[alsa] geluidskaart zit met me te spelen...
eerst alle belangrijke gegevens :)
output van cat /proc/pci
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
root@basje cj # cat /proc/pci
PCI devices found:
  Bus  0, device   0, function  0:
    Host bridge: Silicon Integrated Systems [SiS] 735 Host (rev 1).
      Master Capable.  Latency=32.
      Non-prefetchable 32 bit memory at 0xd0000000 [0xd3ffffff].
  Bus  0, device   1, function  0:
    PCI bridge: Silicon Integrated Systems [SiS] 5591/5592 AGP (rev 0).
      Master Capable.  Latency=64.  Min Gnt=10.
  Bus  0, device   2, function  0:
    ISA bridge: Silicon Integrated Systems [SiS] 85C503/5513 (rev 0).
  Bus  0, device   2, function  3:
    USB Controller: Silicon Integrated Systems [SiS] 7001 (#2) (rev 7).
      IRQ 11.
      Master Capable.  Latency=64.  Max Lat=80.
      Non-prefetchable 32 bit memory at 0xcffff000 [0xcfffffff].
  Bus  0, device   2, function  2:
    USB Controller: Silicon Integrated Systems [SiS] 7001 (rev 7).
      IRQ 11.
      Non-prefetchable 32 bit memory at 0xcfffe000 [0xcfffefff].
  Bus  0, device   2, function  5:
    IDE interface: Silicon Integrated Systems [SiS] 5513 [IDE] (rev 208).
      Master Capable.  Latency=128.
      I/O at 0xff00 [0xff0f].
  Bus  0, device  11, function  0:
    VGA compatible controller: S3 Inc. 86c764/765 [Trio32/64/64V+] (rev 0).
      IRQ 11.
      Non-prefetchable 32 bit memory at 0xcf000000 [0xcf7fffff].
  Bus  0, device  13, function  0:
    Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 16).
      IRQ 5.
      Master Capable.  Latency=64.  Min Gnt=32.Max Lat=64.
      I/O at 0xd800 [0xd8ff].
      Non-prefetchable 32 bit memory at 0xcfffdf00 [0xcfffdfff].
  Bus  0, device  17, function  0:
    Multimedia audio controller: Fortemedia, Inc Xwave QS3000A [FM801] (rev 177).
      IRQ 11.
      Master Capable.  Latency=64.  Min Gnt=4.Max Lat=40.
      I/O at 0xd400 [0xd47f].
  Bus  0, device  17, function  1:
    Gameport controller: Fortemedia, Inc Xwave QS3000A [FM801 game port] (rev 177).
      Master Capable.  Latency=255.  Min Gnt=255.Max Lat=255.
      I/O at 0xdc00 [0xdc0f].
  Bus  1, device   0, function  0:
    VGA compatible controller: nVidia Corporation NV11 [GeForce2 MX] (rev 178).
      IRQ 5.
      Master Capable.  Latency=248.  Min Gnt=5.Max Lat=1.
      Non-prefetchable 32 bit memory at 0xcd000000 [0xcdffffff].
      Prefetchable 32 bit memory at 0xc0000000 [0xc7ffffff].
alsa versie is : alsa-driver-0.9.2.
systeem draait op gentoo 1.4.
net alle packages geupdate.
als ik alsasound start krijg ik de volgende error:
root@basje cj # /etc/init.d/alsasound start
 * Initialising ALSA....
 * Starting sound driver: snd-fm801
/lib/modules/2.4.20-gentoo-r5/kernel/sound/pci/snd-fm801.o: init_module:
No such device
Hint: insmod errors can be caused by incorrect module parameters,
including invalid IO or IRQ parameters.
      You may find more information in syslog or the output from dmesg
/lib/modules/2.4.20-gentoo-r5/kernel/sound/pci/snd-fm801.o: insmod
/lib/modules/2.4.20-gentoo-r5/kernel/sound/pci/snd-fm801.o failed
snd-fm801 failed
dmesg:
ALSA ../alsa-kernel/pci/fm801.c:208: AC'97 interface is busy (1)
ALSA ../alsa-kernel/pci/fm801.c:239: AC'97 interface is busy (1)
ALSA ../../alsa-kernel/pci/ac97/ac97_codec.c:1960: AC'97 0:0 does not respond - RESET
ForteMedia FM801 soundcard not found or device busy
heb al ge googled en kwam dit tegen.
dit is alleen niet bij mij van toepassing, hij laad netjes snd-fm801.
ik weet het niet meer :S
Ik ga er van uit dat de verdere asla configuratie goed is.
In jou geval hangen er flink wat apparaten op IRQ-11. De hele boel zou wel met IRQ-sharing kunnen werken, naar men zegt. Maar mijn ervaringen zijn anders.
Probeer eerst eens vanuit je BIOS de USB handel te deactiveren. Ook een ander PCI-slot kan je uit de problemen helpen. In de meest gebruikers handleidingen van mainboards staat beschreven welke PCI sloten welke IRQ's sharen. Probeer in ieder geval zo min mogelijk te sharen.
Suc6
  • Lancer
  • Laatst online: 11-09 07:57
Lancer
What the......
OSS module niet al geladen?
modules.conf goed ge-edit?
lsmod output?
[ Voor 47% gewijzigd door Lancer op 24-06-2003 11:03 . Reden: meer vragen..... ]
Je kunt niet in een systeem meten zonder het systeem te beinvloeden.... (gevolg van de Heisenberg onzekerheidsrelatie)
  • NaliXL
  • Laatst online: 30-07 19:19
Haha, grappig dat ik dit nou net tegenkom. Heb hetzelfde probleem gehad met dezelfde geluidskaart. De oplossing was bij mij om op de normale manier te compileren, en m'n ALSA-modules met behulp van /etc/modules.autoload te laden bij het opstarten. Tenminste, bij mij werkte dat...
Genoeg is meer dan veel, en tart den overvloed
