MySQL++ geeft errors!
  • 53 views sinds 30-01-2008
Ik heb dus net op VC++ 6.0, MySQL++ geinstalleerd
nu wanneer ik alleen al de examples probeer te compilen, geeft hij deze errors en warnings:
--------------------Configuration: examples - Win32 Release--------------------
Compiling...
simple1.cpp
../include\convert1.hh(40) : warning C4273: 'strtol' : inconsistent dll linkage. dllexport assumed.
../include\convert1.hh(41) : warning C4273: 'strtoul' : inconsistent dll linkage. dllexport assumed.
../include\convert1.hh(63) : error C2061: syntax error : identifier 'longlong'
../include\convert1.hh(64) : error C2061: syntax error : identifier 'longlong'
../include\convert1.hh(65) : error C2146: syntax error : missing ';' before identifier 'strtoll'
../include\convert1.hh(65) : fatal error C1004: unexpected end of file found
Error executing cl.exe.
examples.exe - 4 error(s), 2 warning(s)
ik heb op google en hier gezocht, maar daar blijken mensen alleen warnings te krijgen, maar het programma blijkt wel te werken. Dat is bij mij niet het geval.
Dit is de code van het voorbeeld:
C++:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
#include <iostream>
#include <iomanip>
#include <sqlplus.hh>
int main() {
  Connection con("mysql_cpp_data");
  // The full format for the Connection constructor is
  // Connection(cchar *db, cchar *host="",
  //            cchar *user="", cchar *passwd="")
  // You may need to specify some of them if the database is not on
  // the local machine or you database username is not the same as your
  // login name, etc..
  Query query = con.query();
  // This creates a query object that is bound to con.
  query << "select * from stock";
  // You can write to the query object like you would any other ostrem
  Result res = query.store();
  // Query::store() executes the query and returns the results
  cout << "Query: " << query.preview() << endl;
  // Query::preview() simply returns a string with the current query
  // string in it.
  cout << "Records Found: " << res.size() << endl << endl;
  Row row;
  cout.setf(ios::left);
  cout << setw(17) << "Item"
       << setw(4)  << "Num"
       << setw(7)  << "Weight"
       << setw(7)  << "Price"
       << "Date" << endl
       << endl;
  Result::iterator i;
  // The Result class has a read-only Random Access Iterator
  for (i = res.begin(); i != res.end(); i++) {
    row = *i;
    cout << setw(17) << row[0]
         << setw(4)  << row[1]
         << setw(7)  << row["weight"]
      // you can use either the index number or column name when
      // retrieving the colume data as demonstrated above.
         << setw(7)  << row[3]
         << row[4] << endl;
  return 0;
en dit is de code van convert1.hh: de file die de errors gaf:
C++:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
#ifndef __convert1_hh__
#define __convert1_hh__
using namespace std ;
#include <stdlib.h>
#include "defs.h"
template <class Type> class mysql_convert;
#define mysql__convert(TYPE, FUNC) \
  template <> \
  class mysql_convert<TYPE> { \
  private:\
    TYPE num;\
  public:\
    mysql_convert(const char* str, const char *& end) { \
      num = FUNC(str, const_cast<char **>(&end));}\
    operator TYPE () {return num;}\
//extern double strtod (const char *, char **);
mysql__convert(float, strtod);
mysql__convert(double, strtod);
#undef mysql__convert
  template <> \
  class mysql_convert<TYPE> {\
  private:\
    TYPE num;\
  public:\
      num = FUNC(str, const_cast<char **>(&end),10);}\
extern long strtol(const char *str, char **ptr, int base);
extern unsigned long strtoul(const char *str, char **ptr, int base);
mysql__convert(char, strtol);
mysql__convert(signed char, strtol);
mysql__convert(int, strtol);
mysql__convert(short int, strtol);
mysql__convert(long int, strtol);
mysql__convert(unsigned char, strtoul);
mysql__convert(unsigned int, strtoul);
mysql__convert(unsigned short int, strtoul);
mysql__convert(unsigned long int, strtoul);
#ifndef NO_LONG_LONGS
#ifdef strtoull
#undef strtoull
#endif
#ifdef strtoll
#undef strtoll
#endif
extern "C" {
extern char *longlong2str(longlong val,char *dst,int radix);
extern char *longlong10_to_str(longlong val,char *dst,int radix);
extern longlong strtoll(const char *nptr,char **endptr,int base);
extern ulonglong strtoull(const char *nptr,char **endptr,int base);
mysql__convert(longlong, strtoll);
mysql__convert(ulonglong, strtoull);
#endif
#endif
Iemand een idee wat het kan zijn?
bvd
Wouter
[ Voor 94% gewijzigd door Verwijderd op 07-07-2003 11:48 ]
niemand?
  • curry684
  • Laatst online: 13-08 16:46
curry684
left part of the evil twins
Ga even Welkom in P&W: FAQ en Beleid *updated: 05-07* lezen terwijl ik wat meer typ.
Professionele website nodig?
  • whoami
  • Laatst online: 21-08 22:54
Hoi.
Schoppen doe je pas na 24 uur. Jouw topic is niet belangrijker dan dat van iemand anders.
Verder wil ik je ook eens op de P&W FAQ wijzen. Je hoeft niet al jouw code te posten, enkel wat relevante code is voldoende. Zoals het nu is, bevordert het de leesbaarheid niet echt, en zouden sommige mensen wel eens kunnen beslissen om jouw topic niet verder te lezen, gewoon omdat er te veel code is.
https://fgheysels.github.io/
  • curry684
curry684
• Dit is niet het MySQL support forum. MySQL levert diverse mailinglists voor support.
• Wij zijn niet jouw persoonlijke debugafdeling. Doe zelf eens wat proberen te elimineren.
• Er staat geen 'taal' prefix voor je topictitle, en uitroeptekens zijn ook storend.
• Google eens gericht naar die errors die je krijgt en wees verbaasd.
• Kicken binnen 24 uur is niet toegestaan, en binnen 20 minuten ronduit asociaal.
