Hallo ik heb een SONY CD-RW CRX160E brander, en telkens als ik ga branden zegt nero op het laatst burn process failed!
nero allemaal al opnieuw geinstalleerd, en ook andere software geprobeerd.
dit zegt nero's foutlog:
Windows XP 5.1
WinAspi: File 'Wnaspi32.dll': Ver=1.0.0.0, size=21504 bytes, created 8-4-2003 19:39:56
ahead WinASPI: File 'C:\Program Files\ahead\Nero\Wnaspi32.dll': Ver=2.0.1.41, size=155715 bytes, created 8-6-2003 13:11:08
Nero Version: 5.5.7.2
Recorder: <SONY CD-RW CRX160E> Version: 1.0e - HA 2 TA 1 - 5.5.7.2
Adapter driver: <atapi> HA 2
Drive buffer : 4096kB
Bus Type : default (0) -> ATAPI
CD-ROM: <Generic STEALTH DVD> Version: - HA 0 TA 0 - 5.5.7.2
Adapter driver: <St320hg> HA 0
Bus Type : default (0) -> SCSI
=== Scsi-Device-Map ===
CdRomPeripheral : Generic STEALTH DVD St320hg Port 0 ID 0 DMA: ?
CdRomPeripheral : Generic STEALTH DVD St320hg Port 0 ID 1 DMA: ?
DiskPeripheral : QUANTUM FIREBALLlct20 40 atapi Port 1 ID 0 DMA: On
DiskPeripheral : ST380021A atapi Port 1 ID 1 DMA: On
CdRomPeripheral : MATSHITA DVD-ROM SR-8586 atapi Port 2 ID 0 DMA: Off
CdRomPeripheral : SONY CD-RW CRX160E atapi Port 2 ID 1 DMA: On
AutoRun : 0
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 61865984 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523764kB)
Free physical memory: 210MB (215532kB)
Memory in use : 58 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Wizard: Off
CueSheet
8.6.2003
13:19:06 #1 Text 0 File Reader.cpp, Line 117
Reader running
13:19:06 #2 Text 0 File Writer.cpp, Line 127
Writer SONY CD-RW CRX160E running
13:19:06 #3 Text 0 File ThreadedTransferInterface.cpp, Line 679
Setup items (original item values)
0: TRM_DATA_RAW_MODE2 (Cue Sheet Track)
2 indices, index0 (150) provided
original CD pos #0 + 300 (300) = #300/0:4.0
relocatable, CD pos for caching/writing not required/not required, no patch infos
1: TRM_DATA_RAW_MODE2 (Cue Sheet Track)
16 indices, index0 (150) provided
original CD pos #0 + 1 + 18867 + 28517 + 37577 + 23599 + 33703 + 21952 + 15945 + 44684 + 17497 + 28475 + 18676 + 24656 + 38218 + 6314 (358681) = #358681/79:42.31
13:19:08 #4 Text 0 File DlgWaitCD.cpp, Line 194
Last possible write address on media: 359848 (79:59.73)
Last address to be written: 359133 (79:50.33)
13:19:09 #5 Text 0 File DlgWaitCD.cpp, Line 1331
Recorder: SONY CD-RW CRX160E;
CDR code: 00 97 17 06; CD manufacturer unknown
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 11 06 (LI 97:17.06), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
13:19:09 #6 Text 0 File ThreadedTransferInterface.cpp, Line 824
Prepare recorder SONY CD-RW CRX160E for write in cue-sheet-DAO
DAO infos:
MCN:
TOCTYPE: 0x20 Close CD
Tracks 1 to 2:
TRM_DATA_RAW_MODE2, 2352/0x0, ISRC "", FilePos 0 352800 1058400
TRM_DATA_RAW_MODE2, 2352/0x0, ISRC "", FilePos 1058400 1411200 845028912
13:19:09 #7 Text 0 File ThreadedTransferInterface.cpp, Line 679
Setup items (after recorder preparation)
-> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 300 blocks [SONY CD-RW CRX160E ]
-> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 358681 blocks [SONY CD-RW CRX160E ]
13:19:09 #8 Phase 24 File dlgbrnst.cpp, Line 1436
Caching of files started
13:19:10 #9 Phase 25 File dlgbrnst.cpp, Line 1436
Caching of files completed
13:19:10 #10 Phase 28 File dlgbrnst.cpp, Line 1436
Speed measurement started
13:19:10 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1950
Verifying CD position of item 0 (relocatable, no CD pos, no patch infos, orig at #0): write at #0
13:19:10 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1950
Verifying CD position of item 1 (relocatable, no CD pos, no patch infos, orig at #0): write at #450
13:20:08 #13 Text 0 File ThreadedTransfer.cpp, Line 219
all writers idle, stopping conversion
13:20:08 #14 Phase 29 File dlgbrnst.cpp, Line 1396
Speed measurement completed: 81.9x (12.285 KB/s)
13:20:08 #15 Phase 32 File dlgbrnst.cpp, Line 1436
Simulation started at 12x (1.800 KB/s)
13:20:10 #16 Text 0 File ThreadedTransferInterface.cpp, Line 1950
13:20:10 #17 Text 0 File ThreadedTransferInterface.cpp, Line 1950
13:20:15 #18 Text 0 File Writer.cpp, Line 304
13:20:15.049 - SONY CD-RW CRX160E : Queue again later (Intervall : 36msec)
13:20:30 #19 Text 0 File Writer.cpp, Line 304
13:20:30.751 - SONY CD-RW CRX160E : Queue again later (Intervall : 36msec)
13:27:03 #20 SCSI -1135 File Cdrdrv.cpp, Line 1411
SCSI Exec, HA 2, TA 1, LUN 0, buffer 0x02EC0054
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x08
CDB Data: 0x2A 0x00 0x00 0x05 0x6D 0x95 0x00 0x00 0x1B 0x00 0x00 0x00
Sense Data: 0xF1 0x00 0x03 0x00 0x05 0x67 0x02 0x12
0x00 0x00 0x00 0x00 0x0C 0x08
13:27:03 #21 mmc -1135 File Writer.cpp, Line 321
Write error
13:27:03 #22 Text 0 File ThreadedTransfer.cpp, Line 219
13:27:03 #23 Phase 34 File dlgbrnst.cpp, Line 1436
Simulation failed at 12x (1.800 KB/s)
13:27:03 #24 Text 0 File Scsicmd.cpp, Line 371
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
srry voor dubbel posten, ik had hem verkeerd gepost en dacht, dan zet ik een nieuwe in de goede rubriek. mijn excuus
Windows XP 5.1
AutoRun : 0
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Use Inquiry : 1
Wizard: Off
CueSheet
8.6.2003
Reader running
ATIP Data:
DAO infos:
MCN:
Tracks 1 to 2:
Sense Code: 0x0C
Sense Qual: 0x08
Write error
Existing drivers:
respect tha DON Don's SPECS
