mad man Mr. G |
  • ReseTTim
ReseTTim
Chocolate addicted
pyravex schreef op 16 juli 2003 @ 16:45:
koop hem, test hem vertel je verhaaltje hier en als je niet tevreden bent breng hem binnen 8 dagen gewoon terug.. doet mycom niet moeilijk over..
  • pyravex
pyravex
krijg je dan je centen terug'??
  • ReseTTim
ReseTTim
Chocolate addicted
pyravex schreef op 16 July 2003 @ 17:04:
jups en anders vraag je aan de balie voor de zekerheid maar normaal doen ze niet moeilijk over.. heb laatst nog een ati r9500 terug gebracht.. zei dat ie niet snel genoeg was. zij vonden dat een reden dus kreeg me geld terug.. soms vragen ze niet eens waarom..
  • pyravex
pyravex
Ik heb um maar gewoon gekocht,
heb het idd nog even na gevraagt over geld terug en idd, binnen 7 dagen moet ie terug zijn en dan krijg je zonder vragen je geld terug..
ik zal ff een aantal pixels schieten van het apparaatje en een review schrijven.
sow als je er wat over wilt weten,,,, post het even dan verwerk ik het in de review...
owjah, voor de geintresseerde..
er zijn dr 32 nog op voorraad op het hoofdkantoor, de vestiging in utrecht is nu uitverkocht ;)
[ Voor 14% gewijzigd door pyravex op 16-07-2003 18:27 ]
Maak aub ook wat pics van het beeld wat ie produceert !! :)
  • pyravex
pyravex
ok, was mijn id ookal ;)
moet ff afwassen :( en dan aan de slag!!!! :7
  • OverSoft
  • Laatst online: 07-09 11:49
ik heb em nu ook, zag em vanochtend in de krant staan (als vervanging van mijn infocus lp730)
het beeld is erg mooi, lekker helder en goed zichtbaar in een kamer met 2 dakramen bij zonlicht.
er zit gelukkig ook een economy mode op en daar ben ik wel blij om, want op de volle sterkte is echt te fel voor savonds of met mijn verduisteringsgordijnen dicht
NL: 3x Victron Multiplus II 5000VA, 1x Victron SmartSolar MPPT RS 450/200, 50kWh (3x Yixiang v2 met EVE MB30's) | IT: Deye SUN-15K-SG01HP3-EU-AM2, Deye BOS-G50 Pro (51,2kWh HV)
  • PilatuS
er komt volgende maand in de PCM een test van beamers, misschien is het een goed idee om tot die test te wachten met kopen
  • OverSoft
zo, even wat foto's, maar mijn camera is nogal brak :|
Afbeeldingslocatie: http://members.chello.nl/~w.leemans/IM000142.JPG
Afbeeldingslocatie: http://members.chello.nl/~w.leemans/IM000143.JPG
Afbeeldingslocatie: http://members.chello.nl/~w.leemans/IM000144.JPG
Afbeeldingslocatie: http://members.chello.nl/~w.leemans/IM000145.JPG
Edit: Die puntjes zijn trouwens geen dooie pixels, maar schroefgaten :|
[ Voor 12% gewijzigd door OverSoft op 16-07-2003 20:18 ]
PilatuSSS schreef op 16 July 2003 @ 20:05:
dat is geen goed idee want de actie is dan voorbij
[ Voor 11% gewijzigd door Verwijderd op 16-07-2003 20:24 ]
  • Novah
  • Laatst online: 30-08 10:47
De prijs is voor mij altijd het stopbordje geweest om een beamer aan te chaffen. Ik ben zelf een grote filmfan dus een beamer zijn zeker goed van pas komen. Maar waar ik erg benieuwd naar ben is het geluid wat hij produceert. Misschien kan oversoft daar wat over vertellen.
geluid :?
Maar dat is toch totaal niet interessant ? Meestal zit op beamers 2x1 watt (hier zelfs 1x1 watt :{) ofzo, daar hoef je geen donder van te verwachten... geluid haal je doorgaans toch uit je receiver ? Hoe en waar enzo wil je die beamer dan gaan gebruiken Novah ?
[ Voor 6% gewijzigd door Verwijderd op 16-07-2003 21:05 ]
Ik denk dat novah het lawaai van de beamer bedoelt. en niet het geluid uit de speakers, want dat is vaak niet al te best.
