Wat vind jij van Futuremark 3Dmark 2003?
  • 169 views sinds 30-01-2008
  • Madrox
  • Laatst online: 14-08 11:10
Madrox
Oh, Pharaoh!
Voordat je je reactie geeft, mag je dit volgenden artikel even doorspitten. Het komt van http://www.extremetech.com en behalve de laatste 3.30 resultaten gaan ze ook even in op de mogelijkheden en onmogelijkheden van benchmarks.
UPDATED ATI TEST RESULTS
In our original story down below, we presented extensive test data that showed how both ATI and nVidia were losing some performance in the newest 3.30 version of 3DMark03, which has implemented countermeasures to defeat app detection by 3D GPU drivers. Due to a variation in our test methodology, the drop seen in our initial tests for ATI appears to be have been unduly affected by the location where render state settings are made (in the application versus in the driver).
Our original test results misstated ATI's performance drop with 3DMark03 version 3.30, and we'll provide correct, updated results that set ATI in a much better light, with far less performance hit moving to version 3.30. However, ATI still detected 3DMark03 within their driver, and substituted a "better optimized" shader, and that is still benchmark cheating in our book, even if the overall performance boost was modest.
In other words, the results we initially reported were more pronounced than they should have been for ATI– holding all else equal. Based on our retesting, we still saw that ATI takes a small hit on Game Test 4 in version 3.30, which has to do with a driver "optimization" that ATI has already publicly stated will be removed from its next Catalyst driver.
We'll explain how these issues arose, and present the updated test results for ATI.
We went back and tested on our same Intel reference test system, which has the following configuration:
Intel Pentium 4 3GHz
Intel 875PZB motherboard using Intel 875P chipset
512MB 400MHz DDR SDRAM
Sound Blaster Audigy Gamer
3com NIC
40GB ATA-100 EIDE hard drive
Toshiba DVD-ROM
KDS Avitron 21" monitor
Fresh install of Windows XP Pro SP1 with latest system updates as of 4/25/03
DirectX 9.0a
We tested at 1280x960x32 and 1600x1200x32, and with both 4X AA and 8X AF enabled at both resolutions.
Who's Driving Here?
The first issue we hit upon has to do with where anisotropic filtering settings are made. We took a long, hard look in the past at both ATI's and nVidia's adaptive implementations of AF, since both companies apply AF on an as-needed basis. Anisotropic filtering is used to address a specific kind of texture artifact that occurs when a 3D surface is sloped relative to the view camera.
Performance differences can arise depending on whether an application sets the AF parameters, or whether these are forced on at a driver level. There are additional parameters that applications can specify regarding how AF is applied to a scene, starting with which parts of the scene will have AF applied and which will not.
When AF is forced onto an unsuspecting app at a driver level, the driver attempts to make best-guess assumptions about how to apply AF, and not significantly degrade frame-rate performance.
In the case of 3DMark03, when AF is enabled from the benchmark itself, additional AF work has to be done during the four game test scenes, and this extra work induces roughly an 8% performance hit for ATI on its overall 3DMark03 score, compared to when the AF state is set at the driver level (by a setting in the graphics control panel).
Both nVidia and ATI allow their different AF settings to be set in their driver control panels. nVidia has a single panel that governs both Direct3D and OpenGL, whereas ATI has a panel for each of the two APIs, making for more "knobs and levers," but also allowing more granularity of these settings.
During our original testing of 3DMark03 version 3.30, ATI cards were set to use AF settings specified by 3DMark03, not the ATI driver's control panel. This created a much bigger drop in performance than if we had used the ATI driver's AF settings only. For the nVidia results, we used the driver control panel settings for both version 3.20 and 3.30 of 3DMark03, and not 3DMark03's AF settings, so our nVidia results will stand as previously tested. With the new results, ATI is using driver setting for AF in all cases, so it's more of an apples-to-apples comparison of ATI versus nVidia.
Here we present the data for both versions 3.20 and 3.30 of 3DMark03, with the latter version having anti-detection measures built into it to defeat driver detection/optimizations/funny business.
Note in our chart that "APP" refers to when anisotropic filtering is implemented via the 3DMark2003 benchmark, while "DRV" refers to setting AF via the driver before running the benchmarks.
