directx probleem directplay8?
  • 146 views sinds 30-01-2008
  • kep1973
  • Laatst online: 15-10 17:41
ik heb een fout bij directplay8 staan, maar ik kan ook niet op de knop directplay testen drukken.
System Information
Time of this report: 5/24/2002, 13:37:17
Machine name: XAVIER-AHYH5IJU
Operating System: Windows XP Professional (5.1, Build 2600) (2600.xpclient.010817-1148)
Language: Dutch (Regional Setting: Dutch)
System Manufacturer: ECS
System Model: K7S5A
BIOS: Version 1.00
Processor: AMD Athlon(tm) Processor, MMX, 3DNow, ~1.4GHz
Memory: 256MB RAM
Page File: 197MB used, 444MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0 (4.09.0000.0900)
DX Setup Parameters: /PackageInstall
DxDiag Version: 5.03.0000.0900 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: The registry information for the service provider 'DirectPlay8 TCP/IP Service Provider' is missing or damaged. You should reinstall DirectX. The registry information for the service provider 'DirectPlay8 IPX Service Provider' is missing or damaged. You should reinstall DirectX. The registry information for the service provider 'DirectPlay8 Modem Service Provider' is missing or damaged. You should reinstall DirectX. The registry information for the service provider 'DirectPlay8 Serial Service Provider' is missing or damaged. You should reinstall DirectX. You should reinstall DirectX to get the latest version.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce3 Ti 200
Manufacturer: NVIDIA
Chip type: GeForce3 Ti 200
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0201&SUBSYS_40571043&REV_A3
Display Memory: 64.0 MB
Current Mode: 1152 x 864 (32 bit) (60Hz)
Monitor: Plug en Play-monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.13.0010.4072 (English)
DDI Version: 8
Driver Attributes: Final Retail
Driver Date/Size: 9/27/2002 15:38:00, 2596938 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n.v.t.
Mini VDD: nv4_mini.sys
Mini VDD Date: 9/27/2002 15:38:00, 1104282 bytes
Device Identifier: {D7B71E3E-4141-11CF-1B7C-5D6001C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0201
SubSys ID: 0x40571043
Revision ID: 0x00A3
Revision ID: 0x00A3
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: SB Live! Audio [D000]
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_0002&SUBSYS_80271102&REV_06
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ctaud2k.sys
Driver Version: 5.12.0001.0252 (English)
WHQL Logo'd: Yes
Date and Size: 7/19/2002 10:47:52, 837548 bytes
Other Files:
Driver Provider: Creative
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 4000, 191999
Static/Strm HW Mix Bufs: 32, 30
Static/Strm HW 3D Bufs: 32, 30
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: Enabled
Ports: SB Live! DirectMusic Synthesizer [D000], Hardware (Kernel Mode), Output, DLS, Internal, Default Port
MPU-401, Hardware (Kernel Mode), Input, No DLS, External
MPU-401, Hardware (Kernel Mode), Output, No DLS, External
SB Live! Audio [D000], Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI-mapper (emulatie), Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Live! Synth A [D000] (emulatie), Hardware (Not Kernel Mode), Output, No DLS, Internal
MPU-401 (emulatie), Hardware (Not Kernel Mode), Output, No DLS, External
SB Live! Sw Synth [D000] (emulatie), Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Live! Synth B [D000] (emulatie), Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Live! MIDI Port [D000] (emulatie), Hardware (Not Kernel Mode), Output, No DLS, External
Microsoft GS Wavetable SW Synth (emulatie), Hardware (Not Kernel Mode), Output, No DLS, Internal
MPU-401 (emulatie), Hardware (Not Kernel Mode), Input, No DLS, External
SB Live! MIDI Port [D000] (emulatie), Hardware (Not Kernel Mode), Input, No DLS, External
Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Muis
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Toetsenbord
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Thrustmaster Formula T1/T2 zonder adapter
Attached: 0
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x01EA
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB-hoofdhub
| Vendor/Product ID: 0x1039, 0x7001
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 9/7/2001 12:00:00, 50688 bytes
| Driver: usbd.sys, 9/7/2001 12:00:00, 4736 bytes
Gameport Devices
+ SIS PCI to ISA bridge
| Matching Device ID: pci\ven_1039&dev_0008
| Service: isapnp
| Driver: isapnp.sys, 9/7/2001 12:00:00, 36352 bytes
+-+ Standaardspelpoort
| | Matching Device ID: *pnpb02f
| | Service: gameenum
| | Driver: gameenum.sys, 8/17/2001 22:02:32, 9728 bytes
+ PCI-bus
| Matching Device ID: *pnp0a03
| Service: pci
| Driver: pci.sys, 9/7/2001 12:00:00, 62464 bytes
+-+ Creative Game Port
| | Matching Device ID: pci\ven_1102&dev_7002&subsys_00201102
| | Service: gameenum
| +-+ Algemeen spelpoortapparaat
| | | Matching Device ID: gameport\gamedevice
| | | Service: hidgame
| | | OEMData: 40 08 00 00 04 00 00 00
| | | Driver: hidgame.sys, 8/17/2001 22:02:32, 8576 bytes
