[busybox] fout met make (uClibc)
i386-uclibc-ar -r libbb.a libbb/full_version.o libbb/name_too_long.o libbb/omitting_directory.o libbb/not_a_directory.o libbb/memory_exhausted.o libbb/invalid_date.o libbb/invalid_option.o libbb/io_error.o libbb/dash_dash_help.o libbb/write_error.o libbb/too_few_args.o libbb/name_longer_than_foo.o libbb/unknown.o libbb/can_not_create_raw_socket.o libbb/archive_offset.o libbb/seek_sub_file.o libbb/extract_archive.o libbb/unarchive.o libbb/get_header_ar.o libbb/get_header_cpio.o libbb/get_header_tar.o libbb/deb_extract.o libbb/ask_confirmation.o libbb/chomp.o libbb/concat_path_file.o libbb/copy_file.o libbb/copy_file_chunk.o libbb/libc5.o libbb/device_open.o libbb/error_msg.o libbb/inode_hash.o libbb/error_msg_and_die.o libbb/fgets_str.o libbb/find_mount_point.o libbb/find_pid_by_name.o libbb/find_root_device.o libbb/full_read.o libbb/full_write.o libbb/get_console.o libbb/get_last_path_component.o libbb/get_line_from_file.o libbb/gz_open.o libbb/human_readable.o libbb/isdirectory.o libbb/kernel_version.o libbb/loop.o libbb/mode_string.o libbb/module_syscalls.o libbb/mtab.o libbb/mtab_file.o libbb/my_getgrnam.o libbb/my_getgrgid.o libbb/my_getpwnam.o libbb/my_getpwnamegid.o libbb/my_getpwuid.o libbb/parse_mode.o libbb/parse_number.o libbb/perror_msg.o libbb/perror_msg_and_die.o libbb/print_file.o libbb/process_escape_sequence.o libbb/read_package_field.o libbb/recursive_action.o libbb/safe_read.o libbb/safe_strncpy.o libbb/syscalls.o libbb/syslog_msg_with_name.o libbb/time_string.o libbb/trim.o libbb/unzip.o libbb/vdprintf.o libbb/verror_msg.o libbb/vperror_msg.o libbb/wfopen.o libbb/xfuncs.o libbb/xgetcwd.o libbb/xreadlink.o libbb/xregcomp.o libbb/interface.o libbb/remove_file.o libbb/last_char_is.o libbb/copyfd.o libbb/vherror_msg.o libbb/herror_msg.o libbb/herror_msg_and_die.o libbb/xgethostbyname.o libbb/dirname.o libbb/make_directory.o libbb/create_icmp_socket.o libbb/u_signal_names.o libbb/arith.o libbb/simplify_path.o
make: i386-uclibc-ar: Command not found
make: *** [libbb.a] Error 127
dit krijg ik als ik busybox wil "maken". uClibc is geinstalleerd (welliswaar niet in de standaard-directory, maar hij is wel geinstalleerd). en het bestand i386-uclibc-ar staat waar hij hoort te staan (/mnt/bd/usr/uClibctmp/bin/i386-uclibc-ar).
ik had eerst hetzelfde probleem met i386-uclibc-gcc maar nadat ik in de makefile de regel CC= had bijgewerkt en naar i386-uclibc-gcc had verwezen deed hij het wel.
  • Onno
Staat /mnt/bd/usr/uClibctmp/bin in je PATH?
had ik ook al geprobeerd ja, die er bij te zetten, maar dat hielp helaas niet (of ik heb typo gemaakt ,zal zo nog eens proberen)
  • Wilke
  • Laatst online: 22:26
Hij zoekt de 'archiver' (ding dat de library samenvoegt) die specifiek bij uclibc hoort, en kan deze niet vinden. Je PATH staat dus toch echt niet goed, of uclibc is niet goed geinstalleerd. Zoek op waar die 'ar' staat en voeg die dir toe aan je pad, dan moet het werken.
Ik dacht dat uclibc een scriptje meeleverde dat je kon runnen, en dat dan alle environment-vars goed zet enzo...
ok het is gelukt :)
(ik ben een bootdisk aan het maken met uClibc en busybox)
alleen nu boot ik en krijg ik kernel panic: no init found. :'(
fftjes kijken hoe dat gefixed moet worden
