[USB versterker] Yamaha AP-U70 - doen of niet?
  • 1.623 views sinds 30-01-2008
  • jagermeister
  • Laatst online: 04-10 12:23
jagermeister
Artillerie magneet :-(
Zie in de Telegraaf een interresante aanbieding staan. Een Yamaha AP-U70 USB Home Cinema versterker voor 50 Euro
Speakers worden niet meegeleverd!!
Afbeeldingslocatie: http://www.areadvd.de/images/yamahaapu70front.jpg
Afbeeldingslocatie: http://www.areadvd.de/images/yamahaapu70rear.jpg
The AP-U70 is the ideal way to upgrade the sound card in your laptop or desktop computer. The CAVIT AP-U70 is a self contained integrated amplifier that will deliver high performance sound quality via passive speakers. With 20 watts of output power per channel it surpasses most powered speakers output levels. This system is truly for the audio fanatic who listens to their collection of MP3 music and want to enjoy them clean, clear and loud!
Easy to installs it provides you with the latest in technology, including Dolby Digital and DTS processing into Virtual Modes. If you're using your computer for audio recordings then this unit is a must have.
EXTERNAL AUDIO SOUNDBOARD AMPLIFIER FOR COMPUTERS
The AP-U70 is a 2-channel amplifier featuring Virtual DTS and Virtual Dolby Digital decoding that connects to a Computer via USB cable. Just add speakers and your ready to enjoy.
MULTI-FORMAT DIGITAL CAPABILITY
The AP-U70 is compatible with all audio formats from the computer including MP3, WMA, DVD, Computer Games, Extended Wave File Multi-Channel sound, and Direct Sound 3D, as well as providing Yamaha's DSP
VIRTUAL SURROUND SOUND
The processor provides 2/4/5.1 channels of Dolby Digital and DTS decoding and delivers it via Virtual Dolby Digital and DTS an incredible surround experience using only two powered speakers.
MULTI-CHANNEL SOUND VIA USB
Rather than process audio within the computer, the AP-U70 is linked to a Computer via a USB cable that takes the audio from the computer digitally for processing within the amplifier's processor. The result is a pure and accurate audio signal.
VERSATILE RECORDING CAPABILITY
The AP-U70 provides a bridge to record any analog to digital, digital to digital on to your hard drive while at the same time include the DSP effects to your recordings.
24-BIT / 96 kHz USB AUDIO PLAYBACK
True digital audio fidelity from computer sources.
FULL PC USER INTERFACE CONTROL
The AP-U70 can be easily controlled via the GUI (graphical user interface) supplied with the unit.
REMOTE CONTROL
The unit comes with an easy-to-use remote control.
SOPHISTICATED DIGITAL EQUALIZER
The AP-U70 features a sophisticated 7-band equalizer that's adjustable through 13 steps.
MULTIPLE INPUTS AND OUTPUTS
Inputs include 3 computer inputs via USB, Digital (coaxial/optical), and Analog. Aux. 1 provides an analog input and a digital optical input. Aux. 2 has an analog input. In addition, the amplifier has analog and digital outputs with subwoofer output and headphone outputs.
YAMAHA DSP ENGINE
Yamaha's YSS-928 ASIC Application Specific Integrated Circuit provides Silent Cinema surround for headphones and Virtual Surround. Same Chipset found on Yamaha High Performance Home Theater Products.
MULTI-PLATFORM
The AP-U70 is compatible with Win98, Win98SE, Win ME, Win2000, Mac OS 9.1 or higher.
Ik heb de search gebruikt, maar de topics die ik vond zijn al redelijk oud en bovendien gaan ze niet specifiek over deze versterker.
Ik heb momenteel een SB live in mijn PC'tje waarop een Creative Inspire 5300 5.1 setje is aangesloten. Nu begrijp ik uit bovenstaand verhaal dat die Yamaha versterker een vervanging is van je huidige geluidskaart, maar is het wel beter voor het maken van muziek (Reason 2.5) dan die Live denken jullie, of kan ik het vooralsnog beter bij die Live houden? Het ziet er natuurlijk wel gelikt uit zo'n ding op je buro (naast zilverkleurig tft-scherm) Wat ik me ook afvraag is of de driver ondersteuning wel goed is en hoe zit het met het spelen van Games? In bovenstaand verhaal staat dat dat geen probleem moet zijn, maar is dat ook zo? Kan ik mijn Creative setje hier ook op aansluiten of gaat dat niet?
Mensen die dit apparaat hebben of kennen graag commentaar.
- specs - Download mijn custom BF2 map HIER NIET MEER
  • Eskimootje
  • Laatst online: 08:04
USB geeft een gigantische lag als je er geluid mee afspeelt mijn advies: niet kopen.
  • jagermeister
jagermeister
Eskimootje schreef op 20 June 2003 @ 10:19:
Dus Latency zal hoger liggen dan bij mijn Live?
  • Baur
Baur
Opperlurker
jagermeister1 schreef op 20 June 2003 @ 10:16:
De U70 is stereo dus je kunt je speakerset er niet op aansluiten, of je kiest voor 2.1 geluid. Of je moet proberen de U200 te vinden, die is wel helemaal 5.1.
Windows XP herkent de U70 automatisch, dus je hoeft in feite geen drivers te installeren. De software die erbij zit kun je gebruiken om aanpassingen te maken in de presets die op de versterker zitten.
Hij ondersteund geen AEX of A3D, dus als je veel spellen speelt kan dat een nadeel zijn.