| | | Driver: hidclass.sys, 9/7/2001 12:00:00, 33152 bytes
| | | Driver: hidparse.sys, 9/7/2001 12:00:00, 23680 bytes
| | | Driver: hid.dll, 9/7/2001 12:00:00, 22528 bytes
| | +-+ HID-compliant spelbesturing
| | | | Matching Device ID: hid_device_system_game
PS/2 Devices
+ Standaardtoetsenbord (101/102 toetsen) of Microsoft Natural PS/2-toetsenbord
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 9/7/2001 12:00:00, 51968 bytes
| Driver: kbdclass.sys, 9/7/2001 12:00:00, 23936 bytes
+ Toestenbordstuurprogramma voor Terminal Server
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/18/2001 06:38:00, 37896 bytes
+ Microsoft PS/2-muis
| Matching Device ID: *pnp0f03
| Service: i8042prt
| Driver: mouclass.sys, 9/7/2001 12:00:00, 22528 bytes
+ Stuurprogramma voor muis van Terminal Server
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 TCP/IP Service Provider - Registry: Error, File: ()
DirectPlay8 IPX Service Provider - Registry: Error, File: ()
DirectPlay8 Modem Service Provider - Registry: Error, File: ()
DirectPlay8 Serial Service Provider - Registry: Error, File: ()
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0000.0900)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0000.0900)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 1.4 GB
Total Space: 4.5 GB
File System: FAT32
Model: ST340824A
Drive: D:
Free Space: 0.7 GB
Total Space: 11.1 GB
File System: FAT32
Model: WDC WD200BB-32CXA0
Drive: E:
Free Space: 0.1 GB
Total Space: 28.6 GB
File System: FAT32
Model: ST340824A
Drive: F:
Free Space: 1.0 GB
Total Space: 5.0 GB
File System: FAT32
Model: ST340824A
Drive: G:
Free Space: 1.0 GB
Total Space: 4.0 GB
File System: FAT32
Drive: H:
Free Space: 1.5 GB
Total Space: 2.0 GB
File System: FAT32
Drive: I:
Free Space: 0.2 GB
Total Space: 2.0 GB
File System: FAT32
Drive: J:
Model: PIONEER DVD-ROM DVD-106
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.0000 (Dutch), 9/7/2001 12:00:00, 47488 bytes
Drive: K:
Model: SONY DVD RW DRU-500A
Drive: L:
Model: Generic STEALTH DVD SCSI CdRom Device
System Devices
Name: Creative Game Port
Device ID: PCI\VEN_1102&DEV_7002&SUBSYS_00201102&REV_06\3&61AAA01&0&59
Driver: C:\WINDOWS\system32\drivers\gameenum.sys, 5.01.2600.0000 (English), 8/17/2001 22:02:32, 9728 bytes
Name: Creative SB Live! Value
Device ID: PCI\VEN_1102&DEV_0002&SUBSYS_80271102&REV_06\3&61AAA01&0&58
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.0000 (English), 8/17/2001 22:01:20, 57344 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.0000 (English), 8/18/2001 06:24:38, 135040 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.0000.0900 (Dutch), 12/12/2002 00:14:32, 45696 bytes
Driver: C:\WINDOWS\System32\wdmaud.drv, 5.01.2600.0000 (English), 9/7/2001 12:00:00, 22016 bytes
Driver: C:\WINDOWS\System32\ksuser.dll, 5.03.0000.0900 (Dutch), 12/12/2002 00:14:32, 4096 bytes
Driver: C:\WINDOWS\system32\drivers\ctac32k.sys, 5.12.0001.0245 (English), 7/19/2002 10:46:28, 127948 bytes
Driver: C:\WINDOWS\system32\drivers\ctaud2k.sys, 5.12.0001.0252 (English), 7/19/2002 10:47:52, 837548 bytes
Driver: C:\WINDOWS\system32\drivers\ctoss2k.sys, 5.12.0001.0245 (English), 7/19/2002 10:48:04, 195432 bytes
Driver: C:\WINDOWS\system32\drivers\ctprxy2k.sys, 5.12.0001.0244 (English), 7/19/2002 10:48:08, 11068 bytes
Driver: C:\WINDOWS\system32\drivers\ctsfm2k.sys, 5.12.0001.0140 (English), 7/19/2002 10:48:22, 213860 bytes
Driver: C:\WINDOWS\system32\drivers\emupia2k.sys, 5.12.0001.0244 (English), 7/19/2002 10:48:32, 156604 bytes
Driver: C:\WINDOWS\system32\drivers\ha10kx2k.sys, 5.12.0001.0250 (English), 7/24/2002 13:52:26, 998004 bytes
Driver: C:\WINDOWS\System32\ctdlang.dat, 7/19/2002 11:07:30, 164044 bytes
Driver: C:\WINDOWS\System32\ctstatic.dat, 7/19/2002 10:59:32, 179669 bytes
Driver: C:\WINDOWS\System32\ctdaught.dat, 7/19/2002 10:56:50, 44055 bytes
Driver: C:\WINDOWS\System32\default.ecw, 9/22/1999 23:18:50, 2259067 bytes
Driver: C:\WINDOWS\System32\sfman32.dll, 5.12.0001.0130 (English), 8/17/2001 14:35:46, 36864 bytes
Driver: C:\WINDOWS\System32\a3d.dll, 80.00.0000.0003 (English), 7/19/2002 10:43:06, 65536 bytes
Driver: C:\WINDOWS\System32\ctbasicw.dat, 7/19/2002 11:02:24, 113373 bytes
Driver: C:\WINDOWS\System32\SBLive.ico, 10/22/2001 09:10:28, 4398 bytes
Driver: C:\WINDOWS\System32\Live.bmp, 10/22/2001 09:10:28, 3126 bytes
Name: Realtek RTL8139 Family PCI Fast Ethernet NIC
Device ID: PCI\VEN_10EC&DEV_8139&SUBSYS_813910EC&REV_10\3&61AAA01&0&88
Driver: C:\WINDOWS\System32\DRIVERS\RTL8139.sys, 5.396.0530.2001 (English), 8/17/2001 20:12:42, 23070 bytes
Name: NVIDIA GeForce3 Ti 200
Device ID: PCI\VEN_10DE&DEV_0201&SUBSYS_40571043&REV_A3\4&3525EC23&0&0008
Driver: C:\WINDOWS\System32\DRIVERS\nv4_mini.sys, 6.13.0010.4072 (English), 9/27/2002 15:38:00, 1104282 bytes
Driver: C:\WINDOWS\System32\nvinstnt.dll, 6.13.0010.4072 (Dutch), 9/27/2002 15:38:00, 118784 bytes
Driver: C:\WINDOWS\System32\nvsvc32.exe, 6.13.0010.4072 (English), 9/27/2002 15:38:00, 65536 bytes
