[ASP] Exchange achter ISA-server, mail naar buiten domein *
  • BasSpruit
  • Laatst online: 09-04-2022
ik heb de volgende code:
ASP:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
SUB sendmail( fromWho, toWho, Subject, Body )
Dim objCDO
Dim objConf
Dim objFields
Const cdoSendUsingPort = 2
Set objCDO = Server.CreateObject("CDO.Message")
Set objConf = Server.CreateObject("CDO.Configuration")
Set objFields = objConf.Fields
objFields.Item("http://schemas.microsoft.com/cdo/configuration/sendusing") = cdoSendUsingPort
objFields.Item("http://schemas.microsoft.com/cdo/configuration/smtpserver") = "Onze ExChange server, een andere PC" 'originele naam vervangen'
objFields.Item("http://schemas.microsoft.com/cdo/configuration/smtpserverport") = 25
objFields.Item("http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout") = 10
objFields.Update
Set objCDO.Configuration = objConf
objCDO.From     = fromWho
objCDO.To       = toWho
objCDO.Subject  = Subject
objCDO.TextBody = Body
on error resume next
objCDO.Send
END SUB
fromWho     = TRIM( Request.Form( "fromWho") )
toWho       = TRIM( Request.Form( "toWho") )
Subject     = TRIM( Request.Form( "Subject" ) )
Body        = TRIM( Request.Form( "Body") )
If toWho <> "" THEN
sendMail fromWho, toWho, Subject, Body
' Response.redirect "confirmation.html"
' Any existing page can be used for the response redirect method
END IF
'Cleanup
Set ObjCDO = Nothing
Set objConf = Nothing
Set objFields = Nothing
<html>
<head><title>Email Form</title></head>
<form method="POST" action="<%=Request.ServerVariables("SCRIPT_NAME")%>"> <br>
TO: <input name="toWho" type="text" size=40> <br>
FROM: <input name="fromWho" type="text" size=40> <br>
SUBJECT: <input name="Subject" type="text" size=40> <br>
<textarea name="Body" cols=40 rows=5></textarea> <br>
<input type="SUBMIT" value="Send Mail">
</form>
</html>
de webserver en de Exchange server staan op 2 verschillende PC`s. nu zou dat met dit script niks uit moeten maken, maar het netwerk zit achter een ISA-server en ik kan alleen emailtjes versturen naar emailadressen binnen het eigen domein. weet iemand hoe ik nu E-mailtjes kan sturen naar buiten het eigen domein? alle server binnen het domein zijn trouwens OF W2000 OF W2000server.
Volgens mij moet je op de server waar IIS draait de SMTP-server (onderdeel van IIS) installeren. Via 'smarthost' stuur je mail voor buiten het domein door naar de Exchange-server. Op de Exchange-server moet je relay-verkeer vanaf je SMTP-server toestaan (ip-adres). Misschien moet je in de ISA-server nog smtp-verkeer openzetten.
