Wimbledon scoreboard: classNotFoundException
Ik weet niet of dit het goede forum is, maar ik wil wimbledon volgen via het scoreboard op www.wimbledon.com, maar dan krijg ik de foutmelding ClassNotFoundException.
Ik werk op een NT machine zit wel achter een firewall, maar dat zou
geen probleem moeten zijn, want collega's kunnen het wel zien.
Als ik in de javaconsole kijk krijg ik dit te zien:
java.net.UnknownHostException: scoreboard.wimbledon.org
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:143)
at java.net.Socket.connect(Socket.java:425)
at java.net.Socket.connect(Socket.java:375)
at sun.net.NetworkClient.doConnect(NetworkClient.java:139)
at sun.plugin.net.protocol.http.HttpClient.doConnect(HttpClient.java:95)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:366)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:582)
at sun.net.www.http.HttpClient.<init>(HttpClient.java:292)
at sun.net.www.http.HttpClient.<init>(HttpClient.java:253)
at sun.plugin.net.protocol.http.HttpClient.<init>(HttpClient.java:41)
at sun.plugin.net.protocol.http.HttpClient.New(HttpClient.java:68)
at sun.plugin.net.protocol.http.HttpURLConnection.privBlock(HttpURLConnection.java:113)
at sun.plugin.net.protocol.http.HttpURLConnection$PrivilegedBlockAction.run(HttpURLConnection.java:430)
at java.security.AccessController.doPrivileged(Native Method)
at sun.plugin.net.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:157)
at sun.plugin.net.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:361)
at sun.plugin.net.protocol.http.HttpUtils.followRedirects(HttpUtils.java:39)
at sun.plugin.cache.CachedJarLoader.download(CachedJarLoader.java:311)
at sun.plugin.cache.CachedJarLoader.load(CachedJarLoader.java:131)
at sun.plugin.cache.JarCache.get(JarCache.java:177)
at sun.plugin.net.protocol.jar.CachedJarURLConnection.connect(CachedJarURLConnection.java:71)
at sun.plugin.net.protocol.jar.CachedJarURLConnection.getJarFile(CachedJarURLConnection.java:56)
at sun.misc.URLClassPath$JarLoader.getJarFile(URLClassPath.java:498)
at sun.misc.URLClassPath$JarLoader.<init>(URLClassPath.java:459)
at sun.misc.URLClassPath$2.run(URLClassPath.java:255)
at sun.misc.URLClassPath.getLoader(URLClassPath.java:244)
at sun.misc.URLClassPath.getLoader(URLClassPath.java:221)
at sun.misc.URLClassPath.getResource(URLClassPath.java:134)
at java.net.URLClassLoader$1.run(URLClassLoader.java:190)
at java.net.URLClassLoader.findClass(URLClassLoader.java:186)
at sun.applet.AppletClassLoader.findClass(AppletClassLoader.java:134)
at sun.plugin.security.PluginClassLoader.findClass(PluginClassLoader.java:189)
at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
at sun.applet.AppletClassLoader.loadClass(AppletClassLoader.java:114)
at java.lang.ClassLoader.loadClass(ClassLoader.java:262)
at sun.applet.AppletClassLoader.loadCode(AppletClassLoader.java:501)
at sun.applet.AppletPanel.createApplet(AppletPanel.java:548)
at sun.plugin.AppletViewer.createApplet(AppletViewer.java:1627)
at sun.applet.AppletPanel.runLoader(AppletPanel.java:477)
at sun.applet.AppletPanel.run(AppletPanel.java:290)
at java.lang.Thread.run(Thread.java:536)
load: class Scoreboard.class not found.
java.lang.ClassNotFoundException: Scoreboard.class
at sun.applet.AppletClassLoader.findClass(AppletClassLoader.java:153)
at sun.applet.AppletClassLoader.loadCode(AppletClassLoader.java:506)
Caused by: java.net.UnknownHostException: scoreboard.wimbledon.org
at java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:237)
at sun.applet.AppletClassLoader.getBytes(AppletClassLoader.java:250)
at sun.applet.AppletClassLoader.access$100(AppletClassLoader.java:42)
at sun.applet.AppletClassLoader$1.run(AppletClassLoader.java:143)
at sun.applet.AppletClassLoader.findClass(AppletClassLoader.java:140)
... 10 more
Ik gebruik IE 5.5 op een windows NT 4 machine. De versie van de virtual machine weet ik niet (hoe kan ik daar achter komen?). Mijn collega's gebruiken dezelfde machines met dezelfde configuratie.
Ik heb al geprobeerd uit te zetten dat java 2 versie 1.4 gebruikt wordt voor applets, maar dan krijg ik een leeg scherm te zien.
[ Voor 9% gewijzigd door Verwijderd op 24-06-2003 11:14 ]
  • F_J_K
F_J_K
Moderator CSA/PB/AI
Front verplichte underscores
Leuk om die foutmelding (veel te groot, haal in ieder geval elke tweede enter even weg :X ) te laten zien, maar info zoals welke browser (versie) en welke Java VM (versie) lijken me erg handig :Y)
Maar haal in ieder geval even de nieuwste laatste Microsoft VM binnen. (Is niet meer bij Microsoft te krijgen, maar de link staat hier een aantal keer op GoT).
  • aReaRe
aReaRe
Welkom Patrick (11-02-2022) <3
Verwijderd schreef op 24 June 2003 @ 10:46:
Welke windows versie :? NT is een relatief begrip, we hebben het dan over NT4, Windows 2000 of Windows XP :? Welke Servicepacks. Welke rechten heb je op jouw machine.
Wat hebben je collega's aan specs, os enzo :?
Zie ook - topicstart
Leg je probleem goed uit. Hetgeen jij zegt is namelijk het enige dat anderen van jouw probleem weten. Hoe meer (relevante) informatie je geeft, hoe beter je geholpen kunt worden
Noem eventueel terzake doende omstandigheden en feiten (gebruikt OS, hardware etc).
Maak duidelijk wat je zelf hebt geprobeerd en vertel waarom dit je niet verder geholpen heeft. Wees hierbij specifiek, zodat de info relevant is. "Ik heb niets gevonden" zegt niets.
Geef eventueel linkjes naar websites die je hebt bezocht (en geef aan waarom die informatie niet voldoende was).
Probeer er een duidelijk! verhaal van te maken dat door andere mensen prettig te lezen en goed te begrijpen valt!
Renault Mégane Estate 1.3 TCe EDC (IV) 140pk Bose (oktober 2019) met aan de trekhaak een Caravelair Antares Titanium 390 (mei 2021)