Driver: C:\WINDOWS\System32\nv4_disp.dll, 6.13.0010.4072 (English), 9/27/2002 15:38:00, 2596938 bytes
Driver: C:\WINDOWS\System32\nvoglnt.dll, 6.13.0010.4072 (English), 9/27/2002 15:38:00, 3461120 bytes
Driver: C:\WINDOWS\System32\nvcpl.dll, 6.13.0010.4072 (English), 9/27/2002 15:38:00, 4214784 bytes
Driver: C:\WINDOWS\System32\nvmctray.dll, 6.13.0010.4072 (English), 9/27/2002 15:38:00, 49152 bytes
Driver: C:\WINDOWS\System32\nview.dll, 6.13.0010.4072 (English), 9/27/2002 15:38:00, 856133 bytes
Driver: C:\WINDOWS\System32\dmcpl.exe, 6.13.0010.4072 (English), 9/27/2002 15:38:00, 1306624 bytes
Driver: C:\WINDOWS\System32\nvshell.dll, 6.13.0010.4072 (English), 9/27/2002 15:38:00, 516167 bytes
Driver: C:\WINDOWS\System32\nvtuicpl.cpl, 6.13.0010.4072 (English), 9/27/2002 15:38:00, 192512 bytes
Driver: C:\WINDOWS\System32\nwiz.exe, 6.13.0010.4072 (English), 9/27/2002 15:38:00, 446464 bytes
Driver: C:\WINDOWS\System32\nviewimg.dll, 6.13.0010.4072 (English), 9/27/2002 15:38:00, 352256 bytes
Driver: C:\WINDOWS\System32\keystone.exe, 6.13.0010.4072 (English), 9/27/2002 15:38:00, 262229 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 9/27/2002 15:38:00, 54831 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 9/27/2002 15:38:00, 21725 bytes
Driver: C:\WINDOWS\nview\generic.tvp, 9/27/2002 15:38:00, 25392 bytes
Driver: C:\WINDOWS\System32\nvrsar.dll, 6.13.0010.4072 (Arabic), 9/27/2002 15:38:00, 294912 bytes
Driver: C:\WINDOWS\System32\nvwrsar.dll, 6.13.0010.4072 (Arabic), 9/27/2002 15:38:00, 126976 bytes
Driver: C:\WINDOWS\System32\nvrscs.dll, 6.13.0010.4072 (Czech), 9/27/2002 15:38:00, 237568 bytes
Driver: C:\WINDOWS\System32\nvwrscs.dll, 6.13.0010.4072 (Czech), 9/27/2002 15:38:00, 135168 bytes
Driver: C:\WINDOWS\System32\nvrsda.dll, 6.13.0010.4072 (Danish), 9/27/2002 15:38:00, 245760 bytes
Driver: C:\WINDOWS\System32\nvwrsda.dll, 6.13.0010.4072 (Danish), 9/27/2002 15:38:00, 139264 bytes
Driver: C:\WINDOWS\System32\nvrsde.dll, 6.13.0010.4072 (German), 9/27/2002 15:38:00, 253952 bytes
Driver: C:\WINDOWS\System32\nvwrsde.dll, 6.13.0010.4072 (German), 9/27/2002 15:38:00, 151552 bytes
Driver: C:\WINDOWS\System32\nvrsel.dll, 6.13.0010.4072 (Greek), 9/27/2002 15:38:00, 237568 bytes
Driver: C:\WINDOWS\System32\nvwrsel.dll, 6.13.0010.4072 (Greek), 9/27/2002 15:38:00, 159744 bytes
Driver: C:\WINDOWS\System32\nvrseng.dll, 6.13.0010.4072 (English), 9/27/2002 15:38:00, 114688 bytes
Driver: C:\WINDOWS\System32\nvwrseng.dll, 6.13.0010.4072 (English), 9/27/2002 15:38:00, 126976 bytes
Driver: C:\WINDOWS\System32\nvrses.dll, 6.13.0010.4072 (Spanish), 9/27/2002 15:38:00, 241664 bytes
Driver: C:\WINDOWS\System32\nvwrses.dll, 6.13.0010.4072 (Spanish), 9/27/2002 15:38:00, 151552 bytes
Driver: C:\WINDOWS\System32\nvrsfi.dll, 6.13.0010.4072 (Finnish), 9/27/2002 15:38:00, 237568 bytes
Driver: C:\WINDOWS\System32\nvwrsfi.dll, 6.13.0010.4072 (Finnish), 9/27/2002 15:38:00, 143360 bytes
Driver: C:\WINDOWS\System32\nvrsfr.dll, 6.13.0010.4072 (French), 9/27/2002 15:38:00, 249856 bytes
Driver: C:\WINDOWS\System32\nvwrsfr.dll, 6.13.0010.4072 (French), 9/27/2002 15:38:00, 151552 bytes
Driver: C:\WINDOWS\System32\nvrshe.dll, 6.13.0010.4072 (Hebrew), 9/27/2002 15:38:00, 282624 bytes
Driver: C:\WINDOWS\System32\nvwrshe.dll, 6.13.0010.4072 (Hebrew), 9/27/2002 15:38:00, 122880 bytes
Driver: C:\WINDOWS\System32\nvrshu.dll, 6.13.0010.4072 (Hungarian), 9/27/2002 15:38:00, 229376 bytes
Driver: C:\WINDOWS\System32\nvwrshu.dll, 6.13.0010.4072 (Hungarian), 9/27/2002 15:38:00, 147456 bytes
Driver: C:\WINDOWS\System32\nvrsit.dll, 6.13.0010.4072 (Italian), 9/27/2002 15:38:00, 253952 bytes
Driver: C:\WINDOWS\System32\nvwrsit.dll, 6.13.0010.4072 (Italian), 9/27/2002 15:38:00, 151552 bytes
Driver: C:\WINDOWS\System32\nvrsja.dll, 6.13.0010.4072 (Japanese), 9/27/2002 15:38:00, 221184 bytes
Driver: C:\WINDOWS\System32\nvwrsja.dll, 6.13.0010.4072 (Japanese), 9/27/2002 15:38:00, 94208 bytes
Driver: C:\WINDOWS\System32\nvrsko.dll, 6.13.0010.4072 (Korean), 9/27/2002 15:38:00, 217088 bytes
Driver: C:\WINDOWS\System32\nvwrsko.dll, 6.13.0010.4072 (Korean), 9/27/2002 15:38:00, 90112 bytes
Driver: C:\WINDOWS\System32\nvrsnl.dll, 6.13.0010.4072 (Dutch), 9/27/2002 15:38:00, 249856 bytes
Driver: C:\WINDOWS\System32\nvwrsnl.dll, 6.13.0010.4072 (Dutch), 9/27/2002 15:38:00, 147456 bytes
Driver: C:\WINDOWS\System32\nvrsno.dll, 6.13.0010.4072 (Norwegian (Bokmål)), 9/27/2002 15:38:00, 241664 bytes
Driver: C:\WINDOWS\System32\nvwrsno.dll, 6.13.0010.4072 (Norwegian (Bokmål)), 9/27/2002 15:38:00, 139264 bytes
Driver: C:\WINDOWS\System32\nvrspl.dll, 6.13.0010.4072 (Polish), 9/27/2002 15:38:00, 229376 bytes
Driver: C:\WINDOWS\System32\nvwrspl.dll, 6.13.0010.4072 (Polish), 9/27/2002 15:38:00, 143360 bytes
Driver: C:\WINDOWS\System32\nvrspt.dll, 6.13.0010.4072 (Portuguese), 9/27/2002 15:38:00, 233472 bytes
Driver: C:\WINDOWS\System32\nvwrspt.dll, 6.13.0010.4072 (Portuguese), 9/27/2002 15:38:00, 151552 bytes
