[Norman]Nvcoas.exe soms 50+ CPU belasting?
Hier op een 1,4Ghz Celeron, 256MB RAM en WinXP Pro is Norman Anti-Virus 5 geinstalleerd.
Nou heb ik uit mijn eigen profiel alles van norman uit de opstart gehaald (msconfig), maar in processes vind ik nog terug:
- Nvcoas.exe
- Nvcsched.exe
- Njeeves.exe
allen onder gebruikersnaam SYSTEM.
Op google vind ik oa. deze link:
http://www.thinkware.se/cgi-bin/thinki.cgi/AntiVirusPrograms met dit:
1.17 Norman Virus ControlTested during March - April 2002. Trial at http://www.norman.no/trialversions.shtml
No infections, no crashes, no performance impact noticed. Fairly recent updates. The best system I've tested so far.
UPDATE: It seems nothing good lasts...
I found an offer to try Norman Virus Control 5 for five months. It didn't work out so well. It locked up my computer completely as soon as I left it idle for some time, and sometimes while I was working with it.
I search web and docs for solutions, and did what I could. Eventually, I posted the following message on their support page on the web...
Subject: 100% CPU for nvcoas.exe in Win 2000.
I have severe problems with my NVC 5 installation on Win 2000.
If I leave the PC idle for an hour or so, nvcoas.exe will take all available CPU capacity, and I see no other solution than to cycle the power. I can often switch programs with Alt-Tab, but the programs are unresponsive, and after a while I can't even move the cursor on the screen.
Similar lockups sometimes happen as I work.
Previously, I had my email (Eudora, with thousands of mail in about 45 mailboxes (two files each) in all maybe 50 MB) on a SAMBA server, and then I had to restart SAMBA now and then as the disk was constantly spinning and the server was unresponsive. Now, since I moved my email to the local machine, the problems described above appear.
I have no 2506 errors in the event log. Besides not scanning network drives, I've explicitly put the network mounted drive letter (H:\) in the exclude list.
I've applied the Zandafix.zip. No change.
I use "scan new or changed", not "scan before use". I also unticked scanning with heuristic methods, and for aggressive marketing and security risks to make life easier for the on-access scanner. All three values are ticked in "exclude from scanning".
Several weeks have passed, but I've heard nothing from them.
Also on the down side, you have to download a seperate 'uninstall' program to remove it. I found this after about 20 minutes of searching their site. Why not just include it in the install? Sgt. Banjo Dec 2002
Het is geloof ik een bekend probleem, maar in dit stuk wordt niet direct een oplossing geboden. Meer mensen bekend met dit probleem :?
