[Usb adsl] pppoa2/3 wil geen verbinding maken
  • Jap
  • Laatst online: 29-06 14:51
Jap
No worries
Ik ben bezig om mijn usb modem onder linux (debian woody 3.0) aan de praat te krijgen.
Het volgende werkt al,
ik stop mijn usb modem erin, en doe:
mount none /proc/bus/usb -t usbdevfs
dat gaat goed, vervolgens firmware inladen:
modem_run -f /home/xhoy/dsl/mgmt/mgmt.o -m -v 1
en dit gaat ook goed, dat weet ik zkr want /var/log/messages zegt:
Jun 7 23:46:50 Jap-router-01 modem_run[855]: modem_run version CVS_19_11_2002 started by root uid 0
Jun 7 23:46:50 Jap-router-01 modem_run[855]: Found ALCATEL SpeedTouch USB modem
Jun 7 23:46:50 Jap-router-01 modem_run[855]: Best offset 6463 with probability 100%
Jun 7 23:46:51 Jap-router-01 modem_run[855]: Best offset 526179 with probability 100%
Jun 7 23:46:53 Jap-router-01 kernel: usb_control/bulk_msg: timeout
Jun 7 23:46:53 Jap-router-01 kernel: usbdevfs: USBDEVFS_BULK failed dev 4 ep 0x85 len 512 ret -110
Jun 7 23:46:53 Jap-router-01 modem_run[855]: BLOCK1 : 991 bytes uploaded : OK
Jun 7 23:46:53 Jap-router-01 modem_run[855]: BLOCK2 : 511 bytes downloaded : OK
Jun 7 23:46:55 Jap-router-01 modem_run[855]: BLOCK3 : 526187 bytes uploaded : OK
Jun 7 23:46:55 Jap-router-01 modem_run[855]: BLOCK4 : 511 bytes downloaded : OK
Jun 7 23:46:56 Jap-router-01 modem_run[855]: Modem reference : 3EC36656AAAA01
Jun 7 23:47:21 Jap-router-01 modem_run[856]: Received interrupt, len = 6
Jun 7 23:47:21 Jap-router-01 modem_run[856]: Sending a signal to notify the adsl up state
Jun 7 23:47:21 Jap-router-01 modem_run[855]: ADSL synchronization has been obtained
Jun 7 23:47:21 Jap-router-01 modem_run[855]: ADSL line is up (256 kbit/s down | 64 kbit/s up)
so far, so good, maar dan, je moet met pppd call adsl en dit resulteerd in:
Jun 7 23:47:36 Jap-router-01 pppd[857]: pppd 2.4.1 started by root, uid 0
Jun 7 23:47:36 Jap-router-01 pppd[857]: Using interface ppp0
Jun 7 23:47:36 Jap-router-01 pppd[857]: Connect: ppp0 <--> /dev/pts/0
Jun 7 23:47:36 Jap-router-01 pppd[857]: Child process /usr/local/sbin/pppoa2 -vpi 8 -vci 48 (pid 858) terminated with signal 2
Jun 7 23:47:36 Jap-router-01 pppd[857]: Modem hangup
Jun 7 23:47:36 Jap-router-01 pppd[857]: Connection terminated.
Jun 7 23:47:36 Jap-router-01 pppd[857]: Exit.
Jun 7 23:48:18 Jap-router-01 pppd[863]: pppd 2.4.1 started by root, uid 0
Jun 7 23:48:18 Jap-router-01 pppd[863]: Using interface ppp0
Jun 7 23:48:18 Jap-router-01 pppd[863]: Connect: ppp0 <--> /dev/pts/0
Jun 7 23:48:18 Jap-router-01 pppd[863]: Modem hangup
Jun 7 23:48:18 Jap-router-01 pppd[863]: Connection terminated.
Jun 7 23:48:18 Jap-router-01 pppd[863]: Exit.
