"I've always found a fully Deployed Battle Group to be the most Effective Negotiator." Admiral Stark, High Guard, CY 9758
Google? Zie Chkdsk Runs Each Time That You Start Computer
Martin
chkdsk [driveletter] /Cc:\>chkntfs/?
Displays or modifies the checking of disk at boot time.
CHKNTFS volume [...]
CHKNTFS /D
CHKNTFS /T[:time]
CHKNTFS /X volume [...]
CHKNTFS /C volume [...]
volume Specifies the drive letter (followed by a colon),
mount point, or volume name.
/D Restores the machine to the default behavior; all drives are
checked at boot time and chkdsk is run on those that are
dirty.
/T:time Changes the AUTOCHK initiation count down time to the
specified amount of time in seconds. If time is not
specified, displays the current setting.
/X Excludes a drive from the default boot-time check. Excluded
drives are not accumulated between command invocations.
/C Schedules a drive to be checked at boot time; chkdsk will run
if the drive is dirty.
If no switches are specified, CHKNTFS will display if the specified drive is
dirty or scheduled to be checked on next reboot
Als het goed is zal de schijf worden gescheduled voor de volgende boot...
Thanks mrtnvnl, dit lijkt het te zijn, ga het direct proberen.
Anglico
Anglico
