Cisco 801 BRI interfaces down
Heej, ik heb een 801 geconfigged voor router router verkeer en voor een internet verbinding. nu is de BRI interface down.
Waarschijnlijk is dit ook de reden waarom het internetten niet lukt.
Nu ben ik tot nu toe lekker autodidactisch bezig geweest alleen kom ik hier niet uit.
BRI0 is administratively down, line protocol is down
Hardware is BRI with S/T interface
Internet address is 195.0.238.1/8
MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation PPP, loopback not set
Last input never, output never, output hang never
Last clearing of "show interface" counters 00:34:20
Input queue: 0/75/0 (size/max/drops); Total output drops: 0
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/16 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
5 minute input rate 0 bits/sec, 0 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 0 interface resets
0 output buffer failures, 0 output buffers swapped out
0 carrier transitions
en
Dialer1 is up (spoofing), line protocol is up (spoofing)
Hardware is Unknown
Description: verbinding naar ISP XS4ALL
Internet address is 194.109.61.52/24
MTU 1500 bytes, BW 56 Kbit, DLY 20000 usec,
DTR is pulsed for 1 seconds on reset
Last clearing of "show interface" counters 01:23:04
Ethernet0 is up, line protocol is up
Hardware is PQUICC Ethernet, address is 00b0.c288.bc1d (bia 00b0.c288.bc1d)
Internet address is 194.0.1.1/24
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Encapsulation ARPA, loopback not set
Keepalive set (10 sec)
ARP type: ARPA, ARP Timeout 04:00:00
Last input 00:00:00, output 00:00:03, output hang never
Last clearing of "show interface" counters never
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 1000 bits/sec, 1 packets/sec
6216 packets input, 1036491 bytes, 0 no buffer
Received 4035 broadcasts, 0 runts, 0 giants, 0 throttles
0 input packets with dribble condition detected
1774 packets output, 229832 bytes, 0 underruns
0 output errors, 22 collisions, 1 interface resets
0 babbles, 0 late collision, 5 deferred
0 lost carrier, 0 no carrier
zit er een foutje in de config ?
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
service compress-config
hostname hthk
enable secret 5 <knip>.
enable password 7 <knip>
username ht999 password 7 <knip>
ip subnet-zero
no ip domain-lookup
ip name-server 194.109.6.66
ip name-server 194.109.9.99
isdn switch-type basic-net3
isdn tei-negotiation first-call
process-max-time 200
interface Ethernet0
ip address 194.0.1.1 255.255.255.0
no ip directed-broadcast
ip nat inside
interface BRI0
ip address 195.0.238.1 255.0.0.0
ip nat inside
encapsulation ppp
shutdown
dialer map ip 195.0.2.1 name ht999 (msn-nummer)
dialer-group 1
compress stac
ppp authentication chap
interface Dialer1
description verbinding naar ISP XS4ALL
ip address 194.109.61.52 255.255.255.0
ip nat outside
encapsulation ppp
dialer remote-name ISP
dialer idle-timeout 180
dialer string 80793611011
dialer hold-queue 10
dialer load-threshold 180 outbound
dialer pool 1
dialer-group 1
no cdp enable
ppp quality 50
ppp authentication pap chap callin
ppp pap sent-username user@xs4all.nl password 7 <knip>
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source static tcp 194.0.1.3 25 194.109.61.52 25 extendable
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 194.0.2.0 255.255.255.0 195.0.2.1
line con 0
exec-timeout 0 0
transport input none
stopbits 1
line vty 0 4
password 7 <knip>
login
end
Jaja het zijn lappen text. Maar ik wil het wel graag weten (ook of het een beetje nette config is)
  • igmar
  • Laatst online: 26-09 18:37
igmar
ISO20022
Verwijderd schreef op 18 June 2003 @ 15:42:
conf t
int BRI0
no shutdown
end
zou het moeten doen.
igmar schreef op 18 June 2003 @ 15:48:
conf t
int BRI0
no shutdown
end
Klinkt heel logisch..... :/
Dit brengt de interface idd op maar werken ho maar.
[ Voor 12% gewijzigd door Verwijderd op 18-06-2003 16:29 ]
  • Harrie666
  • Laatst online: 20-09 17:38
begin eens wat te debuggen.
debug ppp
debug dialer
wat krijg je bij een show ip interface brief ?
Je hebt op zowel je BRI als op je dialer een IP adres gezet (waar heb je die vandaan??). Bovendien kan je op je interne netwerk beter RFC1918 adressen gebruiken, bijvoorbeeld 192.168.0.0/16
[ Voor 26% gewijzigd door Verwijderd op 18-06-2003 21:08 ]
  • sniper20
  • Laatst online: 10-10 23:05
Ik zou bij Bri0 zoiets neerzetten :
interface BRI0
no ip address
ip nat outside
encapsulation ppp
dialer pool-member 1
no cdp enable
en bij dialer1 :
interface Dialer1
ip address negotiated (In geval van DHCP van provider)
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 181
dialer string 123456789
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username user password xxxxxxx
Het is maar een voorbeeld, die ik uit een andere config heb geplukt.
Als je je RFC1918 range intern hebt, kan je deze ook lozen "ip route 194.0.2.0 255.255.255.0 195.0.2.1" ...dan is hij directly connected..(eth0)..tenzij je op 195.0.2.1 een doos hebt die routeerd.
Zoals Sniper ook al melde...bij PPP Auth...niet chap en pap tegelijk zetten..wil vaak de boel verstieren...
Voor het snelste troubleshooting...werk het osi model af.
L1: http://www.cisco.com/en/U...ote09186a0080094b76.shtml
L2: http://www.cisco.com/en/U...ote09186a0080094b77.shtml
L3:
http://www.cisco.com/en/U...ote09186a0080093c1a.shtml
Feel leesplezier en good luck... 8)7 ...als je klaar bent dan gaan we routeren :9
p.s. is vnl amerikaans dus houd't het op basci net 3 en vergeet het SPID verhaal...is allen van belang bij ISDN centrales/PABX'en
[ Voor 10% gewijzigd door Verwijderd op 19-06-2003 00:56 ]
  • Equator
  • Laatst online: 20-10 17:05
Equator
Crew Council
🦺#Rodekruis #whisky #barista
Volgens mij kan je niet een Dialer Map EN een Dialer1 gebruiken.
Ik ben zelf altijd fan geweest van Dialer's dus ik zou een Dialer1 en Dialer2 maken.
Daarna gewoon goed routeren..
Ohja, welke versie van je IOS heb je ??
Standaard werd de 801 serie uitgeleverd met ik meen IOS versie: 12.1
En daar zat een ppp bug in..
[ Voor 31% gewijzigd door Equator op 19-06-2003 08:07 ]
