Water-cooling voor Notebooks
  • 52 views sinds 30-01-2008
  • Longbeard
  • Laatst online: 14:07
Longbeard
Back in Black, hobby beëindigd
NEC Develops World's First Water-Cooling Module with Piezoelectric Pump for Notebook PC
NEC Corporation today announced the development of the world's first slim sized water-cooling module for notebook personal computers that employs a piezoelectric pump driving method. This water cooling-module enables a highly advanced, slim sized, notebook PC with minimal operating noise.
The water-cooling module uses a piezoelectric pump to drive the cooling liquid. This newly structured water-cooling module is developed by integrating the pump and the tank with the aluminum radiation plate that contains the water circulation channel.
Main features of NEC's water-cooling module
(1) Through optimized design of the radiation plate and the ingenuity of the coolant passage configuration below the CPU attached area, a cooling performance of 80W (2 times that of conventional systems) is realized. Moreover, the optimized piezoelectric pump structure suppresses the operating noise up to the whisper level of about 30dB, in turn enabling highly efficient water-cooling performance.
(2) By development of a piezoelectric pump with higher water pressure and slimmer size (thickness 5mm), the thickness of the aluminum radiation plate that contains the water circulation channel is reduced to within 3 mm. The increase in the thickness of the chassis is reduced to 4mm, half that of conventional water-cooling methods.
(3) By integrating the aluminum radiation plate, the tank and the piezoelectric pump, ease of installation in personal computers and long-term reliability is achieved.
(4) Hermetical sealing is improved through the use of materials with little liquid permeability. In turn the size of the cooling liquid tank is reduced by 9/10 compared to conventional tanks.
Features of the conventional water-cooling system
(1) Water pressure of the electromagnetic centrifugal pump is relatively weak. If the thickness of the circulation channel is decreased, cooling-liquid flow is restricted.
(2) The system is difficult to install as the tank, pump and CPU attached area are all inter-connected to a metal pipe and a rubber tube.
(3) Installation of a large tank is necessary as cooling liquid seeps through the resin parts of the tank, pump and the connection tubes resulting in liquid reduction over time.
The water-cooling module developed by NEC is the slimmest model in the world. When installed in a notebook personal computer increase in thickness is minimized. In order to drive a conventional piezoelectric pump alternating voltage of 100V is necessary. However, with NEC's water-cooling module system the pump can be driven with 5V of direct voltage. As a result it is easy to install in all IT equipment. This product is suitable not only for use in notebook PCs, but also in servers and desktop computers. It is expected that it will be positioned as a core technology for spreading the water-cooling system in IT equipment and that it will be used as an alternative to the conventional water-cooling heat sink and heat pipe.
NEC Personal Products, Ltd. plans to commercially produce the water-cooling module within two years. NEC aims to create a de-facto industry standard and will actively work towards licensing supply of its module technology to parties outside the NEC Group.
Leek mij als water-coolings leek wel interessant voor /51 :)
  • Brede P
  • Laatst online: 08-01 14:43
Het klinkt erg geinig, ben benieuwd wanneer we de eerste resultaten van tests kunnen aanschouwen. En dan bedoel ik natuurlijk tests van onafhankelijke sites, ala Toms Hardware, Extreme-OC etc.
Dit is |:(
Die mensen snappen duidelijk niet wat waterkoeling betekent. Lees de WC faq eens en de links naar mijn posts die daarin staan.
Het water is alleen maar een manier van energietransport naar een koeler met groter oppervlakte (de radiator)
In kleine ruimtes heb je daar iets ideaals voor wat al jaren gebruikt wordt in bijvoorbeeld notebooks: Heatpipes
Ook is een alu rad dan dom aangezien in alle nieuwe laptops al een koperen grill gebruikt wordt om ruimte te besparen.
[ Voor 14% gewijzigd door Verwijderd op 30-06-2003 12:13 ]
  • Meneer aard
  • Laatst online: 17:28
Meneer aard
Porsche rulez!
Waarom :?
Je hebt een laptop om ergens mee naar toe te nemen (werk, school).
Als je nou naar school moet in de trein en je hebt een laptop ook voor school nodig dan gebruik je `m ook in de trein (mocht het lang duren).
Je gaat toch helemaal geen extra troep mee nemen voor die waterkoeling :? .
Dit is gewoon 8)7
Of hebben ze nog niet genoeg aan hun fully modified pc met waterkoeling :? .
Volgens mij is dit gewoon zwaar ;( .
Als de wereld vergaat; Ja dan zijn alle mussen dood:+
als het een kleine onzichtbare interne ingreep betekend is het wel ok naar mijn idee!!
maarja als jet zelfde kan berijken met heatpipes... whats the point?
Heeft dit nut.
ik denk zelf niet groot resevoir ivm warmte transport en een radiator nodig. extra kilo's
ik zie hier niet echt het voordeel van
[zie ook meneer aard]
[ Voor 11% gewijzigd door Verwijderd op 30-06-2003 16:22 ]
Mooi is dat, je zegt iets. Alle kindjes komen uit school om 4 uur (nofi :) ) en zeggen vervolgens precies hetzelfde.
Over gewicht hoef je je geen zorgen te maken, dat kleine beetje water dat erin zit weegt echt niet zoveel, maar het is wel altijd zwaarder als een heatpipe. Maar dus geen kilo's zoals mensen hier beweren. En een reservoir is helemaal niet nodig bij WC.
Net als die brandstofcel accu, 900 gram. Maar dan wel 40 uur aan de gang. 1 nadeel is wel dat je dan weer moet vullen ipv gewoon ff inpluggen. Ik hoop dat de brandstof dan niet te duur wordt, want stroom is toch wel redelijk goedkoop.
Meneer aard, Xavyer en PreaTorian, het is klein en compact. Aan de buitenkant zie je dus niets anders als normaal en het weegt ook geen ruk. Het is alleen |:( omdat heatpipes veel beter en makkelijker zijn.
[ Voor 35% gewijzigd door Verwijderd op 30-06-2003 18:42 ]
  • Bob Popcorn
  • Laatst online: 16:19
Bob Popcorn
Plop!
Verwijderd schreef op 30 juni 2003 @ 18:39:
Ach meneer zit op zn luie reet op maandagochtend een beetje interessant te doen (nofi)
Naar mijn inzien lijkt waterkoeling in een laptop helemaal niets. Ik heb niet zoveel ervaring met laptops maar worden ze echt te heet dan met luchtkoeling?
Kan niet stoppen met ontploffen!
  • Remy
  • Laatst online: 30-09 09:31
Remy
I usually get 100% accuracy
Deze gaat dicht, omdat dit verder geen belangrijk nieuwsitem (op dit moment) is. Pas als waterkoeling @ notebooks aan slaat (dat zien we dan wel weer) zijn er interessante topics over te openen. Jammer genoeg geldt wederom dat sommige users hier niet het begrip 'forumgedrag' niet kennen. Respecteer je mede-users, flames of vergelijkbare zinnen zijn niet gewenst :/
LinkedIn
Instagram
