NVIDIA Overclocking Utility
  • 483 views sinds 30-01-2008
  • MaiorDomus
  • Laatst online: 05-04 22:31
When I recently visited NVIDIA before this launch, they were very excited to show me a new tool that they had been working on for some time. It is a Windows based application (in its current form) that allows the user to overclock their system in Windows, without rebooting in most cases.
I have some screen shots here, but I’ll describe what you are seeing as well. Through some very basic menus and scroll bars, you are able to edit the front-side bus of the system, the voltages as well as the memory timings. The only reason you should have to reboot, they are telling me, is when you change the CAS Latency setting – other than that when you hit apply, all should be working as shown. In my tests, the application was working well. Upping the FSB from 200 to 220 MHz and then hitting apply, I opened the SiSoft Sandra and it reported to me that the system was indeed running at the new faster speed. Benchmarks verified it as well.
Afbeeldingslocatie: http://www.amdmb.com/images/athlonxp3200/octool-1.gif
Afbeeldingslocatie: http://www.amdmb.com/images/athlonxp3200/octool-2.gif
Currently, this program is only working with their reference boards, and is in a very conceptual state. NVIDIA wanted you to know that this utility is a work in progress and is still in the conceptual stage. NVIDIA has not disclosed when this utility might be available, or the mode of distribution. However, NVIDIA is actively soliciting feedback and ideas for possible development, so if you like what you see or have any helpful suggestions, please submit your ideas to AMDMB.com, and we will forward them on to the NVIDIA engineers.
weet iemand hier meer over?? IK zou er graag meer info over willen hebben :Y)
[edit] dit proggie is dus alleen voor de Nforce 2 (ultra 400 ?? :? )... moederborden... en je kan er mee overclocken in Windows >:) Lijkt mij wel heel handig :D :Y)
bron: http://www.amdmb.com/arti...hp?ArticleID=237&PageID=3
13 Mei dus... dus ik hoop dat het snel komt :9~
[ Voor 13% gewijzigd door MaiorDomus op 23-06-2003 13:08 ]
  • Rey Nemaattori
  • Laatst online: 11:28
Volgens mij krijg je dit proggie bij een mobo met de Nfoce2 400 chipset, en issie ook daarvoor bedoelt... Mishcien heb je er wat aan mij andere nforce typen, maar ik betwijfel of ik met my KT er iets aan heb :-S
[ Voor 50% gewijzigd door Rey Nemaattori op 23-06-2003 12:18 ]
Speks:The Hexagon Iks Twee Servertje
"When everything is allright,there is nothing left."Rey_Nemaattori
  • MaiorDomus
Rey Nemaattori schreef op 23 juni 2003 @ 12:17:
Ik denk idd niet dat jij er dan iets aan hebt... :/
Maar nouja ik het er wel iets aan... ;) Daarom wil ik ook graag wat meer info.. ik heb hem volgens mij bij nog geen enkele moederbordcd gezien dus ... weten jullie misschien wanneer die dan uitkomt??
  • EvilWhiteDragon
  • Laatst online: 10:45
Ik denk dat het idd alleen voor de nforce 2 is en niet alleen voor de ultra 400
LinkedIn
BlackIntel
is dat niet gevaarlijk in windows je memory timings veranderen enz :?
  • MaiorDomus
Verwijderd schreef op 23 June 2003 @ 13:41:
IK heb gelezen dat als het niet goed gaat >:) hij automatisch opnieuw opstart en dat je dan weer gewoon op je vorige settings zit...
:Y)
ThaKiller:
of je moet ff de reset knop indrukken he ?
zal ook wel kunnen ;) De instellingen worden iig terug verandert... :)
[ Voor 27% gewijzigd door MaiorDomus op 23-06-2003 14:05 ]
  • EvilWhiteDragon
LinkedIn
BlackIntel
Ik hoop dat het ook voor eerdere revisie nForce2 mobo's is. Ik heb een A7N8X Rev 2.0 die Ultra 400 Support, maar ik heb officieel (volgens mij) geen Ultra 400 chipset :)
  • MaiorDomus
Verwijderd schreef op 23 June 2003 @ 14:07:
Zoveel verschil zat daar toch niet tussen?? ;)
Mijn abit nfs-7 s rev. 2.0 zou het wel moeten doen lijkt mij :Y)
  • t!mP
  • Laatst online: 08:45
t!mP
is inflatie gevoelig
ja is net zoals dat msi progje denk ik ;x
fuzzy logic ofso ?
  • PowerPee
  • Laatst online: 08-06-2025
Echt super cool !! >:)
Wat gebeurt er nou als je je settings te hoog instelt? Default ie dan?