Driver: C:\WINDOWS\System32\nvrsptb.dll, 6.13.0010.4072 (Portuguese), 9/27/2002 15:38:00, 249856 bytes
Driver: C:\WINDOWS\System32\nvwrsptb.dll, 6.13.0010.4072 (Portuguese), 9/27/2002 15:38:00, 151552 bytes
Driver: C:\WINDOWS\System32\nvrsru.dll, 6.13.0010.4072 (Russian), 9/27/2002 15:38:00, 245760 bytes
Driver: C:\WINDOWS\System32\nvwrsru.dll, 6.13.0010.4072 (Russian), 9/27/2002 15:38:00, 155648 bytes
Driver: C:\WINDOWS\System32\nvrssk.dll, 6.13.0010.4072 (Slovak), 9/27/2002 15:38:00, 229376 bytes
Driver: C:\WINDOWS\System32\nvwrssk.dll, 6.13.0010.4072 (Slovak), 9/27/2002 15:38:00, 147456 bytes
Driver: C:\WINDOWS\System32\nvrssl.dll, 6.13.0010.4072 (Slovenian), 9/27/2002 15:38:00, 237568 bytes
Driver: C:\WINDOWS\System32\nvwrssl.dll, 6.13.0010.4072 (Slovenian), 9/27/2002 15:38:00, 135168 bytes
Driver: C:\WINDOWS\System32\nvrssv.dll, 6.13.0010.4072 (Swedish), 9/27/2002 15:38:00, 241664 bytes
Driver: C:\WINDOWS\System32\nvwrssv.dll, 6.13.0010.4072 (Swedish), 9/27/2002 15:38:00, 139264 bytes
Driver: C:\WINDOWS\System32\nvrstr.dll, 6.13.0010.4072 (Turkish), 9/27/2002 15:38:00, 245760 bytes
Driver: C:\WINDOWS\System32\nvwrstr.dll, 6.13.0010.4072 (Turkish), 9/27/2002 15:38:00, 143360 bytes
Driver: C:\WINDOWS\System32\nvrszhc.dll, 6.13.0010.4072 (Chinese), 9/27/2002 15:38:00, 208896 bytes
Driver: C:\WINDOWS\System32\nvwrszhc.dll, 6.13.0010.4072 (Chinese), 9/27/2002 15:38:00, 73728 bytes
Driver: C:\WINDOWS\System32\nvrszht.dll, 6.13.0010.4072 (Chinese), 9/27/2002 15:38:00, 212992 bytes
Driver: C:\WINDOWS\System32\nvwrszht.dll, 6.13.0010.4072 (Chinese), 9/27/2002 15:38:00, 73728 bytes
Driver: C:\WINDOWS\help\nvcpar.hlp, 9/27/2002 15:38:00, 59265 bytes
Driver: C:\WINDOWS\help\nvwcpar.hlp, 9/27/2002 15:38:00, 22708 bytes
Driver: C:\WINDOWS\help\nvcpcs.hlp, 9/27/2002 15:38:00, 44912 bytes
Driver: C:\WINDOWS\help\nvwcpcs.hlp, 9/27/2002 15:38:00, 24807 bytes
Driver: C:\WINDOWS\help\nvcpda.hlp, 9/27/2002 15:38:00, 43012 bytes
Driver: C:\WINDOWS\help\nvwcpda.hlp, 9/27/2002 15:38:00, 23266 bytes
Driver: C:\WINDOWS\help\nvcpde.hlp, 9/27/2002 15:38:00, 45407 bytes
Driver: C:\WINDOWS\help\nvwcpde.hlp, 9/27/2002 15:38:00, 24223 bytes
Driver: C:\WINDOWS\help\nvcpel.hlp, 9/27/2002 15:38:00, 46549 bytes
Driver: C:\WINDOWS\help\nvwcpel.hlp, 9/27/2002 15:38:00, 24099 bytes
Driver: C:\WINDOWS\help\nvcpeng.hlp, 9/27/2002 15:38:00, 20214 bytes
Driver: C:\WINDOWS\help\nvwcpeng.hlp, 9/27/2002 15:38:00, 20453 bytes
Driver: C:\WINDOWS\help\nvcpes.hlp, 9/27/2002 15:38:00, 43519 bytes
Driver: C:\WINDOWS\help\nvwcpes.hlp, 9/27/2002 15:38:00, 21880 bytes
Driver: C:\WINDOWS\help\nvcpfi.hlp, 9/27/2002 15:38:00, 44427 bytes
Driver: C:\WINDOWS\help\nvwcpfi.hlp, 9/27/2002 15:38:00, 23365 bytes
Driver: C:\WINDOWS\help\nvcpfr.hlp, 9/27/2002 15:38:00, 42315 bytes
Driver: C:\WINDOWS\help\nvwcpfr.hlp, 9/27/2002 15:38:00, 23448 bytes
Driver: C:\WINDOWS\help\nvcphe.hlp, 9/27/2002 15:38:00, 56600 bytes
Driver: C:\WINDOWS\help\nvwcphe.hlp, 9/27/2002 15:38:00, 21885 bytes
Driver: C:\WINDOWS\help\nvcphu.hlp, 9/27/2002 15:38:00, 46995 bytes
Driver: C:\WINDOWS\help\nvwcphu.hlp, 9/27/2002 15:38:00, 26585 bytes
Driver: C:\WINDOWS\help\nvcpit.hlp, 9/27/2002 15:38:00, 42729 bytes
Driver: C:\WINDOWS\help\nvwcpit.hlp, 9/27/2002 15:38:00, 23268 bytes
Driver: C:\WINDOWS\help\nvcpja.hlp, 9/27/2002 15:38:00, 42956 bytes
Driver: C:\WINDOWS\help\nvwcpja.hlp, 9/27/2002 15:38:00, 30841 bytes
Driver: C:\WINDOWS\help\nvcpko.hlp, 9/27/2002 15:38:00, 118846 bytes
Driver: C:\WINDOWS\help\nvwcpko.hlp, 9/27/2002 15:38:00, 27388 bytes
Driver: C:\WINDOWS\help\nvcpnl.hlp, 9/27/2002 15:38:00, 44088 bytes
Driver: C:\WINDOWS\help\nvwcpnl.hlp, 9/27/2002 15:38:00, 23179 bytes
Driver: C:\WINDOWS\help\nvcpno.hlp, 9/27/2002 15:38:00, 42223 bytes
Driver: C:\WINDOWS\help\nvwcpno.hlp, 9/27/2002 15:38:00, 22968 bytes
Driver: C:\WINDOWS\help\nvcppl.hlp, 9/27/2002 15:38:00, 45164 bytes
Driver: C:\WINDOWS\help\nvwcppl.hlp, 9/27/2002 15:38:00, 24464 bytes
Driver: C:\WINDOWS\help\nvcppt.hlp, 9/27/2002 15:38:00, 42439 bytes
Driver: C:\WINDOWS\help\nvwcppt.hlp, 9/27/2002 15:38:00, 23915 bytes
Driver: C:\WINDOWS\help\nvcpptb.hlp, 9/27/2002 15:38:00, 42882 bytes
Driver: C:\WINDOWS\help\nvwcpptb.hlp, 9/27/2002 15:38:00, 23930 bytes
Driver: C:\WINDOWS\help\nvcpru.hlp, 9/27/2002 15:38:00, 45752 bytes
Driver: C:\WINDOWS\help\nvwcpru.hlp, 9/27/2002 15:38:00, 24241 bytes
Driver: C:\WINDOWS\help\nvcpsk.hlp, 9/27/2002 15:38:00, 46650 bytes
Driver: C:\WINDOWS\help\nvwcpsk.hlp, 9/27/2002 15:38:00, 24532 bytes
Driver: C:\WINDOWS\help\nvcpsl.hlp, 9/27/2002 15:38:00, 45954 bytes
Driver: C:\WINDOWS\help\nvwcpsl.hlp, 9/27/2002 15:38:00, 23464 bytes
Driver: C:\WINDOWS\help\nvcpsv.hlp, 9/27/2002 15:38:00, 43181 bytes
Driver: C:\WINDOWS\help\nvwcpsv.hlp, 9/27/2002 15:38:00, 23535 bytes
Driver: C:\WINDOWS\help\nvcpth.hlp, 9/27/2002 15:38:00, 58368 bytes
Driver: C:\WINDOWS\help\nvwcpth.hlp, 9/27/2002 15:38:00, 30486 bytes
Driver: C:\WINDOWS\help\nvcptr.hlp, 9/27/2002 15:38:00, 45555 bytes
Driver: C:\WINDOWS\help\nvwcptr.hlp, 9/27/2002 15:38:00, 22587 bytes