  • DaRKie
  • Laatst online: 20-08 15:40
Verwijderd schreef op 16 July 2003 @ 21:04:
geluid :?
misschien bedoelt hij de lawaai productie van het toestel
  • pyravex
pyravex
Ok mijn bevindingen hier...
de beamer ziet er mooi uit lekker klein...
de verpakking was ook goed uitgedacht (zie foto's hieronder)
Beeld
erg scherp en mooi
ik projecteer nu rechtstreeks op een witte muur
die beschilderd is met structuur verf (van die korreltjes da als je je hand er langs schuurt dat ie meteen open ligt...
alleen ik erger me nu al aan de lage contrast ratio..
het zwart is meer licht grijs.....
ik zal het nog eens een keertje testen morgen als ik m'n dia scherm heb neer gezet
maar gok dat het niet veel uit maakt helaas...
ook heb ik er eentje met een dode pixel
wat mijn (toch al niet te hoge) mening over iiyama niet te goeden doet :)
het geluid wat hij maakt is na mijn mening te veel en storend tijdens het film kijken.
ik denk er over om me geld weer terug te halen en de beamer in te leveren
dan maar extra geld uitgeven via pc prive ofzo...
ik zal ff pixels plaatsen
AARRGGG
hoe de fuk doe je pixels posten???
heb het wel geweten (doe t nie zo vaak ;) )
ze zijn iig te vinden op
http://www.xs4all.nl/~dvc/beamer
[ Voor 18% gewijzigd door pyravex op 16-07-2003 22:04 ]
Ah, dat geluid ;)
Hm jammer dat het contrast tegenvalt. En ook dat het geluidsniveau te hoog is... ik zat er ook over te denken om 'm te halen.
  • pyravex
pyravex
Verwijderd schreef op 16 July 2003 @ 21:59:
Ah, dat geluid ;)
tjah...
beetje een tegenvaller vond ik..
bekijk de pixels die ik heb geplaatst op www.xs4all.nl/~dvc/beamer/
en oordeel zelf...
het geluid was goed hoorbaar terwijl ik gewoon muziek aan t spelen was
en dat stond nou niet echt hard maar ook nie zacht...
(als iemand ze ff hier wil dumpen... graag :))
  • OverSoft
gelukkig zit er op deze beamer een economy mode wat ERG veel scheelt qua geluid, aangezien er nog wel ontzettend veel licht uit komt op economy mode is dit perfect.
Scheelt ook nog eens lamptijd :D
Alleen of het veilig is om em bij deze temperaturen aan te zetten... de lucht die eruit komt is meer dan warm... je verbrand bijna je fikken er aan!
Geluidsniveau is ontzettend acceptabel op economy mode, op normal mode is het wat lawaaierig maar nog niet erg.
Ik heb trouwens lekker geen dooie pixel :D :D
[ Voor 7% gewijzigd door OverSoft op 16-07-2003 22:06 ]
  • pyravex
pyravex
:P
alleen al voor die dooie pixel gaat ie terug... die verscheen na 10 min dat ie aanstond (vind ik niet acceptabel......)
zie de foto's
bij de quake beelden issie er nie..
bij de dvd pixswel :)
ik zal de economie mode nog een keer proberen om te kijken of het geluid dan wel acceptabel is..
de lucht die dr uit komt is idd fucking heet!!
ik ga morgen maar verder denk ik :(
tis hier 33 graden en de handlung zegt dat ie tot 35 mag...
met de helderheid zit het wel goed na mijn idee.
als je de quake foto ziet dan zie je de kamer maximaal verlicht en er scheen nog licht door m'n ramen :)
[ Voor 16% gewijzigd door pyravex op 16-07-2003 22:14 ]
  • e-boy
  • Laatst online: 14-11-2025
e-boy
en ooit komt hier iets nuttig!
Zou iemand misschien eens een paar shots kunnen tonen
terwijl hij de nokia screen-test draait? (http://crew.tweakers.net/FAQ/VB/nokia1a.zip)
Heb hier momenteel een geleende projector staan
(SUPER oud en GROOT |:( :+ )
Dan kunnen we allemaal daar even ff mee vergelijken.
Ik ben dan vooral geinteresseerd in de resolutie-test
(of wat het dan ook is, de test met de horizontale en verticale lijnen)
en de eerste test waar je nogal duidelijk een beeld hebt van hoe zwart
het zwart is.
Alvast bedankt
[ Voor 5% gewijzigd door e-boy op 16-07-2003 22:47 ]
  • pyravex
pyravex
waar kan je die d/l?
dan zal ik um ff draaien..
