Webalizer compilatie error
Oke... ben geen newby, maar hier begrijp ik niks van
[root@server webalizer-2.01-10]# make
gcc -Wall -O2 -DETCDIR=\"/etc\" -DHAVE_GETOPT_H=1 -DHAVE_MATH_H=1 -c webalizer.c
gcc -Wall -O2 -DETCDIR=\"/etc\" -DHAVE_GETOPT_H=1 -DHAVE_MATH_H=1 -c hashtab.c
gcc -Wall -O2 -DETCDIR=\"/etc\" -DHAVE_GETOPT_H=1 -DHAVE_MATH_H=1 -c linklist.c
gcc -Wall -O2 -DETCDIR=\"/etc\" -DHAVE_GETOPT_H=1 -DHAVE_MATH_H=1 -c preserve.c
gcc -Wall -O2 -DETCDIR=\"/etc\" -DHAVE_GETOPT_H=1 -DHAVE_MATH_H=1 -c dns_resolv.c
gcc -Wall -O2 -DETCDIR=\"/etc\" -DHAVE_GETOPT_H=1 -DHAVE_MATH_H=1 -c parser.c
gcc -Wall -O2 -DETCDIR=\"/etc\" -DHAVE_GETOPT_H=1 -DHAVE_MATH_H=1 -c output.c
gcc -Wall -O2 -DETCDIR=\"/etc\" -DHAVE_GETOPT_H=1 -DHAVE_MATH_H=1 -I/usr/include -c graphs.c
cc1: let op: changing search order for system directory "/usr/include"
cc1: let op: as it has already been specified as a non-system directory
gcc -L/usr/lib -o webalizer webalizer.o hashtab.o linklist.o preserve.o parser.o output.o dns_resolv.o graphs.o -lgd -lpng -lz -lm
graphs.o: In function `year_graph6x':
graphs.o(.text+0x5aa): undefined reference to `gdImagePng'
graphs.o: In function `month_graph6':
graphs.o(.text+0x126d): undefined reference to `gdImagePng'
graphs.o: In function `day_graph3':
graphs.o(.text+0x1bd5): undefined reference to `gdImagePng'
graphs.o: In function `pie_chart':
graphs.o(.text+0x2338): undefined reference to `gdImagePng'
collect2: ld gaf exit-status 1 terug
make: *** [webalizer] Fout 1
Ziet er naaruit dat je gd niet of niet goed is geinstalleerd/geconfigureerd.
Ja maar die heb ik net ook geinstalleerd... dus moet volgens mij goed zitten
Dit is trouwens wat ie doet bij ./configure
[root@server webalizer-2.01-10]# ./configure
creating cache ./config.cache
checking for gcc... gcc
checking whether the C compiler (gcc ) works... yes
checking whether the C compiler (gcc ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking whether ln -s works... yes
checking for a BSD compatible install... /usr/bin/install -c
checking how to run the C preprocessor... gcc -E
checking whether char is unsigned... no
checking for main in -l44bsd... no
checking for main in -lm... yes
checking for main in -lz... yes
checking for gzrewind in -lz... yes
checking for main in -lpng... yes
checking for gdImagePng in -lgd... no
checking for libgd.a... /usr/lib
checking for gd.h... /usr/include
checking for getopt.h... yes
checking for math.h... yes
checking default config dir... /etc
checking for language file... yes - english
updating cache ./config.cache
creating ./config.status
creating Makefile
linking ./lang/webalizer_lang.english to webalizer_lang.h
[ Voor 88% gewijzigd door Verwijderd op 13-06-2003 15:01 ]
  • imdos
  • Laatst online: 10-09 09:50
imdos
I use FreeNAS and Ubuntu
Hij geeft het zelfs al aan! Heb je na de install van gd wel ldconfig gedaan en staat in /etc/ld.so.conf wel de dir waar de gd libs staan :?
pvoutput. Waarom makkelijk doen, als het ook moeilijk kan! Every solution has a new problem
Oke... nu gaat het me iets te snel... heb net wel ldconfig uitgevoerd.. maar wat moet er precies waar staan
Dit staat er in die /etc/ld.so.conf
/usr/kerberos/lib
/usr/X11R6/lib
[ Voor 27% gewijzigd door Verwijderd op 13-06-2003 15:09 ]
  • moto-moi
  • Laatst online: 09-06-2011
moto-moi
Ja, ik haat jou ook :w
Verwijderd schreef op 13 June 2003 @ 15:07:
Je hebt gdimage nodig waarbij png support erin gecompileerd moet worden. Dat is toch vrij duidelijk uit de foutmelding te halen hoor ?
God, root, what is difference? | Talga Vassternich | IBM zuigt
in ld.so.conf zet je alle paden waar je library's in hebt staan. Hiervan word vervolgens een lookup cache gemaakt met ldconfig. Als je gd vers installed, dan moet je die cache wel updaten, anders ziet geen enkele applicatie dat je die libs geinstalled hebt (die kijken naar de cache namelijk)
Ik heb nu net alle padden toegevoegd, maar die
krijg ik maar niet anders... iemand die me een klap kan verkopen zodat ik het licht zie :D
[ Voor 21% gewijzigd door Verwijderd op 13-06-2003 15:34 ]
misschien helpt dit??
./configure --with-gd=/usr/local/.....
[ Voor 25% gewijzigd door Verwijderd op 13-06-2003 16:43 ]
  • RvdH
  • Laatst online: 28-07 15:42
RvdH
Uitvinder van RickRAID
Recompile GD met libpng support, in de GD Readme staat precies beschreven hoe dat moet.
Thx.....
./configure --with-gd=/usr/local/lib/
was de oplossing...
