heeft iemand hier ervaring mee?
ik krijg het niet voorelkaar om de mailserver in de DMZ te bereiken via Outlook 2003.
mijn IPcop is van het internet netwerk bereikbaar middels;
ping,
ssh poort 222,
web interface poort 81.
als ik ssh naar de ipcop kan ik pingen naar de mailserver dus de verbinding is er.
HIERONDER WAT INFO VOOR JULLIE
port forwarding
TCP DEFAULT IP : 80(HTTP) 192.168.10.1 : 80(HTTP)
TCP DEFAULT IP : 110(POP3) 192.168.10.1 : 110(POP3)
TCP DEFAULT IP : 25(SMTP) 192.168.10.1 : 25(SMTP)
external service access
TCP ALL DEFAULT IP 113
TCP ALL DEFAULT IP 80
TCP ALL DEFAULT IP 25
TCP ALL DEFAULT IP 110
TCP ALL DEFAULT IP 222
dmz pinholes
TCP 192.168.1.10 192.168.10.1 80
TCP 192.168.1.10 192.168.10.1 22
TCP 192.168.1.10 192.168.10.1 25
TCP 192.168.1.10 192.168.10.1 110
Alle interface's
ETH0 Link encap:Ethernet HWaddr 00:A0:24:A2:44:B2
inet addr:192.168.1.101 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:12355 errors:0 dropped:0 overruns:0 frame:0
TX packets:12155 errors:0 dropped:0 overruns:0 carrier:0
collisions:1 txqueuelen:100
RX bytes:2265309 (2.1 Mb) TX bytes:7241190 (6.9 Mb)
Interrupt:11 Base address:0x6400
ETH1 Link encap:Ethernet HWaddr 00:02:44:41:C2:B2
inet addr:192.168.10.100 Bcast:192.168.10.255 Mask:255.255.255.0
RX packets:168 errors:0 dropped:0 overruns:0 frame:0
TX packets:288 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:100
RX bytes:36852 (35.9 Kb) TX bytes:17854 (17.4 Kb)
Interrupt:9 Base address:0x6000
ETH2 Link encap:Ethernet HWaddr 00:02:44:41:C2:B1
inet addr:10.0.0.1 Bcast:10.0.0.255 Mask:255.255.255.0
RX packets:21213 errors:0 dropped:0 overruns:0 frame:0
TX packets:22899 errors:0 dropped:0 overruns:0 carrier:0
collisions:5 txqueuelen:100
RX bytes:7603971 (7.2 Mb) TX bytes:2829051 (2.6 Mb)
Interrupt:10 Base address:0x8000
LO Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:6 errors:0 dropped:0 overruns:0 frame:0
TX packets:6 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:643 (643.0 b) TX bytes:643 (643.0 b)
PPP0 Link encap:Point-to-Point Protocol
inet addr:80.60.72.180 P-t-P:195.190.242.55 Mask:255.255.255.255
UP POINTOPOINT RUNNING NOARP MTU:1500 Metric:1
RX packets:11076 errors:0 dropped:0 overruns:0 frame:0
TX packets:10530 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:3
RX bytes:6432835 (6.1 Mb) TX bytes:1522124 (1.4 Mb)
Is het eigenlijk wel mogelijk wat ik wil of niet??
Als het kan wie heeft de oplossing??
Alvast bedankt!!!
ping,
ssh poort 222,
port forwarding
dmz pinholes
Alle interface's
Alvast bedankt!!!
https://www.taltion.nl, https://www.trekhaakkoffer-huren.nl, https://www.fietsendrager-huren.nl, https://www.fietskar-huren.nl