Driver: C:\WINDOWS\help\nvcpzhc.hlp, 9/27/2002 15:38:00, 51887 bytes
Driver: C:\WINDOWS\help\nvwcpzhc.hlp, 9/27/2002 15:38:00, 24481 bytes
Driver: C:\WINDOWS\help\nvcpzht.hlp, 9/27/2002 15:38:00, 51828 bytes
Driver: C:\WINDOWS\help\nvwcpzht.hlp, 9/27/2002 15:38:00, 20847 bytes
Device ID: PCI\VEN_1039&DEV_7012&SUBSYS_0A141019&REV_A0\3&61AAA01&0&17
Driver: n/a
Name: SiS 7001 PCI naar USB open host-controller
Device ID: PCI\VEN_1039&DEV_7001&SUBSYS_0A141019&REV_07\3&61AAA01&0&13
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.0000 (English), 9/7/2001 12:00:00, 15616 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.0000 (English), 9/7/2001 12:00:00, 123264 bytes
Driver: C:\WINDOWS\System32\usbui.dll, 5.01.2600.0000 (Dutch), 9/6/2001 21:27:06, 69120 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.0000 (English), 9/7/2001 12:00:00, 50688 bytes
Device ID: PCI\VEN_1039&DEV_7001&SUBSYS_0A141019&REV_07\3&61AAA01&0&12
Name: SiS PCI IDE-controller
Device ID: PCI\VEN_1039&DEV_5513&SUBSYS_55131039&REV_D0\3&61AAA01&0&15
Driver: C:\WINDOWS\System32\DRIVERS\pciide.sys, 5.01.2600.0000 (Dutch), 9/7/2001 12:00:00, 3328 bytes
Driver: C:\WINDOWS\System32\DRIVERS\pciidex.sys, 5.01.2600.0000 (Dutch), 9/7/2001 12:00:00, 23680 bytes
Driver: C:\WINDOWS\System32\DRIVERS\atapi.sys, 5.01.2600.0000 (English), 9/7/2001 12:00:00, 86656 bytes
Name: SiS735/733 Host CPU-brug
Device ID: PCI\VEN_1039&DEV_0735&SUBSYS_00000000&REV_01\3&61AAA01&0&00
Driver: n/a
Name: SIS PCI to ISA bridge
Device ID: PCI\VEN_1039&DEV_0008&SUBSYS_00000000&REV_00\3&61AAA01&0&10
Driver: C:\WINDOWS\System32\DRIVERS\isapnp.sys, 5.01.2600.0000 (Dutch), 9/7/2001 12:00:00, 36352 bytes
Name: SIS Processor to AGP Controller
Device ID: PCI\VEN_1039&DEV_0001&SUBSYS_00000000&REV_00\3&61AAA01&0&08
Driver: C:\WINDOWS\System32\DRIVERS\SISAGP.SYS, 5.12.0001.2010 (English), 8/17/2001 21:58:02, 26112 bytes
DirectX Components
ddraw.dll: 5.03.0000.0900 Dutch Final Retail 12/12/2002 00:14:32 284160 bytes
ddrawex.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 24064 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 9/7/2001 12:00:00 10496 bytes
d3d8.dll: 5.03.0000.0900 Dutch Final Retail 12/12/2002 00:14:32 1177600 bytes
d3d8thk.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 8192 bytes
d3d9.dll: 5.03.0000.0900 Dutch Final Retail 12/12/2002 00:14:32 1634304 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 9/7/2001 12:00:00 436224 bytes
d3dim700.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 797184 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 9/7/2001 12:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 9/7/2001 12:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 9/7/2001 12:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 9/7/2001 12:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 Dutch Final Retail 9/7/2001 12:00:00 33040 bytes
dplayx.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 217600 bytes
dpmodemx.dll: 5.03.0000.0900 Dutch Final Retail 12/12/2002 00:14:32 77824 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 9/7/2001 12:00:00 42768 bytes
dpwsockx.dll: 5.03.0000.0900 Dutch Final Retail 12/12/2002 00:14:32 76800 bytes
dplaysvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 28160 bytes
dpnsvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 16896 bytes
dpnet.dll: 5.03.0000.0900 Dutch Final Retail 12/12/2002 00:14:32 723968 bytes
dpnlobby.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes
dpnaddr.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes
dpvoice.dll: 5.03.0000.0900 Dutch Final Retail 12/12/2002 00:14:32 381952 bytes
dpvsetup.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 80896 bytes
dpvvox.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 112128 bytes
dpvacm.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 19968 bytes
dpnhpast.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 32768 bytes
dpnhupnp.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 68096 bytes
dpserial.dll: 5.00.2134.0001 Dutch Final Retail 9/7/2001 12:00:00 53520 bytes
dinput.dll: 5.01.2600.1106 Dutch Final Retail 8/29/2002 03:40:00 648704 bytes
dinput8.dll: 5.01.2600.1106 Dutch Final Retail 8/29/2002 03:40:00 667648 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 9/7/2001 12:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 Dutch Final Retail 9/7/2001 12:00:00 395264 bytes
joy.cpl: 5.01.2600.1106 Dutch Final Retail 8/29/2002 03:41:00 207360 bytes
gcdef.dll: 5.01.2600.0000 Dutch Final Retail 9/7/2001 12:00:00 77312 bytes
pid.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:41:00 31744 bytes
gameenum.sys: 5.01.2600.0000 English Final Retail 8/17/2001 22:02:32 9728 bytes
hidgame.sys: 5.01.2600.0000 English Final Retail 8/17/2001 22:02:32 8576 bytes
dsound.dll: 5.03.0000.0900 Dutch Final Retail 12/12/2002 00:14:32 355328 bytes
dsound3d.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 1294336 bytes