2x??? jah dat is pppoa2 en pppoa3 (je weet maar nooit :) )
mijn /etc/ppp/peers/adsl ziet er zo uit:
debug
kdebug 1
noipdefault
defaultroute
pty "/usr/local/sbin/pppoa2 -vpi 8 -vci 48"
nodetach
sync
user "Pacthon@zonnet-lite"
kdebug 7
noaccomp
nopcomp
#nomagic
noccp
#passive
#lcp-echo-interval 5
#lcp-echo-failure 30
#persist
in /etc/ppp/chap-secrets staat het user en wachtwoord gebeuren goed,
ik heb deze handleiding gevolgt:
http://benoit.papillault.free.fr/speedtouch/user.en.php3
en alles netjes gedaan, ik heb alles netjes in de kernel gebakken, alleen niet als module maar gewoon in de kernel, maar dit zou niet uit moeten maken.
Heeft iemand mischien een tip waar ik het moet zoeken? mocht je meer moeten weten moet je het zeggen dan post ik het even.
Nieuws en informatie over IPv6 @ Fix6.net | Hosting met IPv6 nodig? Bekijk de IPv6-hosters lijst op Fix6.net/ipv6-webhosting
  • The_Greater
  • Laatst online: 10-09 13:53
ff mijn router boekje erbij gepakt
Versatel : VPI 0, VCI 32, Protocol PPPoA, Encapsulation VC-MUX
Versatel (new) : VPI 0, VCI 32, Protocol RFC1483bridged, Encapsulation LLC
[ Voor 89% gewijzigd door The_Greater op 07-06-2003 23:49 ]
Working in the IT : "When you do things right, people won't be sure you've done anything at all"
  • Jap
Jap
No worries
using channel 1
Connect: ppp0 <--> /dev/pts/2
Child process /usr/local/sbin/pppoa2 -vpi 0 -vci 32 (pid 249) terminated with signal 2
Modem hangup
neej, doet prcies het zelfde (pppoa2 en 3)
[edit]
0 en 0?? als ik me man van pppoa3 er op na kijk staat voor nl die -vpi 8 -vci 48 en dat vindt ik ook steeds op alle usb/adsl sites terug!
[edit2]
nope zowel met als zonder quotes maakt niets uit
[edit3]
nee ok, dan staat dat teminste goed, maar wat zou het anders kunnen zijn?
[ Voor 45% gewijzigd door Jap op 07-06-2003 23:52 ]
  • The_Greater
Ik heb zelf Zonnet-family. Ik ben niet zo thuis in Linux, maar horen die "" wel bij je username?
edit 1:
Dit heb ik rechtsstreeks uit mijn router boekje gehaald.
edit 2:
mijn fout.. idd het moet VCI 32 zijn!
[ Voor 49% gewijzigd door The_Greater op 07-06-2003 23:49 ]
  • The_Greater
Weet je ook zeker dat je PPPoA hebt geprobeerd? Want de verbing staat. Het lijkt er op dat er wat verkeerde protocol gebruikt, terminated with signal 2
[ Voor 18% gewijzigd door The_Greater op 07-06-2003 23:55 ]
  • Jap
Jap
No worries
sorry hoe bedoel je? pppoA? gewoon pppoa2 en pppoa3? dat zijn toch de goede? is er nog iets anders dan?
  • The_Greater
ver vang deze regel eens:
naar
pty "/usr/local/sbin/pppoa -vpi 0 -vci 32"
nu houdt mijn kennis ook wel een beetje op |:(
[ Voor 32% gewijzigd door The_Greater op 07-06-2003 23:58 . Reden: Er wordt wel veel geedit he! ]
  • Jap
Jap
No worries
Jap-router-01:~# /usr/local/sbin/pppoa
bash: /usr/local/sbin/pppoa: No such file or directory
  • The_Greater
Het gaat om dit stukje :
Het gaat daar ergens mis? Of zit ik er naast?
Dan zal het wel pppoa1 zijn, lijkt me.
En anders, heb je wel een password bij zitten? Ik neem aan dat je die regel weg hebt gelaten.
  • Jap
Jap
No worries
The_Greater schreef op 08 June 2003 @ 00:05:
pppoa1 bestaat niet, en zoals in start post:
Ten eerste zou ik eens hier kijken, de HOWTO is flink wat groter.
http://linux-usb.sourceforge.net/SpeedTouch/
Ten tweede, is het modem wel pppoa, want mijn modem gebruikt naar de buitenwereld pppoa, maar naar de computer vertaalt ie de packages naar pppoe.