Overall 3DMark03 Score
Version 3.20 Version 3.30 %drop v. 3.30 vs. v. 3.20
R9800 12x9 - DRV 2214 2150 2.9%
R9800 12x9 - APP 2028 1975 2.6%
R9800 16x12 - DRV 1613 1552 3.8%
R9800 16x12 - APP 1477 1430 3.2%
As you can see from the above chart, ATI's overall performance drops less than 3% at 1280x960 -- within the margin of error for the test – when AF is applied consistently using either the driver method or the application method. This occurs when running both versions 3.20 and 3.30 of 3DMark03. (See new ATI versus nVidia results below).
At 16x12, the difference grows a little more marked – almost 4% at the driver level, which is starting to become significant, but still not tremendously different.
App-level versus Driver-level AF Settings
This next chart shows the differences in overall 3DMark03 score if we set AF on from the application in one run, and then from the driver in the other. We present both the percentage decrease by using APP vs. DRV, and the percentage increase of using DRV vs. APP, two sides of the same coin, really. Letting 3DMark2003 set the AF results in about 9% drop in performance consistently whether you test with version 3.30 or version 3.20 of 3DMark2003.
Ver. 3.20 %Drop using APP Ver. 3.20 %Gain Using DRV Ver. 3.30 %Drop using APP Ver. 3.30 %Gain Using DRV
R9800 12x9 8.4% 9.2% 8.1% 8.9%
R9800 16x12 8.4% 9.2% 7.9% 8.5%
The 9% gain ATI gets at both resolutions by using its own driver-level AF setting pulls ATI even with the GeForceFX 5900 Ultra, which we also tested using that GPU's driver-level AF settings. When we initially (and erroneously) compared ATI's application-set scores versus nVidia's driver-set scores on version 3.30, nVidia was ahead by about 10%.
Differences Still Seen in Game Test 4
3DMark2003 game test 4 was the only test that showed significant performance differences for ATI, whether testing was done consistently at the application or the driver level. Here are the frame rate results from Game Test 4 – Mother Nature, the DX9/Pixel Shaders 2.0 test.
R9800 12x9 - DRV 20.5 18.8 8.3%
R9800 12x9 - APP 17.9 15.8 11.7%
R9800 16x12 - DRV 15.8 14.2 10.1%
R9800 16x12 - APP 13.8 12.6 8.7%
What you can see here is that even the biggest percentage drop going from version 3.20 to version 3.30, 11.7%, turns out to be all of 2.1fps, not a significant actual amount of performance loss. These deltas indicate how frame rate data, taken as percentages, can obscure, or in this case, artificially augment what's really going on.
When you vary how AF is set in Game Test 4, from application to driver and back, the differences are even more pronounced, as you can see here.
R9800 12x9 - APP 12.7% 14.5% 16.0% 19.0%
R9800 16x12 - APP 12.7% 14.5% 11.3% 12.7%
The nVidia/ATI Matchup
The saucier question is, do the results seen in version 3.30 of 3DMark03 affect how nVidia and ATI's match up on this benchmark? And the answer is, yes, except that it now becomes that much more difficult to declare an out and out winner.
nVidia holds a noteworthy lead at both test resolutions when running on version 3.20, but that's with cheats in place, so the results don't count. nVidia's lead gets all but obliterated in version 3.30 when we also use ATI's driver-level AF settings.
Here are the raw scores with AF set at the driver level on both products.
1280x960x32 V 3.20 Version 3.30 %drop v. 3.30 vs. v. 3.20
ATI R9800 - DRV 2214 2150 2.9%
nVidia GFFX 5900 Ultra - DRV 2623 2182 16.8%
1600x1200x32 Version 3.20 Version 3.30 %drop V/V
ATI R9800 - DRV 1613 1552 3.8%
nVidia GFFX 5900 Ultra - DRV 1743 1567 10.1%
Below we list the winners by percentage. As you can see, nVidia is ahead of ATI by a negligible 1% on both tests.