  • OverSoft
zie V&B faq bij hoe kan ik mijn monitor testen
ziet er goed uit moet ik zeggen, geen moire, geen convergentie fouten, geen problemen :)
ik ben er tevreden mee iig, die van mij blijft mooi hier staan
  • pyravex
pyravex
ok,
ik kijk er morgen nog wel naa, ben nu moe, en moe morgen weer vroeg om om eerder naar huus te kenne.... :P
  • ReseTTim
ReseTTim
Chocolate addicted
Afbeeldingslocatie: http://www.xs4all.nl/~dvc/beamer/Q3.jpg
Q3
Afbeeldingslocatie: http://www.xs4all.nl/~dvc/beamer/Q3_met_licht.jpg
Q3 met licht
Afbeeldingslocatie: http://www.xs4all.nl/~dvc/beamer/desktop_win2k.jpg
dekstop w2k
Afbeeldingslocatie: http://www.xs4all.nl/~dvc/beamer/dode_pixel.jpg
dode pixel
Afbeeldingslocatie: http://www.xs4all.nl/~dvc/beamer/dodepixel.jpg
Afbeeldingslocatie: http://www.xs4all.nl/~dvc/beamer/inhoud_doos.jpg
doos inhoud
Afbeeldingslocatie: http://www.xs4all.nl/~dvc/beamer/neo_slaapt_beeld.jpg
wake up neo..
foto's gemaakt door pyravex
  • ReseTTim
ReseTTim
Chocolate addicted
pyravex kan je nog wat meer vertellen over de beamer?
  • pyravex
pyravex
Wat wil je precies weten.
k ga hem nu weer aansluiten
is gelukkig koeler als gister avond (33 graden)
nu zal de beamer wel wat stiller zijn.
ik ga hem zo op eco mode zetten om te kijken of dat ook weer scheeld.
ik zal ook nog wat detail foto's maken van de beamer..
  • ReseTTim
ReseTTim
Chocolate addicted
heb net me 63cm tv binnen.. dus in mijn geval is de xtra info niet echt noodzakelijk maar ik denk wel leuk :)
kan je ook nog een mooie detail foto maken van de beamer en de ingangen zelf?
  • pyravex
pyravex
is goed..
komt r aan :)
Welke tv heb je gekocht? (pix ;) )
ik heb een Philips van 72cm
[ Voor 62% gewijzigd door pyravex op 17-07-2003 21:21 ]
  • ReseTTim
ReseTTim
Chocolate addicted
KV-25FX30B
Entry level 25-inch (59cmv) FD Trinitron WEGA
http://www.sony.nl/view.x...&cat=12628&tech&loc=en_NL
sony dus :P hij is dus plat van voren en diep van achteren.. net uit de doos :)
  • Dnc1n
zullen de prijzen van beamers niet verder gaan dalen omdat de vraag steeds groter wordt.
veel mensen hebben een behoorlijke HT en je ziet een aantal mensen met een beamer in de woonkamer en een scherm. ik vindt beamer nog best duur voor wat je ervoor krijgt. wat kost zo'n beamer nou eenmaal om te produceren, weinig toch? :?
wat denken jullie gaan de prijzen dalen van beamers?
  • OverSoft
nou, een productie van een beamer is vrij duur hoor, de tftjes (die zijn het duurst), de prisma, lenzen, electronica, dat is niet zomaar een $25 job...
bij beamers is het hetzelfde als printers
op de beamer verdienen ze weinig tot niets
lampen daarentegen zijn bijna pure winst
prijzen gaan voorlopig nog wel niet dalen, en 1000 euro is absoluut niet duur
  • pyravex
pyravex
sorry dat ik nog geen pix heb geplaatst
heb mijn beamer terug gebracht en heb nu net gister een nieuwe gekregen
zal vanavodn ff pix maken
  • ken
  • Laatst online: 06-09 07:52
ken
actie is afgelopen :( zie het in ieder geval niet meer op de site staan
Canon 5D Mark II, Canon 35 f/1.4L
ken schreef op 05 August 2003 @ 01:59:
ja was een actie van een week.... maar om nou dit topic ervoor omhoog te gooien :?
  • ernst
  • Laatst online: 04-08 16:43
(topic vluchtig doorgebladerd)
Ik zag zo snel nergens staan wat je er nou precies mee wilt, voor gamen is dit wel aardig, maar als je er veel films op wil kijken is het ontbreken van 16:9 wel een groot gemis.
In dat geval moet je een kijken naar de Sanyo Z1, te koop vanaf ong E 1500.
Verder kan ik je aanraden om dit topic naar A/V te verplaatsen als je een HT beamer wilt. Vergeet niet ook even hier te kijken Enige uitleg voor mensen die een projector willen kopen !
(edit: grmbl ga je eigen pjoeter schoppen ipv ouwe koe topics :( :| )
[ Voor 7% gewijzigd door ernst op 05-08-2003 12:56 ]
Every day is a start of something new, and every evening ends with the splendid dawn of a new day
