scanner canon lide50
I am not very sucesfull to get this scanner to work with my USB 2.0 on my
Pentium Headstart PC under OS WINXP HE SP1,
It keeps saying no communication possible with the following error report:
ScanWizPage6.cpp:256,SD_result=SD_OPENDSERROR
The problem is very persistent, the scanner worked fine for just one day only,
after that i tried it on another PC same problem. The scanner was turned in
under warranty and replaced by another Serial Nr. The new scanner shows same
problem.
So it is likely a PC or SW problem rather than the scanner....can anybody
help me out ?
TY
