pinnacle pctv rave xawtv
Ja jullie zullen denken alweer zo'n pinnacle post: maar ik heb veel gelezen en uitgeprobeert: zie hier:
Als ik dscaler in windoos draai draait ie goed op:
card:pctv rave en tuner: TEMIC 4002 FH5 [PAL B/G]
Op linux slackware 9 heb ik xawtv geinstalleerd; bttv stond er al in.
modules geladen met:
modprobe videodev
modprobe i2c-algo-bit bit_test=1
modprobe tuner type=0
modprobe bttv card=39 pll=1
modprobe msp3400
modprobe tvmixer
dga uitgeschakelt in XF86Config: Option "omit xfree86-dga" # don't initialise the DGA extension
output dmesg:
29
30
31
32
33
34
35
36
37
38
39
Linux video capture interface: v1.00
i2c-core.o: i2c core module
i2c-algo-bit.o: i2c bit algorithm module
i2c-core.o: driver i2c TV tuner driver registered.
bttv: driver version 0.7.96 loaded
bttv: using 4 buffers with 2080k (8320k total) for capture
bttv: Host bridge is Intel Corp. 82815 815 Chipset Host Bridge and Memory Controller Hub
bttv: Bt8xx card found (0).
PCI: Enabling device 02:0c.0 (0004 -> 0006)
PCI: Assigned IRQ 10 for device 02:0c.0
bttv0: Bt848 (rev 18) at 02:0c.0, irq: 10, latency: 32, mmio: 0xf2800000
bttv0: using: BT848A(Pinnacle PCTV Studio/Ra) [card=39,insmod option]
i2c-algo-bit.o: Adapter: bt848 #0 scl: 1  sda: 1 -- testing...
i2c-algo-bit.o:1 scl: 1  sda: 0
i2c-algo-bit.o:2 scl: 1  sda: 1
i2c-algo-bit.o:3 scl: 0  sda: 1
i2c-algo-bit.o:4 scl: 1  sda: 1
i2c-algo-bit.o: bt848 #0 passed test.
tuner: probing bt848 #0 i2c adapter [id=0x10005]
tuner: chip found @ 0xc0
bttv0: i2c attach [client=Philips PAL_BG (FI1216 and compa,ok]
i2c-core.o: client [Philips PAL_BG (FI1216 and compa] registered to adapter [bt848 #0](pos. 0).
i2c-core.o: adapter bt848 #0 registered as adapter 0.
bttv0: i2c: checking for MSP34xx @ 0x80... not found
bttv0: miro: id=1 tuner=0 radio=no stereo=no
bttv0: using tuner=0
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
tvaudio: TV audio decoder + audio/video mux driver
tvaudio: known chips: tda9840,tda9873h,tda9874h/a,tda9850,tda9855,tea6300,tea6420,tda8425,pic16c54 (PV951)
i2c-core.o: driver generic i2c audio driver registered.
bttv0: registered device video0
bttv0: registered device vbi0
i2c-core.o: driver i2c msp3400 driver registered.
i2c-core.o: driver tv card mixer driver registered.
tvmixer: debug: Philips PAL_BG (FI1216 and compa
bttv0: PLL: 28636363 => 35468950 ... ok
tuner: TV freq (0.-6) out of range (44-958)
output van v4l-conf:
mode: 1024:768, depth=16,bpp=16,bpl=2048,base=0xf4000000
/dev/video0 [v412]: ioctl VIDIOC_QUERYCAP: Invalid argument
/dev/video0 [v4l]: configuration done
output: v4vl-info:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
general info
    VIDIOCGCAP
   name                    : "BT848A(Pinnacle PCTV Studio/Ra)"
   type                    : 0xeb [CAPTURE,TUNER,OVERLAY,CLIPPING,FRAMERAM,SCALES]
   channels                : 3
   audios                  : 1
   maxwidth                : 924
   maxheight               : 576
   minwidth                : 48
   minheight               : 32
channels
    VIDIOCGCHAN(0)
   channel                 : 0
   tuners                  : 1
   flags                   : 0x3 [TUNER,AUDIO]
   type                    : TV
   norm                    : 0
    VIDIOCGCHAN(1)
   channel                 : 1
   tuners                  : 0
   flags                   : 0x2 [AUDIO]
   type                    : CAMERA
   norm                    : 0
    VIDIOCGCHAN(2)
   channel                 : 2
   tuners                  : 0
   flags                   : 0x2 [AUDIO]
   type                    : CAMERA
   norm                    : 0
tuner
    VIDIOCGTUNER
   tuner                   : 0
   rangelow                : 0
   rangehigh               : 4294967295
   flags                   : 0x7 [PAL,NTSC,SECAM]
   mode                    : PAL
   signal                  : 0
audio
    VIDIOCGAUDIO
   audio                   : 0
   volume                  : 0
   bass                    : 0
   treble                  : 0
    VIDIOCGPICT
   brightness              : 32768
   hue                     : 32768
   colour                  : 32512
   contrast                : 27648
   whiteness               : 0
   depth                   : 16
   palette                 : RGB565
buffer
    VIDIOCGFBUF
   base                    : 0xf4000000
   height                  : 768
   width                   : 1024
   depth                   : 16
   bytesperline            : 2048
window
    VIDIOCGWIN
   x                       : 232
   y                       : 260
   width                   : 384
   height                  : 288
   chromakey               : 0
   flags                   : 0
xawtv instellingen:
TV norm: PAL
Video-source: Television
audio-mode: mono
Frequenty-table: europa-west
Capture: overlay (ook capture: grabdisplay geprobeert)
Ik kom niet verder als blauw beeld: In de readme staat:
Ok you have a blue screen: good overlay is working.A blue screen is what you get if the grabber chip has no input signal:
oplossing: pick another video source
ot tuner type is wrong;check de driver configuration.
Dus ik heb nog wat verschillende tuners types geprobeert. De temic 4002 FH5 is
type=0 of type=14 volgens:
/usr/src/linux/Documentation/video4linux/bttv/CARDLIST
xawtv -noxv?
  • CT
  • Laatst online: 13:21
CT
gebruik TVTime ofzo :P en verder, het blauwe beeld komt omdat je op een tv-kaart ook de 'out/in' moet kiezen, dus 0=tuner, 1=svideo, 2=aux (random volgorde, weet de echte niet) en dat moet je aangeven in de configuratie vvan bijv. xawtv. Bij tvtime en mplayer weet ik wel dat het makkelijk kan kiezen.. xawtv nooit gebruikt omdat ik daar altijd gezeik mee had :P
ps. default staat die dus vaak op aux/svideo, daarom blauwbeeld (net zoals een tv die wacht op input van de videorecorder).
[ Voor 17% gewijzigd door CT op 22-06-2003 13:50 ]
  • a casema user
  • Laatst online: 11-09 10:39
The latest stable release is version 0.7.106
Dus download eerst eens de nieuwe bttv drivers en installeer die.
Dan hoef je ook geen parameters mee te geven welke tuner er op de kaart zit en welke kaart je hebt want dat moet die echt automatisch achterkomen.
Bij mij (PCTV PRO) is het ook gelukt met de nieuwste drivers, niet de oudere.
Taaaa taa taa taaaa taa taa ta taaataaaaa.
