Een collega van me heeft een nieuwe Plextor cd-brander gekocht, een 2410a (24-10-24). Maar...hij brandt niet. Hij werkt met Nero 5.5 onder XP en heeft met ForceASPI de ASPI-drivers geinstalleerd. Iemand enig idee? De foutlog staat hieronder......
Windows XP 5.1
WinAspi: File 'Wnaspi32.dll': Ver=4.70, size=45568 bytes, created 10-12-2001
17:32:34
ahead WinASPI: File 'C:\Program Files\ahead\Nero\Wnaspi32.dll':
Ver=2.0.1.50, size=131072 bytes, created 26-6-2002 15:06:32
Nero Version: 5.5.9.8
Recorder: <PLEXTOR CD-R PX-W2410A>Version: 1.03 - HA 1 TA 1 -
5.5.9.8
Adapter driver: <atapi> HA 1
Drive buffer : 4096kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <AOPEN 16XDVD-ROM/AMH> Version: R14 - HA 1 TA 0 -
5.5.9.8
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD600BB-32CAA0 atapi Port 0 ID 0
DMA: On
CdRomPeripheral : AOPEN 16XDVD-ROM/AMH atapi Port 1 ID 0
DMA: On
CdRomPeripheral : PLEXTOR CD-R PX-W2410A atapi Port 1 ID 1
DMA: On
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 34603008 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 255MB (261664kB)
Free physical memory: 85MB (87112kB)
Memory in use : 66 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Enabled (1)
Wizard: On
27.6.2003
CD-ROM (ISO)
21:18:38 #1 Text 0 File Isodoc.cpp, Line 6003
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
21:18:38 #2 Phase 72 File dlgbrnst.cpp, Line 1566
BURN-Proof activated
21:18:38 #3 Text 0 File Reader.cpp, Line 118
Reader running
21:18:38 #4 Text 0 File Writer.cpp, Line 130
Writer PLEXTOR CD-R PX-W2410A running
21:18:38 #5 ISO9660GEN -11 File geniso.cpp, Line 4430
First writeable address = 0 (0x00000000)
21:18:39 #6 Text 0 File Burncd.cpp, Line 3562
Turn on Track-At-Once, using CD-R/RW media
21:18:39 #7 Text 0 File ThreadedTransferInterface.cpp, Line 663
Setup items (original item values)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 97648 (97648) = #97648/21:41.73
relocatable, CD pos for caching/writing not required/required, no patch
infos
21:18:39 #8 Text 0 File DlgWaitCD.cpp, Line 199
Last possible write address on media: 336074 (74:42.74)
Last address to be written: 97647 (21:43.72)
21:18:39 #9 Text 0 File DlgWaitCD.cpp, Line 204
Write in overburning mode: FALSE
21:18:39 #10 Text 0 File DlgWaitCD.cpp, Line 1403
Recorder: PLEXTOR CD-R PX-W2410A;
CDRW code: 00 97 34 24; OSJ entry from: Mitsubishi Chemical
ATIP Data:
Special Info [hex] 1: 96 00 D7, 2: 61 22 18 (LI 97:34.24), 3: 4A 2B
00 (LO 74:43.00)
Additional Info [hex] 1: 66 4A 99, 2: 38 80 00, 3: 04 C4 A0
21:18:39 #11 Text 0 File ThreadedTransferInterface.cpp, Line 815
Prepare recorder PLEXTOR CD-R PX-W2410A for write in TAO
DAO infos:
MCN:
TOCTYPE: 0x0 Close Session
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 200290304
21:18:39 #12 Text 0 File ThreadedTransferInterface.cpp, Line 843
Removed 2 run-out blocks from end of track 1.
21:18:39 #13 Text 0 File ThreadedTransferInterface.cpp, Line 663
Setup items (after recorder preparation)
infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 97646
blocks [PLEXTOR CD-R PX-W2410A]
21:18:39 #14 Phase 24 File dlgbrnst.cpp, Line 1566
Caching of files started
21:18:40 #15 Phase 25 File dlgbrnst.cpp, Line 1566
Caching of files completed
21:18:40 #16 Phase 36 File dlgbrnst.cpp, Line 1566
Burn process started at 4x (600 kB/sec)
21:18:40 #17 Text 0 File ThreadedTransferInterface.cpp, Line 1947
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig
at #0): write at #0
21:18:40 #18 Text 0 File Mmc.cpp, Line 16749
Set BUFE: BURN-Proof -> ON
21:18:41 #19 SCSI -400 File Cdrdrv.cpp, Line 1408
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x025B0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x27
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1F 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x27 0x00
21:18:41 #20 MMC -400 File Writer.cpp, Line 331
SCSI Target error
21:18:41 #21 Text 0 File ThreadedTransfer.cpp, Line 222
all writers idle, stopping conversion
21:18:41 #22 Text 0 File ThreadedTransfer.cpp, Line 216
conversion idle, stopping reader
21:18:41 #23 CDR -201 File WriterStatus.cpp, Line 188
Invalid write state
21:18:41 #24 TRANSFER -18 File WriterStatus.cpp, Line 188
Could not perform EndTrack
21:18:41 #25 SCSI -400 File Cdrdrv.cpp, Line 1204
Sense Code: 0x27
Sense Qual: 0x00
CDB Data: 0x5B 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
21:18:41 #26 MMC -400 File WriterStatus.cpp, Line 227
SCSI Target error
21:18:41 #27 TRANSFER -19 File WriterStatus.cpp, Line 227
Could not perform Fixation
21:18:41 #28 Text 0 File WriterStatus.cpp, Line 236
falling back to disc fixation
21:18:41 #29 SCSI -400 File Cdrdrv.cpp, Line 1204
Sense Code: 0x27
Sense Qual: 0x00
21:18:41 #30 MMC -400 File WriterStatus.cpp, Line 227
SCSI Target error
21:18:41 #31 TRANSFER -19 File WriterStatus.cpp, Line 227
21:18:41 #32 Phase 38 File dlgbrnst.cpp, Line 1566
Burn process failed at 4x (600 kB/sec)
21:18:41 #33 Text 0 File Scsicmd.cpp, Line 384
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.70, size=17101 bytes, created 10-12-2001
17:29:42
File 'Drivers\atapi.sys': Ver=5.1.2600.0 (XPClient.010817-1148), size=86656
bytes, created 7-9-2001 12:00:00 (Adapter driver for rec)
bytes, created 7-9-2001 12:00:00 (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs :
0 (Security Option)
Windows XP 5.1
17:32:34
5.5.9.8
5.5.9.8
DMA: On
DMA: On
DMA: On
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Use Inquiry : 1
Wizard: On
27.6.2003
CD-ROM (ISO)
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Burning mode : TAO
Mode : 1
Joliet : TRUE
Reader running
infos
ATIP Data:
00 (LO 74:43.00)
DAO infos:
MCN:
Tracks 1 to 1:
infos
at #0): write at #0
Sense Code: 0x27
Sense Qual: 0x00
SCSI Target error
Invalid write state
Sense Code: 0x27
Sense Qual: 0x00
SCSI Target error
Sense Code: 0x27
Sense Qual: 0x00
SCSI Target error
Existing drivers:
17:29:42
Registry Keys:
0 (Security Option)
They said it couldn't happen here.... And it didn't
