[DrayTek Vigor (2600WE)] FW-Upgrades suc6-vol? (onderzoekje)
  • Osiris
Ik heb even gekeken naar de huidige FirmWare van mijn 2600WE (2.3.2) en de nieuwste Release (2.3.6) en dus de verschillen daartussen:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
[Changes / New functions since firmware 2.3.3]
    [Improvements]
        1. Improve DHCP client unstable problems in some regions and some ISPs.
        2. SmartStartResponse message add product and version messages.
        3. Reject RIP port unicast packets to protecting from attack.
        4. Implement a new algorithm for DNS.
        5. Add content_length (HTTP protocol).
        6. add PPPoE pass through function.
            a. wired Lan: if it is enabled, it allows pass-through from PC's
                          PPPoE Client.
            b. Wireless Lan: Same as Wired Lan, but it controls Wireless Clients.
                             recommanded to disable it on Wireless Lan.
        7. Show active Primary/Secondary DNS information on "Online Status" of WEB.
        8. Improve DNS assignment policy
        9. Support VPN connection from LAN interface
       10. Support PPTP with MPPE remote access clients via RADIUS authentication
       11. Add customer DNS setting for DYNDNS.
       12. Improve H3.2.3 traffic pass-through NAT
       13. Change "Disable Ping from the Internet" as default setting to increase
           the security
       14. Support wireless LAN roaming.
       15. DHCP server fills hostname for Solaris system.
     [Fixed problems]
        1. Modify 2nd DHCP server bugs.
        2. Modify routing problems in MPoA and PPPoA/PPPoE settings.
        3. Modify receiving Unix mail server abnormal situations.
        4. Fix wireless data corrupt problem.
        5. Modify a tcp congestion bug.
        6. Adapt DDNS for various ISPs.
            a. add customer DNS on DYNDNS.
            b. modify DDNS for HUAGAI ISP.
        7. Modify VPN always on for ISDN problems.
        8. Modify DoS algorithms.
        9. fix a bug when enable ISDN trigger on Route Mode of MPoA. (V2600W/X)
            it only access internet by ISDN line when ISDN trigger is enabled.
       10. Fixed connection failures on MS Exchange Server(5.5) from LAN
       11. Fixed VPN always-on problems for multi-tunnel connections
       12. Fixed VPN always-on failures when back-up ISDN  is up(ISDN model)
       13. Fixed connection failure on  L2TP tunnel  over ISDN
       14. Fixed (firmware 2.3.x)MS Chap v1 authentication failures on VPN
           (as a client)
       15. Fixed upload data corruption problems on wireless LAN
Ik zit toch sterk na te denken om 2.3.6 erop te flashen, ivm met die upgrades en dan zat ik vooral te denken aan die data corruption problems bij WLAN, aangezien ik daar een paar probleempjes mee gehad heb (WLAN op mn laptop viel zomaar weg terwijl hij 1 meter naast de router staat...)
En er zitten nog andere fijne opties etc in :)
Alleen Flashen is uiteraard niet zonder risico's...
Nu vraag ik mij af: zijn dit de risico's waard? En wat zijn die risico's ongeveer?
Dus eigenlijk mijn vraag: Bij wie is het flashen al dan niet gelukt?
Aan de hand van deze gegevens zou het dus mogelijk moeten zijn om een soort Flash-risico in bijv percentages aan te geven, wat dus mijn bedoeling is :P
Dus, een Poll! \o/
Poll: Is het Flashen van je DrayTek-router wel of niet goedgegaan?
Ja, in 1 keer probleemloos
Ja, maar pas na een aantal keer proberen
Nee, m'n router is nog steeds fucked up
Ik heb m'n router nog nooit geflashed
Afbeeldingslocatie: http://poll.dezeserver.nl/results.cgi?pid=2707&layout=2&sort=prc
Ook een poll maken? Klik hier
  • Vinnienerd
  • Laatst online: 12:11
Gewoon d'r op pleuren die firmware..doe ik zo vaak
[ Voor 16% gewijzigd door Vinnienerd op 22-06-2003 20:11 ]
  • Osiris
Vinnienerd schreef op 22 June 2003 @ 20:09:
En hoevaak is vaak? :o 10x ofzo?
En khad nog een vraagje: Is het nou wel verstandig om die 2.3.6 erop te pleuren? Ik hoorde namelijk dat UPnP met een bepaalde Firmware niet goed werkte ofzo... :/
  • Osiris
Niet echt veel belangstelling voor een onderzoekje blijkbaar :'(
  • QlimaX
  • Laatst online: 02-09 12:13
Nou ik heb nu ook de 2600We, en volgens mij zit die firmware er al op :D
  • Osiris
QlimaX schreef op 26 June 2003 @ 22:07:
Werkt prima verder? UPnP ook eventueel?
  • QlimaX
Yep, heb 'm net aangezet en kan bij MSN iig versturen.
