Start-up stalls
  • 36 views sinds 30-01-2008
8)7 Without any warning that something was wrong, I started my computer yesterday. First I read the notification of the graphic card I'm using, after that the following message came up in the BIOS-screen (where the used masters and slave normally are shown): "Award Medallion BIOS v6.0/ ASUS CUSL2 ACPI BIOS Rev. 1006.A/Intel Pentium III 433E (where before it showed the real speed of my CPU, 866) MHz/ [Blank middle of the screen, where the used masters and slave normally are shown]/Press DEL to enter SETUP, ES/02/27/2001-i815-CUSL2-00". During the start-up I hear two creaking sounds. Depending on whether I press DEL from the moment I press the ON-button on my computer, the cursor blinks under de ,[comma]-sign after "Press DEL to enter SETUP,". When I don't press DEL from the beginning the start-up stalls, with a blinking cursor under the S of "Press DEL to enter SETUP, ES". Can you tell me what is wrong and how I can fix this? |:(
  • BalusC
BalusC
Carpe diem
Sorry hoor, maar dit is een Nederlandstalig forum en er wordt van iedereen verwacht dat ze bij machte zijn Nederlands te spreken :)
Wat betreft je probleem: ik raad je aan om de troubleshooter door te nemen, zoals je via de FAQ/sticky van dit subforum kunt terugvinden :)
Dit graag lezen eer je post :) (lees met name de 1e posting, mocht je een nieuw topic willen openen)
Technische PMG FAQ: Hangen en Opstartproblemen
[ Voor 8% gewijzigd door BalusC op 26-06-2003 14:48 ]
