[win2kS]Network Load Balancing niet te vinden?
  • ThaHandy
  • Laatst online: 05-09 12:13
ThaHandy
Discovery Channel
hey,
vanuit help van win2k server:
To install Network Load Balancing if it was previously uninstalled
• Open Network and Dial-up Connections.
Caution
In order to avoid networking problems, follow these steps in the exact order shown.
• Right-click the Local Area Connection on which Network Load Balancing is to be installed, and click Properties. The Local Area Connection Properties dialog box appears.
• Click Install. The Select Network Component Type dialog box appears.
• Click Service, and then click Add. The Select Network Service dialog box appears.
• Click Network Load Balancing, and then click OK. After Network Load Balancing installs, you return automatically to the Local Area Connection Properties dialog box. :?
Afbeeldingslocatie: http://members.home.nl/thahandy/t2/got/loadb.jpg
waar dan?
@ windows setup kan ik em ook niet meer vinden
[ Voor 10% gewijzigd door ThaHandy op 07-09-2015 00:47 ]
  • Predator
  • Laatst online: 07:59
Predator
Suffers from split brain
Network Load Balancing zit enkel bij Windows 2000 Advanced Server en jij hebt misschien Windows 2000 Server ?
[ Voor 16% gewijzigd door Predator op 01-07-2003 21:35 ]
Everybody lies | BFD rocks ! | PC-specs
  • ThaHandy
ThaHandy
Discovery Channel
win2k server ja
ik had die optie voorheen wel maar toen uninstalled, en nu heb ik et nodig :|
