Balen dat het niet werkte... Maar ik ben weer effe verder wezen zoeken:
In the case of an incomplete JetSuite Pro for Hewlett-Packard software installation, the x:\Windows\Jetsuite.ini file might have been written (where "x" is the letter indicating the drive on which Windows is installed).
This file must be removed before attempting another installation. First, try to uninstall the file using the Uninstall program. If that fails to the remove the file, manually remove it by using Windows Explorer.
Attempting to install the JetSuite Pro software when this file exists might cause an error message stating, "An Unknown System Exists. Remove before installing JetSuite."
Dus je kan het weer effe proberen
, zal nog effe verder zoeken, suc6 maar weer
(komt overigens dat laatste zinnetje niet erg overeen met jouw porbleem?
Nog wat gevonden
>>>>>Delete the following icons from the printer's window menu: <<<<<
Product name
JetSuite document Capture
JetSuite Fax
>>>>>Delete the following icon from your desktop:<<<<<
Shortcut (ICON) Title
Command Line
HP JetSuite Pro for the product
C:\Jetsuite\Jetsuite.exe
Delete the product JetSuite Pro group icon from the C:\Winnt\Profiles\All Users\Start Menu\Programs\product JetSuite Pro. This will delete the following shortcut icons:
Command Line
Product Status
C:\Jetsuite\Jetstat.exe
JetSuite Pro Desktop
JetSuite Pro Read Me
C:\Jetsuite\readmehp.txt
JetSuite Setup
C:\Jetsuite\Setup\Setup.exe
JetSuite Uninstall
C:\Jetsuite\Setup\Setup.exe uninstall
JetSuite Version Checker
C:\Jetsuite\Jsinfo.exe
PC Fax QuickNote
C:\Jetsuite\Jspbook.exe
ReadIris OCR
C:\Jetsuite\Iris\Read IRIS.exe
>>>>>Delete the following files:<<<<<
Folder
File Name
Description
C:\Winnt
Jetsuite.ini
JetSuite Pro installation log file
C:\Winnt\System32
Jetres32.dll
JetSuite resource program
Jetres16.dll
Resource program
C:\Winnt\System32\Drivers
Jsdbg.sys
Js1284.sys
Jsscan.sys
Jsmux.sys
Jsfax.sys
Jspclcap.sys
C:\Winnt\System32\Spool\Drivers\W32x86
Hp3100dv.dll
Hp3100ui.dll
Jsddrvkm.dll
Jsddrvum.dll
Jsfax.dll
C:\Winnt\System32\Spool\Drivers\W32x86\2
Hp3100dv.dll
Hp3100ui.dll
Jsddrvkm.dll
Jsddrvum.dll
Jsfax.dll
C:\Winnt\Profiles\All Users\Desktop
JetSuite Pro for HP LaserJet 3100.ink
C:\Winnt\Profiles\All Users\Start Menu\Programs\Startup
Hplase~1.ini
HP LaserJet 3100 Status.Ink
PC Fax QuickNote.Ink
JetSuite Pro Read Me.ink
HP LaserJet 3100 Status.ink
JetSuite Setup.ink
JetSuite Uninstall.ink
JetSuite Version Checker.ink
C:\Winnt\Profiles\All Users\Start Menu\Programs\product JetSuite Pro\Readiris
ReadIris OCR.ini
ReadIris Registration.ink
ReadIris User's Manual.ink
C:\Winnt\Twain_32
Jstwain.ds
JetSuite Pro Scanner Data Source
C:\Jetsuite
Delete entire directory to include all files
>>>>>Delete the following files from the Win.ini folder:<<<<<
NOTE: Delete entries only, do not delete headings in brackets [ ]
Location
Changes Made
Win.ini
Default Source=C:\WINNT\twain_32\jstwain.ds
[READIRIS]
Menu=1
Language=1
exe-path=C:\jetsuite\iris
iris-path=C:\jetsuite\iris
Toolbar=1
Scanner32=TWAINDSC,1
Scanner=TWAINDSC,1
FORMATTEXT=RTF
SN=43110797
[IOCR]
exename=READIRIS
fullname=READIRIS
Tis wel een lijstje zeg..
Voor 74% gewijzigd door
the_RJ op 18-07-2003 08:25