dswave.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18432 bytes
dsdmo.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 186880 bytes
dsdmoprp.dll: 5.03.0000.0900 Dutch Final Retail 12/12/2002 00:14:32 491520 bytes
dmusic.dll: 5.03.0000.0900 Dutch Final Retail 12/12/2002 00:14:32 116736 bytes
dmband.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 27136 bytes
dmcompos.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 58368 bytes
dmime.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 171520 bytes
dmloader.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 33280 bytes
dmstyle.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 98816 bytes
dmsynth.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 100864 bytes
dmscript.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 76800 bytes
dx7vb.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 602624 bytes
dx8vb.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 1189888 bytes
dxdiagn.dll: 5.03.0000.0900 Dutch Final Retail 12/12/2002 00:14:32 1675264 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 9/7/2001 12:00:00 924432 bytes
mfc42.dll: 6.00.8665.0000 English Beta Retail 9/7/2001 12:00:00 995383 bytes
wsock32.dll: 5.01.2600.0000 Dutch Final Retail 9/7/2001 12:00:00 23552 bytes
amstream.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 64512 bytes
devenum.dll: 6.05.0001.0900 Dutch Final Retail 12/12/2002 00:14:32 132096 bytes
dxmasf.dll: 6.04.0009.1120 Dutch Final Retail 9/7/2001 12:00:00 498717 bytes
mciqtz32.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 34304 bytes
mpg2splt.ax: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 136192 bytes
msdmo.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 13312 bytes
encapi.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18944 bytes
qasf.dll: 9.00.0000.2980 Dutch Final Retail 12/20/2002 15:11:48 241664 bytes
qcap.dll: 6.05.0001.0900 Dutch Final Retail 12/12/2002 00:14:32 257024 bytes
qdv.dll: 6.05.0001.0900 Dutch Final Retail 12/12/2002 00:14:32 311808 bytes
qdvd.dll: 6.05.0001.0900 Dutch Final Retail 12/12/2002 00:14:32 449024 bytes
qedit.dll: 6.05.0001.0900 Dutch Final Retail 12/12/2002 00:14:32 1798144 bytes
qedwipes.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 733184 bytes
quartz.dll: 6.05.0001.0900 Dutch Final Retail 12/12/2002 00:14:32 1962496 bytes
strmdll.dll: 4.01.0000.3925 Dutch Final Retail 9/7/2001 12:00:00 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 9/7/2001 12:00:00 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 9/7/2001 12:00:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 9/7/2001 12:00:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 9/7/2001 12:00:00 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 9/7/2001 12:00:00 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 9/7/2001 12:00:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 9/7/2001 12:00:00 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 9/7/2001 12:00:00 154624 bytes
mswebdvd.dll: 6.05.0001.0900 Dutch Final Retail 12/12/2002 00:14:32 324096 bytes
msdvdopt.dll: 5.01.2600.0000 Dutch Final Retail 9/7/2001 12:00:00 75776 bytes
ks.sys: 5.03.0000.0900 Dutch Final Retail 12/12/2002 00:14:32 130304 bytes
ksproxy.ax: 5.03.0000.0900 Dutch Final Retail 12/12/2002 00:14:32 117248 bytes
ksuser.dll: 5.03.0000.0900 Dutch Final Retail 12/12/2002 00:14:32 4096 bytes
stream.sys: 5.03.0000.0900 Dutch Final Retail 12/12/2002 00:14:32 45696 bytes
mspclock.sys: 5.03.0000.0900 Dutch Final Retail 12/12/2002 00:14:32 5248 bytes
mspqm.sys: 5.01.2600.0000 Dutch Final Retail 8/23/2001 05:00:00 4608 bytes
mskssrv.sys: 5.03.0000.0900 Dutch Final Retail 12/12/2002 00:14:32 7424 bytes
swenum.sys: 5.03.0000.0900 Dutch Final Retail 12/12/2002 00:14:32 4096 bytes
mstee.sys: 5.03.0000.0900 Dutch Final Retail 12/12/2002 00:14:32 5504 bytes
bdaplgin.ax: 5.03.0000.0900 Dutch Final Retail 12/4/2002 01:33:40 16896 bytes
bdasup.sys: 5.03.0000.0900 English Final Retail 12/4/2002 02:03:54 11392 bytes
msdvbnp.ax: 6.05.0001.0900 English Final Retail 12/4/2002 01:33:20 52224 bytes
psisdecd.dll: 6.05.0001.0900 English Final Retail 12/4/2002 01:33:32 354816 bytes
psisrndr.ax: 6.05.0001.0900 English Final Retail 12/4/2002 01:33:24 30208 bytes
ipsink.ax: 5.03.0000.0900 Dutch Final Retail 12/4/2002 01:33:42 14848 bytes
mpeg2data.ax: 6.05.0001.0900 English Final Retail 12/4/2002 01:33:22 57856 bytes
ndisip.sys: 5.03.0000.0900 English Final Retail 12/6/2002 23:56:36 10112 bytes
mpe.sys: 5.03.0000.0900 English Final Retail 12/6/2002 23:55:36 15104 bytes
streamip.sys: 5.03.0000.0900 English Final Retail 12/4/2002 02:03:54 14976 bytes
msvidctl.dll: 6.05.0001.0900 English Final Retail 12/4/2002 01:34:46 1230336 bytes
slip.sys: 5.03.0000.0900 English Final Retail 12/4/2002 02:03:56 10880 bytes
nabtsfec.sys: 5.03.0000.0900 English Final Retail 12/4/2002 02:04:14 83968 bytes
ccdecode.sys: 5.03.0000.0900 English Final Retail 12/4/2002 02:04:12 16384 bytes