...als ik straks weer draai, dan ga ik dit zeeeeeker proberen :)
BIOS flashen wordt ook afgeraden in windows...hoe zou het met dit progje zijn? :O
[ Voor 22% gewijzigd door PowerPee op 23-06-2003 15:02 ]
  • MaiorDomus
Echt super cool !! >:) Dacht ik toch ook :7
Wat gebeurt er nou als je je settings te hoog instelt? Default ie dan? volgens mij schakelt die dan terug naar de vorige instellingen... :)
...als ik straks weer draai, dan ga ik dit zeeeeeker proberen :) zal moeilijk gaan of jij moet weten waar je hem nou al kan downloaden ? ;)
BIOS flashen wordt ook afgeraden in windows...hoe zou het met dit progje zijn? :O lijkt mij dat hier nix mis mee is... :Y)
[ Voor 25% gewijzigd door MaiorDomus op 23-06-2003 15:34 ]
  • MaiorDomus
weten meer lui iets van de progje af??? >:)
Kan haast niet wachten om hem te gaan downloaden... :Y)
woopz sorry dubbelpost... :+
[ Voor 16% gewijzigd door MaiorDomus op 23-06-2003 15:50 ]
  • Xiqum
  • Laatst online: 04-04 22:50
t!mP schreef op 23 June 2003 @ 14:50:
fuzzy logic ofso ?
Ja met m'm msi moederboard heb ik ook fuzzy logic 4 gekregen.
Hier kun je de voltage en de fbs dus ook gelijk veranderen.
Zelfs hem automatisch laten overklokken maar toch werkte het niet helemaal goed.
Ik heb het later gewoon in de bios gedaan. Werkte beter omdat ik daar verder kwam :Y)
  • Shyne
  • Laatst online: 01-04 13:31
wel een leuk tooltje
crap zal dus niet werken met me 8rdA+ :(
  • MaiorDomus
Shyne schreef op 23 June 2003 @ 16:22:
Het is toch nog niet duidelijk of hij daarmee niet overweg kan ;)
om dat nou alleen op dat plaatje te baseren vind ik onzin misschien geeft dat gewoon aan dat het die herkent heeft... :)
  • Maestro.mosjuh
wat wel makkelijk is (ik bedoel, je zal je computer niet standaard oc'en via een windows proggel):
- je boot je computer
- start proggel
- oc je computer
- burn in
if (stable): oc verder
if(not stable): stel laatste stabiele waarde in bios in....
[ Voor 14% gewijzigd door Maestro.mosjuh op 23-06-2003 16:49 ]
At the beginning there was nothing. So God said 'apt-get install light'.
  • MaiorDomus
Maestro.mosjuh schreef op 23 June 2003 @ 16:49:
- start proggel
- oc je computer
- burn in
dit is precies waarvoor ik het wou gebruiken :D
en als ik een voor mij 'leuk' punt heb dan voer ik die instellingen gewoon in bij het bios en klaar :9~
(misschien hoeft dit hierboven niet eens en wordt het al in het bios gedaan :Y) dat weten we nou tenslotte nog niet... :) )
heb je al gegoogled met die naam NVSYSCFG?
/edit:
ik heb net zelf even gegoogled en ik vind wel 2 sites :( met een taal die ik niet begrijp :+
[ Voor 56% gewijzigd door Verwijderd op 23-06-2003 21:25 ]
  • MaiorDomus
Verwijderd schreef op 23 June 2003 @ 21:21:
/edit:
yep dat heb ik gedaan... had inderdaad maar 2 opties dacht ik :(
2 voor mij vreemde talen dacht japans en spaans ofzo... :/
GoTAProblem schreef op 23 juni 2003 @ 21:28:
Wie biedt zich aan dit even door te lezen? en misschien te vertalen O-)
anders hebben wij er zo weinig aan he :+
[ Voor 7% gewijzigd door Verwijderd op 23-06-2003 21:32 ]
  • Remy
  • Laatst online: 24-03 03:46
Remy
I usually get 100% accuracy
Ziet er goed uit. Alleen de grote vraag is dus, of het voor de non-ultra 400 borden, de oudere nForce2 borden dus, ook zal werken? Het is dan wel min of meer dezelfde chipset, maar toch weer net ff anders.
