Message in MIME format niet leesbaar
  • Tonton
  • Laatst online: 07-09 11:11
Ik heb hier een document wat waarschijnlijk gemaild is ooit
en nu niet meer leesbaar is, als ik het open krijg ik 485 blz tekst:
het begint zo:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
This message is in MIME format.
--Boundary_(ID_mFN5rk/x/u6hvq48hDDSWQ)
Content-transfer-encoding: base64
Content-disposition: inline; filename=blahblah.doc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 dat gaat dan zo door :(
Hoe zet ik dit weer om in leesbare tekst :?
ps: Heb naam document even aangepast
PC: LianLi O11D evo, Corsair HX1500i, Asus ROG Z790-A, i7-14700KF, 48GB DDR5 Corsair PC7400, MSI RTX5090 Suprim Liquid, Samsung 990pro 1+2TB, LG 42OLEDC4 *** HCS: LG 83OLEDG2, Marantz Cinema 40, B&W (702S2 HTM71S2 705S2 DB4S), Project X2B-at33ptg2, DS3B
  • F_J_K
F_J_K
Moderator CSA/PB/AI
Front verplichte underscores
Lijkt me vrij duidelijk :Y)
Je kan het gewoon uitpakken met winzip :)
  • Tonton
Hoe werkt dat precies dan?
als ik het open in Winrar wordt er geklaagd over wrong format
  • Shift
  • Laatst online: 04-08 13:44
Shift
[] Dual crazy []
Uitpakken met winzip kan niet.
De attachment van mails worden gecodeerd met base64, je kan de file decoderen met die base64 decoder, er zijn functies beschikbaar in php omdat te kunnen doen.
http://nl3.php.net/base64-decode
Dus wat je gaat doen is, je plaatst de gecodeerde gedeelte in een text file, met php open je de bestand en decodeer het en sla op in een andere bestand met extensie .doc dan moet het weer te openen zijn.
[ Voor 51% gewijzigd door Shift op 05-06-2003 09:44 ]
  • McFizban
  • Laatst online: 10-09 13:58
McFizban
Hackito ergo sum.
Hmmmm, lekker genetisch gemodificeerd eten!!!!
Probeer het hier eens mee: http://www.simtel.net/pub/pd/24111.html
[ Voor 44% gewijzigd door McFizban op 05-06-2003 09:49 ]
Haardware: meuk die zo oud is dat het alleen nog nuttig is voor in de openhaard.
  • Shift
Shift
[] Dual crazy []
McFizban schreef op 05 June 2003 @ 09:48:
Lol, het werk toch :D
  • Tonton
lukt me niet met dat base64
Ik krijg: no base64 data found in file (may not be base64)
heb header al geprobeerd weg te halen. lostte niks op
wat doe ik fout?