Winner, version 3.20 Winner, Version 3.30
1280x960x32 nVidia, by 18.5% nVidia, by 1.5%
1600x1200x32 nVidia, by 8.1% nVidia, by 1%
Because Game Test 4 is where we saw the biggest deltas, here are the comparative ATI vs nVidia results for your perusing pleasure:
GAME TEST 4
1280x960x32 Version 3.20 Version 3.30
ATI R9800 - DRV 20.5 18.8
nVidia GFFX 5900 Ultra - DRV 17.9 9.9
1600x1200x32
ATI R9800 - DRV 15.8 14.2
nVidia GFFX 5900 Ultra - DRV 11.7 7.3
As you can see, ATI does take a slight hit, around 8% and 10% at 12x9 and 16x12, respectively. But again, consider that the actual frame rate delta is never more than 1.7fps, a minute amount.
nVidia however suffers larger hits, and at 12x9, sees its score nearly cut in half. It's also interesting to note that nVidia delivers only half of the performance of ATI's 9800 Ultra, indicating some real shader-based performance differences between the parts here – and perhaps a motive for nVidia to artificially pump up its scores. Still, this is all of one data point. We still don't have any games that use DX9's Pixel Shaders 2.0 standard, and until we do, the question of which GPU has superior performance in this area remains open.
Too Many Knobs and Levers...
We had originally reported in the story below that ATI's performance on Game Test 4 dropped by around 20% at both test resolutions. This seemingly large drop amounted to a mere 3fps, but the delta turns out to be about half that amount, as we showed above.
So what happened? We suspect that in preparing our version 3.30 numbers, we went into ATI's driver control panel, and set the correct AF and AA parameters, 8X and 4X, respectively. But upon launching the application, we proceeded to also set those same parameters at an application level, which over-rode the driver-level settings, and had ATI doing the work specified by the app, rather than letting the driver handle AF filtering decisions.
We've added an additional step to our testing methodology, to verify AA and AF settings at a driver level only, and leave the AF and AA settings at their default state in the benchmark.
Did ATI "cheat" on 3DMark2003?
Version 3.30 of 3DMark03 not only defeated the DetonatorFX driver's app detection mechanisms, but it also managed to uncover an ATI optimization that landed the company in a bit of hot water.
ATI's optimization involves using a more optimized shader program in Game Test 4 for the water shader program, but according to ATI, this water shader renders "…the scene exactly as intended by Futuremark, in full-precision floating point. Our shaders are mathematically and functionally identical to Futuremark's, and there are no visual artifacts; we simply shuffle instructions to take advantage of our architecture….However, we recognize that these can be used by some people to call into question the legitimacy of benchmark results, and so we are removing them from our driver as soon as is physically possible. We expect them to be gone by the next release of CATALYST."
The line between a bona fide optimization and a cheat is sometimes not well-defined, but in our estimation, ATI's optimization is suspect, and at the end of the day, it bought them all of a 9% increase in performance, or a barely mention-worthy 1.7fps.
This small gain leads us to question why ATI would implement this optimization in the first place, since the risk of being perceived as cheating would far outweigh a less than 2fps performance increase. However, ATI has been forthcoming in its public statements about the nature of this optimization, and has stated that because of the potential perception of being considered a cheat (and probably because it didn't buy them much performance anyway), that this optimization will be pulled from the next Catalyst driver release.
Meanwhile, nVidia's "optimizations" are far more aggressive, and we believe they go beyond what can be considered reasonable driver optimization, and into the realm of cheating. nVidia has thus far been unable, or perhaps unwilling, to address these issues, since it apparently still refuses to rejoin FutureMark's beta program to gain access to the developer version of 3DMark03, and the company maintains that what ExtremeTech uncovered are driver bugs, and nothing more.
Lessons Learned
It's clear that applications of all stripes need to factor in AF and AA into their settings control panels, and that game developers need to intelligently implement how these two features get used in their games, rather than leaving GPU drivers to make educated guesses as to what will be best. Serious Sam SE does allow for tweaking of AF settings in its advanced rendering options panel, although this option is buried three screens down in those panels.
It also raises once again the issue of subjective versus objective evaluation of 3D performance. Image quality is very important, and anything a GPU can do to palpably improve image quality and the overall gaming experience is obviously a good thing.
But dynamic image quality optimizations can make benchmarking nearly impossible, since one cannot know what exactly a GPU is doing. It's for this reason for example that we always test nVidia-based GPUs with the 3D Quality and Performance slider set at its "Application" position. Yes, nVidia can do intelligent things to dynamically improve image quality and performance, but how much of this is being done at any given time is impossible to say.
