ik was bezig met een ldap server te installen, alleen halverwege crashte de pc en dus de install, en toen heb ik per ongeluk de /etc/ldap weggegooid met de system.core o.i.d.
zooi met apt-get geprobeerd te removen en weer te installen, maar dan krijg ik allemaal vreemde errors.
apt-get install slapd:
apt-get remove slapd:
aangezien ik nogal een debian-n00b ben, kwam ik niet verder dan de /var/apt door te ploegen, en eventuele links naar een niet bestaande slapd te verwijderen, but of no avail
| limper:~# apt-get install slapd Reading Package Lists... Done Building Dependency Tree... Done The following NEW packages will be installed: slapd 0 packages upgraded, 1 newly installed, 0 to remove and 0 not upgraded. Need to get 0B/607kB of archives. After unpacking 1810kB will be used. Preconfiguring packages ... Selecting previously deselected package slapd. (Reading database ... 20555 files and directories currently installed.) Unpacking slapd (from .../slapd_2.0.23-6.3_i386.deb) ... Setting up slapd (2.0.23-6.3) ... /var/lib/dpkg/info/slapd.postinst: /etc/init.d/slapd: No such file or directory dpkg: error processing slapd (--configure): subprocess post-installation script returned error exit status 1 Errors were encountered while processing: slapd E: Sub-process /usr/bin/dpkg returned an error code (1) |
| limper:~# apt-get remove slapd Reading Package Lists... Done Building Dependency Tree... Done The following packages will be REMOVED: slapd 0 packages upgraded, 0 newly installed, 1 to remove and 0 not upgraded. 1 packages not fully installed or removed. Need to get 0B of archives. After unpacking 1810kB will be freed. Do you want to continue? [Y/n] (Reading database ... 20577 files and directories currently installed.) Removing slapd ... dpkg - warning: while removing slapd, directory `/etc/ldap' not empty so not removed. limper:~# |
Compromises are for the weak
