[samba] kan de pc niet zien in werkgroep?!?!
  • 56 views sinds 30-01-2008
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
[global]
# workgroup = NT-Domain-Name or Workgroup-Name, eg: LINUX2
   workgroup = LAN
# server string is the equivalent of the NT Description field
   server string = Samba Server
# This option is important for security. It allows you to restrict
# connections to machines which are on your local network. The
# following example restricts access to two C class networks and
# the "loopback" interface. For more examples of the syntax see
# the smb.conf man page
;   hosts allow = 192.168.1. 192.168.2. 127.
# If you want to automatically load your printer list rather
# than setting them up individually then you'll need this
   load printers = no
# you may wish to override the location of the printcap file
;   printcap name = /etc/printcap
# on SystemV system setting printcap name to lpstat should allow
# you to automatically obtain a printer list from the SystemV spool
# system
;   printcap name = lpstat
# It should not be necessary to specify the print system type unless
# it is non-standard. Currently supported print systems include:
# bsd, sysv, plp, lprng, aix, hpux, qnx
;   printing = bsd
# Uncomment this if you want a guest account, you must add this to /etc/passwd
# otherwise the user "nobody" is used
;  guest account = pcguest
# this tells Samba to use a separate log file for each machine
# that connects
   log file = /var/log/samba.%m
# Put a capping on the size of the log files (in Kb).
   max log size = 50
# Security mode. Most people will want user level security. See
# security_level.txt for details.  NOTE:  To get the behaviour of
# Samba-1.9.18, you'll need to use "security = share".
  security = shar
# Use password server option only with security = server
# The argument list may include:
#   password server = My_PDC_Name [My_BDC_Name] [My_Next_BDC_Name]
# or to auto-locate the domain controller/s
#   password server = *
;   password server = <NT-Server-Name>
# Note: Do NOT use the now deprecated option of "domain controller"
# This option is no longer implemented.
# You may wish to use password encryption. Please read
# ENCRYPTION.txt, Win95.txt and WinNT.txt in the Samba documentation.
# Do not enable this option unless you have read those documents
   encrypt passwords = yes
# Where to find the SSL certificates:
   ssl CA certDir = /etc/ssl/certs
# Using the following line enables you to customise your configuration
# on a per machine basis. The %m gets replaced with the netbios name
# of the machine that is connecting
;   include = /usr/local/samba/lib/smb.conf.%m
# Most people will find that this option gives better performance.
# See speed.txt and the manual pages for details
# You may want to add the following on a Linux system:
#         SO_RCVBUF=8192 SO_SNDBUF=8192
   socket options = TCP_NODELAY
# Configure Samba to use multiple interfaces
# If you have multiple network interfaces then you must list them
# here. See the man page for details.
    interfaces = 192.168.0.100/24
# Browser Control Options:
# set local master to no if you don't want Samba to become a master
# browser on your network. Otherwise the normal election rules apply
;   local master = no
# OS Level determines the precedence of this server in master browser
# elections. The default value should be reasonable
;   os level = 33
# Domain Master specifies Samba to be the Domain Master Browser. This
# allows Samba to collate browse lists between subnets. Don't use this
# if you already have a Windows NT domain controller doing this job
;   domain master = yes
# Preferred Master causes Samba to force a local browser election on startup
# and gives it a slightly higher chance of winning the election
;   preferred master = yes
# Enable this if you want Samba to be a domain logon server for
# Windows95 workstations.
;   domain logons = yes
# if you enable domain logons then you may want a per-machine or
# per user logon script
# run a specific logon batch file per workstation (machine)
;   logon script = %m.bat
# run a specific logon batch file per username
;   logon script = %U.bat
# Where to store roving profiles (only for Win95 and WinNT)
#        %L substitutes for this servers netbios name, %U is username
#        You must uncomment the [Profiles] share below
;   logon path = \\%L\Profiles\%U
# Windows Internet Name Serving Support Section:
# WINS Support - Tells the NMBD component of Samba to enable it's WINS Server
;   wins support = yes
# WINS Server - Tells the NMBD components of Samba to be a WINS Client
#       Note: Samba can be either a WINS Server, or a WINS Client, but NOT both
;   wins server = w.x.y.z
# WINS Proxy - Tells Samba to answer name resolution queries on
# behalf of a non WINS capable client, for this to work there must be
# at least one  WINS Server on the network. The default is NO.
;   wins proxy = yes
