MicroPhone help
  • 46 views sinds 30-01-2008
Need Help With my microphone please . it will work on a different computer but not mine , it wont work in sound recorder , and so on , it is unmuted for sure ( running windows xp ). p.s English please
  • Super_ik
  • Laatst online: 19:22
Super_ik
haklust!
is it in the right hole?
engels, doe normaal man, nl is hier al moeilijk genoeg :P
8<------------------------------------------------------------------------------------
Als ik zo door ga haal ik m'n dood niet. | ik hou van goeie muziek
yes it is
  • m-m
m-m
Sorry, but this is a Dutch computer forum therefore the spoken language here is dutch. If you don't speak it, please post your problem elswhere. If you do speak Dutch, spreek t dan ook gewoon ;)
Have you checked whether the Microphone is selected in "Recording Mode" of the volume control application? (Volume Control -> Properties -> "Adjust volume for (*) Recording" :) ) Then your volume control is in recording mode and you can select the microphone.
[ Voor 21% gewijzigd door m-m op 07-07-2003 19:13 ]
no i haven't
yes it is , just checked
  • m-m
m-m
And the volume in recording mode is not low?
[ Voor 166% gewijzigd door m-m op 07-07-2003 19:15 ]
it is full
and no , it still doesn't work
  • Juicy
  • Laatst online: 14:55
juicy if your so good :) fix it then - go on :P
[ Voor 3% gewijzigd door Verwijderd op 07-07-2003 19:20 ]
  • Stropdas
  • Laatst online: 05-10 14:46
Stropdas
Insert subtitle here
You can edit your message when you want to say something justy after another message. It looks so strange if you have a few short things in diffrent posts beneath eachother
Honda VFR800fi '99 | Volvo S60 '04
  • caspergt
  • Laatst online: 21-04-2025
Come on dude this forum is for people who speak the Dutch Language.
But i will help you because im in a good mood :9 :P
You`ll have to unmute all the sources at the volume control, pump the volume up at the port you put your microphone in.
And it should be working, if it doesn`t work, install new drivers of your soundcard and that will fix your problem i think.
But how the heck did you register to this forum when it is all dutch ! ??? :P
Ridiculer lvl70 Resto drood :D
  • Caerbannog
  • Laatst online: 31-12-2024
Caerbannog
Let's make better things.
yeah how :P
offtopic: (sorry.... had ik bijna in 't duits gereageerd)
What kind of soundcard are you using? You might have destroyed your mic-input on your soundcard (and yes, it IS possible.....)
Dutch:
Wat voor geluidskaart heb je eigenlijk? Misschien heb je wel gewoon de microfoon ingang op je kaart vernacheld. (en ja, dat IS mogelijk.....)
  • JvS
  • Laatst online: 20:22
JvS
Ik heb hem zelf ook
I'm sorry, but we are a dutch forum. There some more topics with tips but they won't help you, because they're in dutch.