The need for speed drives me
  • jagermeister
jagermeister
Baur schreef op 20 juni 2003 @ 11:48:
Ok duidelijk, maar zou mijn huidige videokaart eruit gehaald (of uitgeschakeld) moeten worden. Hoe zit het met Latency als je via de USB poorten geluid uitstuurd?
is wel een kwijl ding zeker aangezien er al 2 x 20 watt rms inzit hang er een paar mooie speakers aan en je hebt de best denkbare 2.1 geluids setup.
edit/ waar eigenlijk in de telegraaf?
[ Voor 13% gewijzigd door Verwijderd op 20-06-2003 11:52 ]
  • JvS
  • Laatst online: 09:37
JvS
Ik heb hem zelf ook
Ik denk dat je geluidskaart bedoelt? Nee die hoef je er niet uit te halen, windows snapt meerdere geluidskaarten. Je moet er el eentje 'primary' maken, alle spellen en windowsgeluiden zullen dan door die worden weergegeven en de secondary wordt alleen aangesproken als je dat echt wil (en instelt) in een programma. Geluidsprogramma's knnen dat wel, winamp kan dat ook, spellen kunnen dat weer niet.
je kan ze dus naast elkaar gebruiken. Overigens over de kwaliteit vind je in die oude topics wel genoeg hoor :). Dat apparaat is niet veranderd :P (Zie topic van JT,. "welk apparaat is dit" ofzo).
  • jagermeister
jagermeister
Verwijderd schreef op 20 June 2003 @ 11:51:
Pagina 8 onderaan.
Idd een zeer mooi ding. Jammer dat het geen 5.1 aansluitmogelijkheid heeft.
Maaruh...USB en Latency, hoe zit dat dan?
JvS schreef op 20 juni 2003 @ 11:53:
Aha...ok dat is opzich wel relaxed, kan ik gewoon mijn spellen via de Live spelen en mp3 en muziek maken via de Yamaha...
Tja je hebt gelijk betreft dat oudere topic, maar ik wilde er toch nog wat meer over vragen dan daar wordt behandeld en om dan meteen zo'n oud topic naar boven te schoppen...
[ Voor 54% gewijzigd door jagermeister op 20-06-2003 11:58 ]
  • Baur
Baur
Opperlurker
jagermeister1 schreef op 20 June 2003 @ 11:54:
Pagina 8 onderaan.
Als je 5.1 zoekt moet eens rondkijken naar de AP-U200, misschien dat de correct die nog heeft?
Maar ik merk niets van latency of iets dergelijks met mijn U70.
  • jagermeister
jagermeister
Baur schreef op 20 juni 2003 @ 11:59:
Ga ik doen...misschien dat ik er na mijn werk ff langsrijdt :)
Latency mag ik echt zo min mogelijk last van hebben (max. 25ms ofzo), omdat ik via een Midicontroller de softsynthesizers in Reason aanstuur. Zit daar een merkbare vertraging in dan heeft het weinig zin.
EDIT: Kan ik dit apparaat eigenlijk niet rechtstreeks aansluiten op die SB Live? Dan is hoeft Windows ook geen 2 kaarten te herkennen.
[ Voor 13% gewijzigd door jagermeister op 20-06-2003 13:00 ]
  • robbynaish
  • Laatst online: 08-10 13:38
kan ik deze gebruiken voor het digitale geluid naar mijn 5.1 versterker?
Ik zag wel dat hij 2.1 was maar dat hij ook digitale uitgangen heeft.
Dus vanaf mijn pc digitaal doorsturen naar mijn versterker. Voor het bekijken van dvd en divx met ac3.
Of werkt dat niet?
bij welk bedrijf issie te koop overigens?
robbynaish schreef op 14 november 2003 @ 10:12:
Of werkt dat niet?
Ja dat kan, hij heeft een Coax en Optische SPdif ingang, dus met een SB Live of Terratec kaart etc is het geen probleem. Hij heeft als output alleen een optische uitgang dus die moet je DD versterker dan wel hebben.
Bij nader inzien weet ik eigenlijk niet hoe hij overweg gaat met een DD signaal. Ze adverteren wel leuk met Virtual DD/DTS maar of en hoe dat weet ik niet.
Bij nog meer inzien wil je hem natuurlijk via USB aansluiten, ik weet niet of dat werkt, ik ga het wel even voor je uitzoeken. Damn, ben er niet helemaal bij met me hoofd vandaag.
Het is wel een kewl ding, latency is voor een normale gebruiker niet echt boeiend en is ook wel cool dat je hem via de pc kan uitschakelen etc.
Verwijderd schreef op 14 november 2003 @ 12:19:
Als je snel bent kun je er in Rotterdam bij Correct in de koopjeskelder nog eentje halen. Daar zag ik er laatst nog een stuk of 10 staan. :)
  • robbynaish
Dus kan ik met de u70 zonder geluidskaart ac3 doorgeven naar mijn andere versterker.
Dus van pc met usb naar de u70 en daar vandaan optisch naar mijn digitale versterker waarop mijn boxen zijn aangesloten.
lukt dat nu? of kan ik dan beter voor deze philips gaan.
Afbeeldingslocatie: http://www.p4c.philips.com/files/p/psc805_17/psc805_17_ihr_us.jpg
  • -DarkShadow-
er zijn ASIO (zo heet dat toch) drivers voor bijna alle USB geluidskaarten beschikbaar op www.download.com In bijna alle USB geluidskaarten zit een ICtje van dezelfde TI familie.
Specialist in:
Soldeerstations
Oscilloscoop