# DNS Proxy - tells Samba whether or not to try to resolve NetBIOS names
# via DNS nslookups. The built-in default for versions 1.9.17 is yes,
# this has been changed in version 1.9.18 to no.
   dns proxy = no
#============================ Share Definitions ==============================
;[homes]
   comment = Home Directories
   browseable = yes
   writable = yes
# Un-comment the following and create the netlogon directory for Domain Logons
; [netlogon]
;   comment = Network Logon Service
;   path = /usr/local/samba/lib/netlogon
;   guest ok = yes
;   writable = no
;   share modes = no
# Un-comment the following to provide a specific roving profile share
# the default is to use the user's home directory
;[Profiles]
;    path = /usr/local/samba/profiles
;    browseable = no
;    guest ok = yes
# NOTE: If you have a BSD-style print system there is no need to
# specifically define each individual printer
;[printers]
;  comment = All Printers
;  path = /var/spool/samba
;  browseable = no
# Set public = yes to allow user 'guest account' to print
;  guest ok = no
;  writable = no
;  printable = yes
# This one is useful for people to share files
;[tmp]
;   comment = Temporary file space
;   path = /tmp
;   read only = no
;   public = yes
# A publicly accessible directory, but read only, except for people in
# the "staff" group
;[public]
;   comment = Public Stuff
;   path = /home/samba
;   public = yes
;   writable = yes
;   printable = no
;   write list = @staff
# Other examples.
# A private printer, usable only by fred. Spool data will be placed in fred's
# home directory. Note that fred must have write access to the spool directory,
# wherever it is.
;[fredsprn]
;   comment = Fred's Printer
;   valid users = fred
;   path = /homes/fred
;   printer = freds_printer
;   public = no
;   writable = no
;   printable = yes
# A private directory, usable only by fred. Note that fred requires write
# access to the directory.
;[fredsdir]
;   comment = Fred's Service
;   path = /usr/somewhere/private
;   public = no
;   writable = yes
;   printable = no
# a service which has a different directory for each machine that connects
# this allows you to tailor configurations to incoming machines. You could
# also use the %U option to tailor it by user name.
# The %m gets replaced with the machine name that is connecting.
;[pchome]
;  comment = PC Directories
;  path = /usr/pc/%m
;  public = no
;  writable = yes
# A publicly accessible directory, read/write to all users. Note that all files
# created in the directory by users will be owned by the default user, so
# any user with access can delete any other user's files. Obviously this
# directory must be writable by the default user. Another user could of course
# be specified, in which case all files would be owned by that user instead.
;[public]
;   path = /usr/somewhere/else/public
;   public = yes
;   only guest = yes
;   writable = yes
;   printable = no
# The following two entries demonstrate how to share a directory so that two
# users can place files there that will be owned by the specific users. In this
# setup, the directory should be writable by both users and should have the
# sticky bit set on it to prevent abuse. Obviously this could be extended to
# as many users as required.
 [FTP]
    comment = FTP folder
    path = /ftp/
    public = yes
    writable = yes
    printable = no
 [WWW]
    comment = WWW folder
    path = /www/
    public = yes
    writable = yes
    printable = no
mijn config
het probleem:
alles werkt perfect behalve dat ik in 2000 (de pc waar ik het nu mee test) de pc niet kan zien in de werkgroep (LAN). ik kom er dus wel op als ik \\het ipvandelinuxmachine intik
wat doe ik vout? ;)
[ Voor 4% gewijzigd door Verwijderd op 22-05-2003 04:31 ]
  • Leon
  • Laatst online: 19-08 12:12
Leon
Rise Of The Robots
wat doe ik vout? ;)
Je openingspost, die is helemaal verkeerd. Mischien als je dat veranderd dat het dan werkt :P
Heb je trouwens al geprobeerd om samba als prefered master op te geven en wins support aan te zetten :?
En om in plaats van security=shar, security=share op te geven?
de ; voor [homes] moet trouwens ook weg.. ;)
Eeuwige n00b
security = shar
share misschien?
dit wil niet helpen :'(
ik heb al van alles geprobeerd maar in de werkgroep wordt ie gewoon niet gezien
  • MrC4u
  • Laatst online: 28-08 16:16
Je hebt [Homes] nog niet leesbaar voor samba gemaakt. De regels daaronder wel, maar deze niet ;). Verder kan je de configuratie testen door het programma 'testparm' te starten.
..: De 3 H's van Microsoft: Herhalen, Herstarten en Herinstalleren :..
  • Wilke
  • Laatst online: 12:57
Daarnaast helpt het ook om niet alleen smbd maar ook nmbd te draaien; of je config 'correct' is kun je inderdaad ook testen (zoals hierboven staat).
Verder is dit wel een vrij basic vraagje wat ook met behulp van documentatie e.d. wel uit te vinden is - daarnaast geef je ook totaal niet aan zelf al iets ondernomen of opgezocht te hebben.
Daarom gaat dit topic dicht.