Then there is the matter of less sophisticated users ignoring these somewhat esoteric features. This is where nVidia's over-arching "3D goodness" slider is helpful, since it allows someone to simply dial up the 3D love without having to know exactly what it does.
The problem here is one of competing objectives: performance sliders such as this help end users, but can drive analysts nuts. The trick, it would seem, is to serve the sometimes-conflicting needs of end-users and analysts alike, and simultaneously improve the 3D user experience of the former without making the job of the latter impossible. One simple way to make this workable is to be sure that whatever consumer-friendly "3D goodness sliders" are added to driver panels, that they can be turned off/disabled completely, forcing the GPU to render the scene as the application has specified. In this way, we can look at "absolute" performance, and then see how much performance scales by using the 3D goodness slider, and at the same time verify that image quality isn't being adversely affected in a palpable way.
The actual performance difference seen in our new test results is fairly insignificant in terms of actual frame rate, but for the purposes of consistent methodology, we needed to revisit this matter and make sure we provided you with accurate information. To avoid such snafus in the future, we'll be using driver-level settings for AF on both GPUs at all times, and forgo using 3DMark's app-level AF settings. This methodology better reflects the current landscape today, where the majority of apps don't understand AF, and don't have settings for it in their options panels.
Voor upgrade, complete zelfbouw, herstellen van windows/software klik hier!
Die lui van 3D mark moeten niet zo zeuren.
Ik vind dat drivers die aplicaties detecteren en zich aanpassen aan deze een heel goed idee! Zolang dit maar niet tenkoste gaat van (zichtbare) beeldkwaliteit.
Eigenlijk zouden de fabrikanten hun drivers zo moeten maken dat er voor elk "bekend" spel een soort profiel in zit. Zodat de hardware altijd optimaal wordt benut. (als ik het goed had begrepen had ATI hun drivers getweakt om hun chip architectuur beter te benutten) Maar dan wel losstaand van de ingame instellingen. Tis maar een idee
Aangezien bijv. de Quake 3 engine anders functioneerd dan bijv. de UT2003 engine zijn er denk ik toch wel wat optimalisaties mogelijk.
Trouwens op het aantal 3D marks staar ik me toch niet blind, als ik een nieuwe kaart ga kopen kijk ik naar de echte game benchmarks. Quake3/UT2003/Splintercell etc.
  • swampy
  • Laatst online: 25-03 09:06
swampy
Coconut + Swallow = ?
3Dmark 2003....tja...het is anders dan de producten die ze eerst hadden. En dat merk je....eerst was het vooral om de frame rate te testen onder voor die tijd zware videokaarten met allemaal effecten aan.
Maar nu is het niet zoveel met de snelheid, maar meer met het uittesten van de technologien en het maximale uit de hardware ondersteuning van de kaart halen.
Dus waar vroegen snelheid zeer belangrijk was, is nu meer belangrijk dat de videokaart ook echt doet wat het moet doen en dus all die verschillende technologie-en draaien en daarbij de framerate goed houden.
Je ziet ook dat bijvoorbeeld de Nvidia FX serie niet echt lekker scoort terwijl als je de specificaties ziet het toch goed zou scoren. Maar blijkbaar heeft ATI toch de hardware matige onderdelen er beter opzitten! ( 8x1 pixel lijn inplaats van 4x2 bv. )
En kunnen videokaart bouwers zich dus er niet makkelijk meer vanuit maken door het geheugen en de core gewoon zo snel mogelijk te laten draaien. Nee, nu moeten ze ECHT hun best doen om het maximale uit hun design te halen.
En dat juich ik toe....kaarten testen op waar ze gemaakt zijn.....het combineren van verschillende technieken!
There is no place like ::1
  • silentsnow
  • Laatst online: 15-04-2013
silentsnow
« '-_-' »
Wat vind je er zelf van? je paste wel een leuk lapje tekst, maar ik wil eigenlijk je eigenn mening wel eens horen ;)
Ik vind de enorme hype rondom 3DMark erg jammer. Het was altijd handig om dmv de online database systemen met elkaar te vergelijken, maar sinds 3DMark03 moet je voor de belangrijkste opties betalen. Als consument én als fabrikant. 3DMark is allang geen programma meer die je in elke review tegenkomt, terwijl dat vroeger wél zo was. Het is nu meer een tool die een score geeft aan de hand van de capaciteiten van de videokaart, terwijl vroeger je gehele systeem centraal stond.