(E-Tech, zonnet family)
Hoe je pppoe moet instellen kun je lezen op de bovenstaande link, in de HOWTO.
  • DGTL_Magician
  • Laatst online: 30-08 12:07
DGTL_Magician
Kijkt regelmatig vooruit
The_Greater schreef op 07 June 2003 @ 23:37:
Dat zijn land waardes. Hier in Nederland is het VPI 8 VCI 48, dus dat heeft TS iig goed.1
Blog | aaZoo - (Wireless) Networking, Security, DDoS Mitigatie, Virtualisatie en Storage
Die " weghalen! Heb je de juiste modules geladen? Je vpi/vci waardes zijn goed, 8 - 48. Hoe zien je pap-secrets d'r uit en chap-secrets? Ligt aan welke je gebruik, die moet er zo uit zien, zonder qoutes:
pc1-srv-01:/etc/ppp# cat pap-secrets
username@adsl-comfort "*" wachtwoord
Ik heb de speedtouch adsl ook, ding werkt perfect.
Waar staat TS voor, ik vraag 't me al een lange tijd af.
  • DGTL_Magician
DGTL_Magician
Verwijderd schreef op 08 June 2003 @ 12:37:
TopicStarter :)
  • Jap
Jap
No worries
/etc/ppp/chap-secrets:
# client server secret IP addresses
"Pacthon@zonnet-lite" "*" "mijnw8woord" "*"
en dat heb ik nu veranderd in:
Pacthon@zonnet-lite "*" mijnw8woord
en dat ga ik zo even testen
[edit]
op bijde manieren deed hij het niet, ik probeer nu vanaf de link die madman2003, de drivers opnieuw te installeren, en de pppd goed te krijgen!
[ Voor 17% gewijzigd door Jap op 08-06-2003 14:34 ]
  • DGTL_Magician
DGTL_Magician
Jap schreef op 08 June 2003 @ 13:52:
"Pacthon@zonnet-lite" * "mijnw8woord" *
Zo hebbik het staan.
  • Jap
Jap
No worries
Ik kreeg van iemand met het zelfde probleem deze link:
http://www.xs4all.nl/~pschram/
die ben ik nu aan het volgend, het scheen dat mijn probleem ligt met driver en pppd combinatie, en daar staat een gepatchde driver, en die ga ik nu proberen :)
  • Jap
Jap
No worries
WOOHOOOO (erggug blij) het is gelukt!! het lag aan de drivers EN de username opbouw ( " ") het werkt perfect!
Hardstikke bedankt iedereen!
Ik heb al een hele tijd geleden d'r een howto over geschreven, maar dat is nog voor de oude speedtouch modem:
http://www.snakeshit.nl/documentatie/speedtouch.html
  • Jap
Jap
No worries
Ik heb nu een werkende verbinding, maar nu heb ik een vraagje!
als ik in me ps -aux kijk staan deze er blijvend in:
root 1917 0.0 1.0 1204 396 ? S 15:06 0:00 /usr/local/sbin/modem_run -f /usr/local/lib/mgmt.o -m
en
root 1920 0.0 1.4 5896 544 ? S< 15:06 0:00 /usr/local/sbin/pppoa3 -m 1 -c -vpi 8 -vci 48 -e 1
root 1922 0.0 1.4 5896 544 ? S< 15:06 0:00 /usr/local/sbin/pppoa3 -m 1 -c -vpi 8 -vci 48 -e 1
root 1923 0.3 1.4 5896 544 ? S< 15:06 1:09 /usr/local/sbin/pppoa3 -m 1 -c -vpi 8 -vci 48 -e 1
root 1924 1.4 1.4 5896 544 ? S< 15:06 5:03 /usr/local/sbin/pppoa3 -m 1 -c -vpi 8 -vci 48 -e 1
die 1e is de firmware, en de 2 tot de 5 zijn de pppoa3, maar zijn de nodig om de verbinding tot stand te houde? of zouden die ook gekilled kunnen worden?
Als je die killed werkt je internet niet meer.
  • Jap
Jap
No worries
dan zullen we dat maar niet doen :+
Lijkt me niet verstandig.
