Locale Shoutcast server
  • menn0
  • Laatst online: 06-09 12:27
Ik ben al aardig op weg en gebruik
Shout cast server en Trans cast, hier de startup logs van beiden:
<06/05/03@20:42:09> [TRANSCast] DNAS/posix v0.400-LAME (Mar 4 2003) starting up...
<06/05/03@20:42:09> [MAIN] PID: 383
<06/05/03@20:42:09> [MAIN] Loaded config from sc_trans.conf
<06/05/03@20:42:09> [MAIN] Loading playlist (shoutcast.lst)
<06/05/03@20:42:10> [MAIN] Read 2500 playlist entries...
<06/05/03@20:42:10> [MAIN] Found (2637) entries in playlist
<06/05/03@20:42:10> [MAIN] Playlist decoder thread starting
<06/05/03@20:42:10> [MAIN] Streaming thread starting
<06/05/03@20:42:10> [STREAM] Creating stream socket
<06/05/03@20:42:10> [DECODE] Opened 01-the_cardigans-communication-bpm.mp3
<06/05/03@20:42:10> [STREAM] Connected to host server
<06/05/03@20:42:10> [CONFIG] WARNING: No InputSamplerate defined, assuming 44100!
<06/05/03@20:42:10> [CONFIG] WARNING: No InputChannels defined, assuming 2!
[2]+ Stopped ./sc_trans_linux
** SHOUTcast Distributed Network Audio Server
** Copyright (C) 1998-2000 Nullsoft, Inc. All Rights Reserved.
** Use "sc_serv filename.ini" to specify an ini file.
Event log:
<06/05/03@20:15:12> [SHOUTcast] DNAS/Linux v1.9.2 (Nov 25 2002) starting up...
<06/05/03@20:15:12> [main] pid: 345
<06/05/03@20:15:12> [main] loaded config from sc_serv.conf
<06/05/03@20:15:12> [main] initializing (usermax:3 portbase:8000)...
<06/05/03@20:15:12> [main] No ban file found (sc_serv.ban)
<06/05/03@20:15:12> [main] No rip file found (sc_serv.rip)
<06/05/03@20:15:12> [main] opening source socket
<06/05/03@20:15:12> [main] source thread starting
<06/05/03@20:15:12> [main] opening client socket
<06/05/03@20:15:12> [main] Client Stream thread [0] starting
<06/05/03@20:15:12> [source] listening for connection on port 8001
<06/05/03@20:15:12> [main] client main thread starting
<06/05/03@20:15:13> [sleeping] 0 listeners (0 unique)
[1]+ Stopped ./sc_serv
Nog even over die errors in sc_trans
; 24kbps 24000/22050/1
; 32kbps 32000/22050/1
; 64kbps mono 64000/44100/1
; 64kbps stereo 64000/22050/2
; 96kbps stereo 96000/44100/2
; 128kbps stere0 128000/44100/2
Bitrate=192000
SampleRate=44100
Channels=2
; Quality is from 1-10. 1 is best, 10 is fastest.
Quality=1
Volgens mij heb ik dat dus wel ingesteld...of dat is de output en kan ik de input niet vinden, maar goed input van sc_trans verander natuurlijk per mp3 file, hoewel meeste 192kbps zijn...
Wat ik me wel afvraag is
sc_trans, en shoutcast doen beiden alles op port 8000
is dat wel ok?
Ter verduidelijking de situatie is als volgt:
192.168.0.1 is p133 linux machine met 100gigabyte daar wordt mijn mp3 op gebackupped. Nou dacht ik is leuk als die ook als soort radiostation fungeert, mp3s staan er al op dus waarom niet. 192.168.0.1 moet dus de mp3s van haar eigen hd broadcasten.
In winamp op 192.168.0.2 connect ik naar 192.168.0.1:8000 maar cannot connect ook met http:// ervoor geprobeert.. no go.
Thnx voor het advies.
  • Kippenijzer
  • Laatst online: 03-09 09:21
Kippenijzer
McFallafel, nu met paardevlees
Zie je die regeltjes stoped staan? Dat houd in dat ze niet meer draaien... Je moet ze op de achtergrond door laten draaien door nadata hij Stopped zegt effe het commando bg te geven, of denk ik zo te simpel?
  • menn0
ze staan nog wel bij ps...
  • Kippenijzer
Kippenijzer
Jupz, met als mededeling dat ze slapen waarschijnlijk... Gewoon ding starten, en dan op ctrl+z drukken, waarna hij "stopped" geeft en dan command bg, waarna hij de commandopromt die je voor het starten gebruikt had weer weergeeft eindigend op een & tekentje... Doe dat nou eerst maar, mocht het daarna nog niet werken kunnen we altijd nog even voor je kijken...
  • Coen Rosdorff
Opstarten met "./sc_trans_linux &" en ze gaan gelijk op de background.
  • menn0
Ik heb na contrl-Z de command promt al terug als ik dan op bg druk kom ik in de background stuff waar ik ook met geen mogelijkheid meer uit kom. :(
Die sc_trans, connect niet goed met shoutcast server. die shoutcast server draait verder wel goed.
edit
het werkt inmiddels maar ik denk dat sc_trans niet echt genoeg opties heeft
en ik voor iceS moet gaan. Ook stottert het met sc_trans mijn winamp moet steeds bufferen maar gaat wel exact verder op waar ie was, oftewel de p133 server trekt het niet... Ook re-encode ie misschien ookal is bitrate hetzelfde. dat kun je niet goed instellen bij sc_trans :( Voor on the fly re-encoden is een p133 uiteraard zwaar te traag, maar afspelen zou toch zeker moeten kunnen.... :S? 48 mb ram
[ Voor 76% gewijzigd door menn0 op 06-06-2003 22:42 ]
Haai,
Ik werk zelf ook met shoutcast en trans, alles werk naar behoren.
Alleen jammer dat ik geen songs kan requesten :(
Je kan ook met nohup aan de gang denk ik'
Bij mij staat ze gewoon te draaien shoutcast op alt-3 trans op alt-2 en mijn main op alt-1, kan ik alles in de gaten houden!
Probeer eens terug te schakelen naar 128 bits, mogelijk dat die dan niet zo buffert.
Richard.