Dat nVidia heeft besloten het lidmaatschap op te zeggen kan ik alleen maar toejuichen. Futuremark en Ati hebben gewoon een heel vies slim spelletje met nVidia zitten spelen. nVidia is daar dik ingetrapt door drivers zodanig aan te passen dat de 330 patch de behaalde resultaten van nVidia keihard onderuit heeft gehaalt. Maar de cheats/optimalisaties van nVidia vind ik een zeer kwalijke zaak, en dat wil ik ook niet goedpraten, net zo min als die van Ati.
The trade of the tools
[ me | specs ] Klipsch Promedia Ultra 5.1 + Sennheiser HD-590
  • DeverauX
DeverauX
Focus is everything
Aan de ene kant is het begrijpelijk dat zowel ATI als nVidia hun drivers optimaliseren om op deze manier zo goed mogelijk uit de bus te komen.
Het verschil zit hem echter in hoe de twee bedrijven deze optimalisatie benaderen. ATI is er in ieder geval eerlijk in, terwijl nVidia aan de andere kant niet helemaal duidelijk is/wil zijn over wat deze optimalisaties volgens hun nou precies inhouden, en dat zegt wel wat.
Eigenlijk is de discussie over wie nou fout is en wie niet eigenlijk niet eens interessant. Interessanter is echter de vraag of 3Dmark (nu en in de toekomst) wel een nauwkeurig en objectief meetinstrument is om de prestaties van grafische kaarten te beoordelen, en daar heb ik gezien de laatste gebeurtenissen zo mijn twijfels bij...
Daarom heb ik ook het gevoel dat Futuremark uiteindelijk de verliezer zal zijn in dit conflict.
...whatever was distasteful or unpleasant or uncomfortable or painful - music could always soothe that.
All you have to do is reach out to beauty.
Quincy Jones
  • Madrox
Madrox
Oh, Pharaoh!
silentsnow schreef op 29 mei 2003 @ 05:32:
Op zichzelf vind ik 3Dmark2003 een goed programma. Alleen nu zitten ze in een ongelukkige situatie. Zal dat zo verder toelichten.
De Hype, die vooral door de gebruikers zelf! teweeg is gebracht
Mee eens. "t is jammer dat je niet meer ff snel op videokaart of CPU een lijstje kan oproepen. Je kan het alleen nog maar met je "custom search" opdracht doen.
Het kan gelukkig nog wel, en het is nog steeds gratis in principe
Klopt, en dit komt mede door de roep om meer game-performance benchmarks. Wat een hoop mensen niet snappen en nog steeds niet snappen is dat 3Dmark vooral bedoeld is om grafische-kaarten met elkaar te vergelijken en niet zozeer om je te laten zien hoe snel je spelletje gaat lopen. Al geeft het wel een indicatie. Ga je het omdraaien en vergelijk je de FPS met de FPS van dat ene spel wat je tof vind, heb je niet begrepen waar 3Dmark voor bedoelt is. Dat was al zo vanaf 3Dmark 2000. Alleen toen en t/m 3Dmark 2001 kon je toch redelijk vertrouwen op de scores. De verschillen tussen de architectuur van de GPU's waren niet zo groot. En dat brengt me gelijk bij probleem waar ze nu mee zitten.
En dat is 2 grote fabrikanten die ieder duidelijk voor een andere route gekozen hebben. Waar de een de pixels met 12bit integer, 16 en 32 bit Floating point precisie rendert doet de ander het met 24 bit precisie (32bit word vertaald naar 24bit door de GPU/drivers). Dat en verschillen in de pixel-shaders en nog een paar dingen maken het eigenlijk onmogelijk om een vergelijkende, objectieve test uit te voeren. de een kan geen Full-24bit draaien en de ander geen mix van 12/16/32. Ziedaar, het kip en het ei :+
Heb je daar bewijzen voor ? Denk het niet. Pure speculatie en in mijn ogen absolute onzin. Futuremark heeft met meer leden rekening te houden behalve ATi, en dat zijn zeker geen kleine jongens. Denk je nou werkelijk dat die dat allemaal goed zouden vinden :?