vbisurf.ax: 5.03.0000.0900 English Final Retail 12/4/2002 01:33:56 27648 bytes
msyuv.dll: 5.03.0000.0900 English Final Retail 12/4/2002 02:04:20 16896 bytes
kstvtune.ax: 5.03.0000.0900 Dutch Final Retail 12/4/2002 12:07:26 274432 bytes
ksxbar.ax: 5.03.0000.0900 English Final Retail 12/4/2002 01:33:50 39424 bytes
kswdmcap.ax: 5.03.0000.0900 Dutch Final Retail 12/4/2002 12:07:34 226304 bytes
wstcodec.sys: 5.03.0000.0900 English Final Retail 12/4/2002 02:04:12 18688 bytes
wstdecod.dll: 5.03.0000.0900 English Final Retail 12/4/2002 02:04:14 47104 bytes
msdv.sys: 5.01.2600.0000 English Final Retail 11/12/2002 19:15:30 52096 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
DivX Decoder Filter,0x00800000,1,1,divxdec.ax,1.00.0000.0001
Multiple VOB-MPEG2 Source,0x00200000,0,0,vobsrc.ax,1.00.0000.0002
Dump,0x00200000,1,0,vobdump.ax,8.00.0000.0010
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.0001.0900
DV Muxer,0x00400000,0,0,qdv.dll,6.05.0001.0900
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.0001.0900
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.2980
htAC3AudioDecoder,0x00600000,1,1,htac3audio.ax,1.00.0000.0001
VOB Stream Splitter,0x00200000,1,0,vobsplit2.ax,1.00.0000.0018
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.0001.0900
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.0001.0900
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4477
Honestech File Source (Async.),0x00400000,0,1,HT_Asyncflt.ax,1.00.0000.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0900
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4477
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.0001.0900
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.0001.0900
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.0001.0900
CyberLink Audio Effect,0x00600000,1,1,claudfx.ax,3.05.0000.1016
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0900
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.0001.0900
Honest Technology Video Encoder,0x00200000,1,0,ht_mpegvenc.ax,1.07.0000.0000
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.2980
DV Splitter,0x00600000,1,2,qdv.dll,6.05.0001.0900
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4477
honestech Mpeg1/2 Recorder Filter,0x00200000,2,0,htmpeg2enc.ax,1.00.0000.0001
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.0001.0900
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
htMPEG2VideoDecoder,0x00600000,1,1,htmpg2video.ax,1.01.0000.0008
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.2980
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
XviD MPEG-4 Video Decoder,0x00800000,1,1,xvid.ax,
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.0001.0900
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.2980
Video Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0900
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.0001.0900
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.0001.0900
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.0000.0900
Video Renderer,0x00400000,1,0,quartz.dll,6.05.0001.0900
htAudioTransFilter,0x00600000,1,1,htAudioTransFilter.ax,8.01.0000.0000
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.2980
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.0000.0900
DivX MPEG-4 DVD Video Decompressor ,0x00800000,1,1,DivX_c32.ax,4.01.0000.3917
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4477
htStillCap,0x00200000,1,1,htStillCap24.ax,1.00.0000.0001
File writer,0x00200000,1,0,qcap.dll,6.05.0001.0900
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.0001.0900
CyberLink Audio Decoder,0x00601000,1,1,claud.ax,3.05.0000.1004
CyberLink Video/SP Decoder,0x00600000,2,2,clvsd.ax,3.05.0000.1011
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.0001.0900
HT_SECURITY_ENGINE,0x00200000,2,0,HT_SecurityEngine.ax,1.01.0000.0002
AVI Draw,0x00600064,9,1,quartz.dll,6.05.0001.0900
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.2980
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.0001.0900
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.2980
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
VOB Stream Multiplexer,0x00200000,1,1,vobmult.ax,1.00.0000.0015
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.0001.0900
Null Renderer,0x00200000,1,0,qedit.dll,6.05.0001.0900
CyberLink DxVA Filter 2,0x00200000,0,2,Cldxva.ax,
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,6.05.0001.0900
IVF source filter,0x00600000,0,1,ivfsrc.ax,5.10.0002.0051
VOB MPEG2 Video Transcoder,0x00400000,1,1,vobtrans.ax,1.00.0000.0027
Smart Tee,0x00200000,1,2,qcap.dll,6.05.0001.0900
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.0001.0900
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0900
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.0001.0900
honestech LPCM Decode,0x00600000,1,1,htLPCMdec.ax,1.00.0000.0002
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.0001.0900
Wave Parser,0x00400000,1,1,quartz.dll,6.05.0001.0900
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.0001.0900