En dat OC'en in Windows is leuk en alles, maar sommige progs, en Windows zelf, kunnen daar wel eens moeite mee hebben. Ik heb voor de lol eens SoftFSB gebruikt, en de pc waar ik toen aan zat begon vlak daarna wel ineens kuren te vertonen. Na een reboot met de nieuwe SoftFSB instellingen ging het echter wel goed :)
LinkedIn
Instagram
  • MaiorDomus
speciaal voor visjesoft :D
vertaalt staat er dus dit :
NVIDIA namely □promotes the nForce chip □□to use the ultra □tool
Before I □□□first □said nVIDIA on LanParty male □demonstrated for the first time nForce2 the Ultra 400 main engines boards the news, □had demonstrated in nVIDIA on Lan Party □□□the nForce series chip □grinds □ultra □□- Nvsyscfg, □funds □may in the Windows operation be □□center □□AGP, □the principle, □saves, AUX and the chip □north □work □□. With □, □□AGP, the FSB work □rate, □shows □the principle, department □work □. □in I □am very high □saw nVIDIA Nvsyscfg ultra □□□center, has joined □the chip □north □chip work □□□entire, is advantageous to promotes the nForce2 main engine board □to determine the nature of in ultra □□□under.
Afbeeldingslocatie: http://www.zenha.net/news/20030506/nvoc.jpg
meer dan dit kan ik er niet van maken ;)
op de andere site kan ik trouwens niet komen?? :+
zie hier trouwens wel verdacht veel ultra staan... :/
[ Voor 55% gewijzigd door MaiorDomus op 23-06-2003 22:32 ]
  • MaiorDomus
is er misschien een Japanner in de zaal?? :Y)
Ik hoop maar dat dit proggie niet alleen de ultra ondersteunt anders zullen veel lui hier chagerijnig worden ;)
  • CommanderKeen
  • Laatst online: 09-03 14:20
is het wel verstandig dat dit zomaar kan? strax komen er virussen die je pc dik overklokken(te dik) waardoor je zeg maar een rokend pctje hebt.....
of ben ik nu een banaan :S
maar opzich lijkt het me wel wat ja :)
toch klinkt het imo iets te mooi om waar te zijn
CommanderKeen schreef op 24 June 2003 @ 17:27:
oei oei :D . dat dat maar nooit zal gebeuren :/ :(
  • MaiorDomus
nou je het zegt... :/ dat zo wou heel erg verot zijn :| Maar als je een pc veels te ver overklokt hangt die toch ook zowat gelijk??? dan maakt het ook niet veel uit denk ik en misschien kan je wel een llimiet stellen ofzo :? :9
Daar had ik een tijd geleden nog wat over gepost:
Verwijderd in "Asus A7N8X overclock resultaten" / Verwijderd in "Asus A7N8X overclock resultaten"
Links:
http://www.pcgames.de/index.cfm?article_id=167622
http://www.amdzone.com/ar...cfm?articleid=1274&page=3
http://www.nforcershq.com...hp?name=News&new_topic=35
Over virussen die je Proc. kunnen laten doorbranden:
dat konden ze al langer als vandaag, sinds Tsjernobyl virus + softFSB/jumperless mobo's kan er al een bios geflasht of FSB gewijzigd worden door een virus.
Gelukkig dat AMD + Nforce2 bordje tegen te hoge temperaturen beschermd zijn (door bios :+)
Frontpage update: nieuws: nVidia komt met ForceWare
[ Voor 34% gewijzigd door Verwijderd op 26-09-2003 14:52 ]
Ik probeer ook wel eens mijn cpu sofwarematig te klokken met SoftFSB maar het wil niet lukken als ik hem een beetje opklok dan hang mijn pc al.... :(
  • MaiorDomus
Yes, it was very nice. the guys at nVidia sad it would only work with the nForce2 400 and nForce3 chipset boards. They did say it would require a bios update from most of the board manufactures.
I did ask them about support for older nForce2 boards, they are talking about adding them in but, not any of the nforce1 can do this...
bron: http://www.nforcershq.com...hp?name=News&new_topic=35
thank you euss dit was info waar denk ik veel lui op zaten te wachten _/-\o_
Verwijderd schreef op 24 June 2003 @ 18:18:
en het lukt wel in het bios?? :?
[ Voor 6% gewijzigd door MaiorDomus op 24-06-2003 18:30 ]
  • Maestro.mosjuh
* Maestro.mosjuh heeft een nvidia nForce2 400 ultra...
gimme the goods :P
  • Extra300s
  • Laatst online: 13-05-2024
Extra300s
Get a live!
Verwijderd schreef op 24 juni 2003 @ 18:18:
Zal veelal aan je systeem liggen. Ook de voltage verhoogt van je CPU en is die unlocked, je geheugentimings enz.. enz.. Zoek daar eerst eens wat info over, en vergelijk dat met jou systeem.