En dat ze eruit gestapt zijn heeft alles te maken met hun GPU architectuur en de onverenigbaarheid met de DX9 standaard. Ze hadden blijkbaar een full-32bit precisie van Ati verwacht, die kwam verrassend met een toegestane! 24 bit precisie en bleek daar goed mee te scoren. Ze zagen de bui met 3Dmark 2003 al hangen en ipv. mee te werken aan hun oplossing hebben ze eieren voor hun geld gekozen. Achteraf gezien ben ik blij met Ati want als we die niet hadden was het met Nvidia precies dezelfde kant op gegaan als Intel in het verleden en Microsoft. Waarom ik dit denk ? Moet je voor de gein maar es het artikel lezen van Nvidia's CEO, die droomt al een tijdje van een WINVIDIA platform. Wat zou die daar nou mee bedoelen >:) Lang leve de concurrentie _/-\o_
zou niet weten waarom ze "erin" moeten trappen. Het is een professioneel bedrijf dat zijn eigen keuses maakt, en het was hun keus om het zo te doen. Beetje dom, he :+
BOLD-einde vergeten 8)7
  • Metro2002
  • Laatst online: 09:49
Metro2002
Memento mori
silentsnow schreef op 29 May 2003 @ 05:32:
_/-\o_
ik hoef gelijk niet meer te posten :) u said it all.
vroegah vond ik 3dmark nog wel een goede vergelijking maar tegenwoordig vind ik het maar een prutbench. oneerlijke vergelijking waarbij zelfs 2 DX8 kaarten een precies omgekeerd beeld vd werkelijkheid laten zien (een trage ati tegenover een snelere GF waarbij de GF 2x zo hoog scoort in alle games en 3dmark2k1 en guess who wins in 3dmark2003 :r )
  • Kimberly
  • Laatst online: 08-09 16:10
Thja, wat vind ik ervan.
Ik vind het alemaal niet zo belangerijk, als alle games goed werken is het toch goed?
Intel 14700K | Asus ROG Strix z790 GAMING WIFI | 32GB 7200MHZ | ASUS ProArt RTX 4070 SUPER | Fractal North | CORSAIR RM750 | Samsung 2.5TB NVME | Samsung Odyssey G8 OLED
  • Bossie
  • Laatst online: 08-09 23:38
Deorgere schreef op 29 mei 2003 @ 09:54:
d8 ik, het kan mooi dus ook geen ene *piep* schelen wat mijn 3dmarkscore is met een bepaalde driver versie
ik heb een ti4200 en een celly 1000a@1333, en ut2k3 draait probleemloos met detonator 44.03, en dat is wat ik atm belangrijk vind
niet een of andere test waaruit blijkt dat een andere kaartje beter is dan de mijne en de toekomstige technieken goed weergeeft, maar gewoon de irl performance van de games die nu uit zijn, en die ik nu speel
goed voorbeeld blijft toch de voodoo 5, in elke review afgekraakt ivm met de gf2 gts totdat je de glide games ging spelen
ik speel de meeste games toch in opengl muv blizzard titels, en ik denk dat dat voor de meesten zo is
  • whyz
whyz
Afdeling icoonloos
Net als wat de anderen boven me zeggen ook ik vind het een flutprogram om het effe zo te brengen. Gaat puur nog op 3dkaart terwijl bij 3dmark2001se je cpu enzo je ook meeophoog hielpen in je score. Ik bench niet meer met 3dmark03, alleen nog met 3dmark2001. Maar dat is dan ook puur omdat ik puntengeil ben, en ik een steeds hogere score wil neerzetten door het overklokken.
Right for all the wrong reasons.
  • Pollewob
Dit is meer een SA aangelegenheid, en wordt voor een deel ook al in Nvidia schandaal ivm. Futuremark's 3Dmark2003 besproken. Dicht dus. Eventueel kan je een nieuw topic in SA openen, maar zorg dan wel voor meer verschil met het bovenstaande topic :)
