vervelende ondertitel
  • 92 views sinds 30-01-2008
Ik klikte op de ondertitel van de gebuiker "basiep", onder deze link zat :
c:/con/con
De meesten weten wel wat dit betekend, je computer loopt hierdoor vast. vervelend voor de mensen met win95 of win98 zonder patch
http://gathering.tweakers.net/forum/list_messages/76542
  • Servowire
  • Laatst online: 07:53
Servowire
prutser:~#
Een beetje tweaker heeft al een update hiervoor ;)
Ik vind dit wel kunnen hoor
gewoon kijken voor je klikt :)
met papier mache kun je alles maken!!
  • BasieP
  • Laatst online: 19-10-2025
tof he!
of niet...?
This message was sent on 100% recyclable electrons.
  • Servowire
Servowire
prutser:~#
wel oud
  • PcDealer
  • Laatst online: 29-09 22:26
PcDealer
HP ftw \o/
Dit geeft MSIE 5.00.2314.1003CO onder WinNT4.0 (SP5):
The page cannot be displayed
The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings.
Please try the following:
Click the Refresh button, or try again later.
If you typed the page address in the Address bar, make sure that it is spelled correctly.
To check your connection settings, click the Tools menu, and then click Internet Options. On the Connections tab, click Settings. The settings should match those provided by your local area network (LAN) administrator or Internet service provider (ISP).
If your Network Administrator has enabled it, Microsoft Windows can examine your network and automatically discover network connection settings.
If you would like Windows to try and discover them,
click Detect Network Settings
Some sites require 128-bit connection security. Click the Help menu and then click About Internet Explorer to determine what strength security you have installed.
If you are trying to reach a secure site, make sure your Security settings can support it. Click the Tools menu, and then click Internet Options. On the Advanced tab, scroll to the Security section and check settings for SSL 2.0, SSL 3.0, TLS 1.0, PCT 1.0.
Click the Back button to try another link.
Cannot find server or DNS Error
Internet Explorer
:D
LinkedIn WoT Cash Converter
  • wildhagen
wildhagen
Blablabla
nogal logisch, want /con/con werkt alleen op Win9x-machines, dus niet op NT/2K. En ik neem aan ook niet op ME.
Virussen? Scan ze hier!
  • BasieP
ik wou net zeggen want ik heb namelijk versie 5.00.2614.3500IC en daar doet hij het ook!
  • Servowire
Servowire
prutser:~#
Snue hoor
c:/con/con
of www.ducks.cjb.net
Wat wil je ermee bereiken!!
Zulke ondertitels moeten gebanned worden (de makers ook)
  • BasieP
Op zondag 26 november 2000 20:08 schreef AmAnido het volgende:
Snue hoor
c:/con/con
je was zeker zo stom om er op te klikken!
en nu pissig. Kijk jij wel waar je klikt??>:)
Op zondag 26 november 2000 20:13 schreef basiep het volgende:
en nu pissig. Kijk jij wel waar je klikt??>;)
Ik heb deze een keer via icq naar jouw gestuurd, jij klikte wel :) :)
hmmmzz, tja... tis vet irritant! gelukkig met Win2K ff iexplorer.exe killen en tis weer gebeurd ;)
  • 4POX
  • Laatst online: 11:52
4POX
Everybody is wired
Bannen die eikel. Mijn win2000 begon te flippen met zijn link
AKA Rinkel weblog
  • BasieP
ik verander het wel
ook al snap ik niet dat jullie te stom/nieuwschierig zijn om na te denken.
Ik zet er niet voor niks bij NOT
Als er op een muur staat: 'Nat!'
Gaan jullie dan ook ff voelen of hij echt nog nat is...:)
LOL...
...He
ik zie nu dat het al weggehaald is..Wat zal ik er nu is neerzetten??
  • BasieP
Beter zo?!
:o:D;):)
[beetje offtopic]
Ik kom niet meer bij :D
En maar zeuren dat er hier teveel non-tweakers komen.
"Zelfs ik" wist dit!
[/beetje offtopic]
  • BasieP
beetje gezeur he!
Nou, ik kom niet meer bij van het lachen.
kinderachtig...:r
Tsja, ieder z'n eigen gevoel voor humor hè?
Mij hoor je er niet over.
Maar omdat deze topic samen met die over het OF in de top 3 van LA stond, heb ik een linkje ertussen gelegd...
  • me1299
  • Laatst online: 28-10 18:17
me1299
$ondertitel
Kan iemand gelijk ff een url geven voor de patch voordat ik weer eens naar http://www.stellendam.net ga ofzo
Het maakt eigenlijk niet uit wat je bewuste geest doet, omdat je onderbewuste automatisch precies dat doet wat het moet doen
  • Nietzman
  • Laatst online: 27-10 19:26
Nietzman
Woei!
Een beetje twieker draait GEEN win98/98 :)
fiets
  • IceStorm
  • Laatst online: 28-10 20:36
IceStorm
This place is GoT-like!!!
Op donderdag 18 januari 2001 21:51 schreef J_da_man het volgende:
fiets
Uhm ja tuurlijk :?
  • Muggie
  • Laatst online: 27-10 18:08
Muggie
8 pm
Stelletje zeikers, gewoon die link niet aanklikken dan heb je ook nergens last van. Gaan we nu over alles mierenneuken ?
PSN: mug_8pm
  • IceStorm
IceStorm
Even voor de duidelijkheid.. dit bericht is van 2 maanden geleden......
  • Muggie
Muggie
8 pm
Aardbei O+
PSN: mug_8pm
  • alt-92
alt-92
ye olde farte
kippesoep.
En dicht graag.