NIKON D70 | flitser: SB-800 | AF-S Nikkor 12-24 ED DX | AF-S Nikkor 24-85 ED DX| AF-S Nikkor 80-200mm ED F1:2.8 D | Sigma 90mm F2.8 EX Macro 1:1 ! www.josla.com
  • Rey Nemaattori
GoTAProblem schreef op 23 June 2003 @ 13:51:
:Y)
Idd, ik kan gewoon mijn bus, mem & core speed verhogen onder windows zonder crashes, tenzij je het heel bont maakt(meder dan 3 mhz per keer) of heel ver doorgaat...(neej een fsb van 175 op een 133mhz t-bred is geen goed idee ;) )
GoTAProblem schreef op 24 June 2003 @ 18:27:
| Ja in de BIOS wel celly 500 @ 600 Hoger wil ie niet :( |
  • MaiorDomus
Verwijderd schreef op 24 June 2003 @ 19:44:
dat is wel raar... :? Misschien is dat proggie gewoon brak ofzo... ;)
  • Glashelder
Glashelder
Anti Android
Altijd als ik dit probeerde (MSI, Fuzzy Logic) dan kreeg ik direct een blauw scherm nadat de nieuwe instellingen waren toegepast (windows XP) :X
vraag me af of dit wel lekker gaat werken :X
  • Syzzer
  • Laatst online: 31-03 22:50
Syzzer
Prutser
Zou je voor elke chipset zo'n progje moeten schrijven, lijkt me wel erg veel werk...
Edit: oops, er was nog een pagina |:(
[ Voor 6% gewijzigd door Syzzer op 25-06-2003 21:25 ]
Komt dat ff handig uit , laat nou net in mijn Shuttle Sn45G een ultra 400 zitten :)
Lijkt me kei blits en handig uit windows te kunnen overklokken
  • poing
Leuk maar niet nieuw, ik gebruikte zo'n programma op men asus p2b (SOFTFSB).
  • Shunt
  • Laatst online: 08:32
Shunt
Boe
poing schreef op 26 June 2003 @ 10:54:
ja maar niet voor nvidia 2 chipsets :>
het is dus van nvidia zelf dit tooltje dus dat is wel nieuw ;)
Game PC
2 Post or Not 2 Post What's the question ?
"If it ain't broken, you didn't try hard enough"
Vet voor je, alleen kun je daarmee niet alle Fsb, multiplier, memory, agp, voltages, CPU-fan, timings etc mee regelen onder Windows. Bovendien is SoftFSB ook gebasseerd op oudere tools (alleen zo oud dat Windows niet eens bestond)...
Het zou trouwens wel kicken zijn als iemand een tweaktool maakt die hiermee weer schakelt (een soort auto-overklok-test) daar zullen veel wannabee's op zitten wachten en de diehard scheelt het weer klikken, testen, beoordelen en schrijven/onthouden...
  • Glashelder
Glashelder
Anti Android
ben nog niet helemaal wakker :o :(
[ Voor 85% gewijzigd door Glashelder op 26-06-2003 13:07 ]
Toch wel, dat is officieel kijk maar op asus.com.tw
  • stamp
Het wordt pas helemaal kicken als dit tooltje verder samenwerkt met windows bv dat ie een bepaald percentage overclockt als je cpu een tijdje 100% in gebruik is en het zaakje weer langzamer zet door te hoge temps of een afnemend cpu verbruik.
zoiets als speedstep van een laptop die dan niet aleen maar underclockt :)
[ Voor 14% gewijzigd door stamp op 26-06-2003 13:39 ]
Then we ate some mescaline and went swimming - Hunter S. Thompson.
  • Yokozuna
  • Laatst online: 19-05-2025
Verwijderd schreef op 26 juni 2003 @ 12:53:
HEhe ja gaaf, en dan zelf instellen hoe lang hij stabiel moet draaien voordat de bench stopt :)
  • VisionMaster
  • Laatst online: 17-03 00:12
VisionMaster
Security!
stamp666 schreef op 26 June 2003 @ 13:38:
* VisionMaster Bookmarked dit even ivm grote intresse (zie specs).
Het zou een leuke toepassing zijn dat je een Timer kan opgeven van x aantal seconden/minuten idle draaien dat je speed terug stepped.
Of juist anders om ... als je performance vraagt dat het tot 120% systeem performance opkrikt (ik bedenk me net dat dit niet de progsels zijn waarvan je wil dat die ooit vastlopen :P )
I've visited the Mothership @ Cupertino
  • MaiorDomus
Ik vind dat NVIDIA wel eens van zich mag laten horen >:) ;)
Zo'n automatisch overclockgedeelte is helemaal geen slecht idee :Y) lijkt mij wel wat >:)
