[W3C] Cookie wordt niet geaccepteerd
  • asusk7m550
  • Laatst online: 09-09 11:51
asusk7m550
Athlon 550@500
Ik wil met het programma W3C mijn webpage ophalen,
maar mijn webpage stuurt een cookie en deze zou W3C dan terug moeten sturen.
Weet iemand hoe ik dit kan doen.
Via Google heb ik niets kunnen vinden, en hier kan ik ook al niets vinden.
Of weet iemand misschien een ander programma waarmee ik een webpage kan ophalen die cookies ondersteunt, en ook de post methode kent, en onder Linux werkt?
It takes only a minute to get a crush on someone, an hour to like someone, and a day to love someone, but it takes a lifetime to forget someone.
  • moto-moi
  • Laatst online: 09-06-2011
moto-moi
Ja, ik haat jou ook :w
wget :
quote: wget manpage
--cookies=on/off
When set to off, disable the use of cookies. Cookies are a mecha-
nism for maintaining server-side state. The server sends the
client a cookie using the "Set-Cookie" header, and the client
responds with the same cookie upon further requests. Since cookies
allow the server owners to keep track of visitors and for sites to
exchange this information, some consider them a breach of privacy.
The default is to use cookies; however, storing cookies is not on
by default.
--load-cookies file
Load cookies from file before the first HTTP retrieval. file is a
textual file in the format originally used by Netscape's cook-
ies.txt file.
You will typically use this option when mirroring sites that
require that you be logged in to access some or all of their con-
tent. The login process typically works by the web server issuing
an HTTP cookie upon receiving and verifying your credentials. The
cookie is then resent by the browser when accessing that part of
the site, and so proves your identity.
Mirroring such a site requires Wget to send the same cookies your
browser sends when communicating with the site. This is achieved
by --load-cookies---simply point Wget to the location of the cook-
ies.txt file, and it will send the same cookies your browser would
send in the same situation. Different browsers keep textual cookie
files in different locations:
Netscape 4.x.
The cookies are in ~/.netscape/cookies.txt.
Mozilla and Netscape 6.x.
Mozilla's cookie file is also named cookies.txt, located some-
where under ~/.mozilla, in the directory of your profile. The
full path usually ends up looking somewhat like
~/.mozilla/default/some-weird-string/cookies.txt.
Internet Explorer.
You can produce a cookie file Wget can use by using the File
menu, Import and Export, Export Cookies. This has been tested
with Internet Explorer 5; it is not guaranteed to work with
earlier versions.
Other browsers.
If you are using a different browser to create your cookies,
--load-cookies will only work if you can locate or produce a
cookie file in the Netscape format that Wget expects.
If you cannot use --load-cookies, there might still be an alterna-
tive. If your browser supports a ``cookie manager'', you can use
it to view the cookies used when accessing the site you're mirror-
ing. Write down the name and value of the cookie, and manually
instruct Wget to send those cookies, bypassing the ``official''
cookie support:
wget --cookies=off --header "Cookie: I<name>=I<value>"
God, root, what is difference? | Talga Vassternich | IBM zuigt
  • asusk7m550
asusk7m550
Athlon 550@500
Ik had ook alwel gekeken naar wget, maar daar kun je geen post formulieren mee posten.
Ik heb ondertussen curl erbij gepakt, en deze doet het wel
