SMTP port 'open' bij E-tech ADSL modem/router
Sinds een dag heb ik een E-TECH ADSL modem/router (4ports switch, firewall, annex-B ). Het lukte me al snel het internet op te komen echter na een port scan via www.grc.com zag ik het volgende;
Port Service Status
21 FTP Closed
23 Telnet Closed
25 SMTP Stealth! <<<<<<<<<<<<
79 Finger Closed
80 HTTP Closed
110 POP3 Closed
113 IDENT Closed
135 RPC Closed
139 NetBIOS Closed
143 IMAP Closed
443 HTTPS Closed
445 MSFTDS Closed
5000 UPnP Closed
Nu lukt het me niet om port 25 SMTP sluiten. Weet iemand hoe ik deze port uit kan zetten en waarom staat deze port standaard open.
  • klaaz
  • Laatst online: 25-08 07:14
klaaz
it's me!
niet voorstellen dat je dat wilt veranderen:
quote portscantest van de website waarop je test:
If all of the tested ports were shown to have stealth status, then for all intents and purposes your computer doesn't exist to scanners on the Internet!
It means that either your computer is turned off or disconnected from the Net (which seems unlikely since you must be using it right now!) or an effective stealth firewall is blocking all unauthorized external contact with your computer. This means that it is completely opaque to random scans and direct assault. Even if this machine had previously been scanned and logged by a would-be intruder, a methodical return to this IP address will lead any attacker to believe that your machine is turned off, disconnected, or no longer exists. You couldn't ask for anything better.
There's one additional benefit: scanners are actually hurt by probing this machine! You may have noticed how slowly the probing proceeded. This was caused by your firewall! It was required, since your firewall is discarding the connection-attempt messages sent to your ports. A non-firewalled PC responds immediately that a connection is either refused or accepted, telling a scanner that it's found a live one ... and allowing it to get on with its scanning. But your firewall is acting like a black hole for TCP/IP packets! This means that it's necessary for a scanner to sit around and wait for the maximum round-trip time possible — across the entire Net, into your machine, and back again — before it can safely conclude that there's no computer at the other end. That's very cool.
  • Predator
  • Laatst online: 07:24
Predator
Suffers from split brain
Die poort 25 wordt wellicht geblokkeerd door je provider ;)
Everybody lies | BFD rocks ! | PC-specs
  • Osiris
Predator schreef op 28 June 2003 @ 17:54:
PHP:
If ($isp == "@Home")
  echo "Bad luck kiddo";
} else {
  echo "Vreemd";
  • Bor
  • Laatst online: 21:56
Bor
Coördinator Frontpage Admins / FP Powermod
01000010 01101111 01110010
Stealth is veel beter als closed. Stealth geeft namelijk aan dat er helemaal niemand op dat ip + die poort antwoord. Bij closed is dat wel het geval (maw een berichtje "ik ben er niet" van de router"). Lijkt me dus niet dat je de poort 25 maar wel de andere poorten wilt veranderen.
Over Bor | Vraag & Aanbod feedback | Frontpagemoderatie Forum
  • Osiris
Ik denk toch werkelijk dat t idd aan z'n ISP ligt, vooral omdat alle overige poorten een ICMP-pakketje "Ik ben er niet" ( ;) ) terugsturen... Poort 25 wordt gewoon bij je geblocked, sorry dude...
Bij mij ook :'( :( (@Home)
Dank, voor alle opmerkingen.
Dat Stealth beter was dat closed had ik nog niet zo 1 2 3 in de gaten. Maar bij nader inzien is alles duidelijker geworden.
Sluit deze thread maar
  • Kabouterplop01
  • Laatst online: 20:21
Kabouterplop01
chown -R me base:all
Hmmmm. welke provider zit je bij?
Je zou dus niet kunnen mailen. Lijkt me niet zo handig van je provider.
Aan de andere kant wordt de poort waarschijnlijk ook gestealth. Zodat het lijkt of de poort wordt geblocked.
  • Osiris
Kabouterplop01 schreef op 30 June 2003 @ 12:00:
Gelukkig gaat het hier alleen om ingaande verbindingen op poort 25 ;) En op elk pakketje komt gewoon geen antwoord, geen eens een ICMP-pakketje terug ofzo, vandaar stealth...