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.0001.0900
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.0001.0900
File stream renderer,0x00400000,1,1,quartz.dll,6.05.0001.0900
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.2980
VOB MPEG2 Video Codec,0x00800000,2,1,vobmpg2.ax,1.00.0000.0016
Honestech StillCapture,0x00200000,1,0,HTStillCap.ax,8.00.0000.0000
Honestech Video Invert Filter,0x00200000,1,1,ht_invert.ax,1.00.0000.0001
AVI Mux,0x00200000,1,0,qcap.dll,6.05.0001.0900
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.0001.0900
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.0001.0900
File Source (URL),0x00400000,0,1,quartz.dll,6.05.0001.0900
WMplug,0x009001f4,1,1,wtwmplug.ax,
VOB AC3 Audio Codec,0x00800000,1,1,VOBAC3.ax,1.00.0000.0017
Honest Technology Audio Encoder,0x00200000,1,0,ht_mpegaenc.ax,1.07.0000.0000
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.0001.0900
BDA MPEG2 Transport Information Filter,0x00200000,1,0,psisrndr.ax,6.05.0001.0900
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0900
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0000
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.0001.0900
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel akoestische echo-opheffing,0x00200000,2,2,,5.03.0000.0900
Microsoft Kernel GS Wavetable-synthesizer,0x00200000,1,1,,5.03.0000.0900
Microsoft Kernel DLS-synthesizer,0x00200000,1,1,,5.03.0000.0900
Microsoft Kernel DRM-audiodecoder,0x00200000,1,1,,5.03.0000.0900
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.0001.0900
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.0001.0900
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.0001.0900
DivX ;-) MPEG-4 Low-Motion,0x00200000,1,1,qcap.dll,6.05.0001.0900
DivX ;-) MPEG-4 Fast-Motion,0x00200000,1,1,qcap.dll,6.05.0001.0900
DivX Codec 4.12,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.0001.0900
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel IYUV-codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft MPEG-4 VKI Codec V2,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft MPEG-4 VKI Codec V3,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft MPEG-4 VKI Codec V1,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.0001.0900
XviD MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.0001.0900
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0900
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0900
ACELP.net,0x00200000,1,1,quartz.dll,6.05.0001.0900
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.0001.0900
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.0001.0900
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.0001.0900
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.0001.0900
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.0001.0900
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.0001.0900
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.0001.0900
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.0001.0900
Audio Capture Sources:
SB Live! Audio [D000],0x00200000,0,0,qcap.dll,6.05.0001.0900
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.0001.0900
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.0001.0900
MPU-401,0x00200000,1,0,quartz.dll,6.05.0001.0900
SB Live! MIDI Port [D000],0x00200000,1,0,quartz.dll,6.05.0001.0900
SB Live! Sw Synth [D000],0x00200000,1,0,quartz.dll,6.05.0001.0900
SB Live! Synth A [D000],0x00200000,1,0,quartz.dll,6.05.0001.0900
SB Live! Synth B [D000],0x00200000,1,0,quartz.dll,6.05.0001.0900
WDM Streaming Capture Devices:
,0x00000000,0,0,,
SB Live! MIDI Port [D000],0x00200000,2,2,,5.03.0000.0900
SB Live! Audio [D000],0x00200000,3,2,,5.03.0000.0900
WDM Streaming Rendering Devices:
,0x00000000,0,0,,
SB Live! DirectMusic Synthesizer [D000],0x00200000,1,1,,5.03.0000.0900
SB Live! Sw Synth [D000],0x00200000,1,1,,5.03.0000.0900
SB Live! Synth A [D000],0x00200000,1,1,,5.03.0000.0900
SB Live! Synth B [D000],0x00200000,1,1,,5.03.0000.0900
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,psisrndr.ax,6.05.0001.0900
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,6.05.0001.0900
WDM Streaming Mixer Devices:
Microsoft Kernel Wave-audiomixer,0x00200000,2,2,,5.03.0000.0900
Audio Renderers:
SB Live! Audio [D000],0x00200000,1,0,quartz.dll,6.05.0001.0900
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.0001.0900
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.0001.0900
DirectSound: SB Live! Audio [D000],0x00200000,1,0,quartz.dll,6.05.0001.0900
WDM Streaming System Devices:
MPU-401,0x00200000,3,2,,5.03.0000.0900
SB Live! DirectMusic Synthesizer [D000],0x00200000,10,2,,5.03.0000.0900
SB Live! Synth A [D000],0x00200000,3,2,,5.03.0000.0900
SB Live! Synth B [D000],0x00200000,12,2,,5.03.0000.0900
SB Live! Audio [D000],0x00200000,11,2,,5.03.0000.0900
  • Maarten
DirectX opnieuw geinstalleerd :?
nieuwe drivers voor je soundblaster live geinstalleerd :?
onder welk OS is dit :?
