AMS-IX problemen?
  • 232 views sinds 30-01-2008
Heel internet is hier zo traag als de pest en begon me op te vallen toen ik op tweakers.net zat te surfen.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
C:\>tracert trueserver.nl
Bezig met het traceren van de route naar trueserver.nl [213.239.129.46]
via maximaal 30 hops:
  1    30 ms    20 ms    20 ms  e110065.upc-e.chello.nl [213.93.110.65]
  2    50 ms    30 ms   100 ms  atm11-0.ah00rt04.brain.upc.nl [212.142.27.2]
  3    40 ms    30 ms    40 ms  srp0-0.am00rt02.brain.upc.nl [212.142.32.2]
  4    30 ms    30 ms    30 ms  srp0-0.am00rt06.brain.upc.nl [212.142.32.44]
  5    30 ms    30 ms    30 ms  nl-ams01a-rd1-pos-3-0.aorta.net [213.46.161.53]
  6    30 ms    30 ms    30 ms  nl-ams04a-ri-gige5-2-4.aorta.net [213.46.161.193
  7    30 ms    70 ms    30 ms  nl-ams02a-rd1-10gige-7-0.aorta.net [213.46.161.5
8]
  8    30 ms    31 ms    30 ms  nl-ams04a-ri1-pos-6-0.aorta.net [213.46.161.62]
  9   631 ms   631 ms   631 ms  ge0-0-0.ams-ix.ams1.trueserver.nl [193.148.15.16
3]
 10   631 ms   631 ms   641 ms  noc.trueserver.nl [213.239.129.46]
De trace is voltooid.
C:\>tracert io.nl
Bezig met het traceren van de route naar io.nl [81.17.33.3]
  1   100 ms    30 ms    20 ms  e110065.upc-e.chello.nl [213.93.110.65]
  2    30 ms    30 ms    30 ms  atm11-0.ah00rt04.brain.upc.nl [212.142.27.2]
  3    91 ms    30 ms    40 ms  srp0-0.am00rt02.brain.upc.nl [212.142.32.2]
  4    40 ms    30 ms    20 ms  srp0-0.am00rt05.brain.upc.nl [212.142.32.43]
  5    30 ms    30 ms    60 ms  nl-ams01a-rd1-pos-0-3.aorta.net [213.46.161.45]
  6    30 ms    30 ms    40 ms  nl-ams04a-ri1-ge-3-0.aorta.net [213.46.161.189]
  7    30 ms    30 ms    30 ms  nl-ams02a-rd1-10gige-7-0.aorta.net [213.46.161.5
8]
  8    30 ms    40 ms    30 ms  nl-ams04a-ri1-pos-6-0.aorta.net [213.46.161.62]
  9    30 ms    40 ms    30 ms  pos0-1.mpr1.ams1.nl.mfnx.net [62.4.95.241]
 10    40 ms    30 ms    30 ms  pos2-0.cr2.ams2.nl.mfnx.net [208.184.231.254]
 11    30 ms    40 ms    20 ms  pos0-3.er1b.ams2.nl.mfnx.net [208.184.210.206]
 12    60 ms    41 ms    90 ms  core-1.io.nl [193.148.15.218]
 13    30 ms    30 ms    40 ms  81.17.33.3
C:\>tracert netholding.n l
^C
C:\>tracert netholding.nl
Bezig met het traceren van de route naar netholding.nl [81.23.225.238]
  1    30 ms    20 ms    30 ms  e110065.upc-e.chello.nl [213.93.110.65]
  2    20 ms    30 ms    40 ms  atm11-0.ah00rt04.brain.upc.nl [212.142.27.2]
  3    30 ms    30 ms    30 ms  srp0-0.am00rt02.brain.upc.nl [212.142.32.2]
  4    30 ms    30 ms    30 ms  srp0-0.am00rt05.brain.upc.nl [212.142.32.43]
  5    40 ms    30 ms    30 ms  nl-ams01a-rd1-pos-0-3.aorta.net [213.46.161.45]
  6    30 ms    30 ms    30 ms  nl-ams04a-ri1-ge-3-0.aorta.net [213.46.161.189]
  7    30 ms    30 ms    40 ms  nl-ams02a-rd1-10gige-7-0.aorta.net [213.46.161.5
8]
  8    30 ms    30 ms    40 ms  nl-ams04a-ri1-pos-6-0.aorta.net [213.46.161.62]
  9   611 ms   611 ms   611 ms  amsix.globalswitch.netholding.nl [193.148.15.79]
 10   600 ms   621 ms   601 ms  www.garnierprojects.com [81.23.225.238]
C:\>
telkens bij de AMS-IX routers gaat het fout, Femme, Kees, Anton wie weet wat er aan de hand is?
Denk eerder dat het bij Chello->AMS-IX zit, vanaf hier (euronet) totaal geen problemen.
Verwijderd schreef op 20 mei 2003 @ 17:29:
zouden dan niet de pings bij de aorta al flink de hoogte in moeten schieten? Hij knalt er nu 1 stap verder in zeg maar
Verwijderd schreef op 20 mei 2003 @ 17:30:
Nee, het probleem kan op hop x zitten of ervoor. In dit geval lijkt het probleem er net voor te zitten.
  • Heineken
Heineken
Tweaker sinds 1999
Ik heb gewoon een ping van 14 ms op tweakers.net.
Als ik echter nl-ams04a-ri1-pos-6-0.aorta.net ping is dit 841 ms.
| Hop | IP Address      | Node Name                        | ms  | Network               |
| 0   | 10.10.0.3       | Gerrit                           |     | (private use)         |
| 1   | 195.190.241.244 | -                                | 11  | KPN Internet Operator |
| 2   | 194.109.5.165   | 32.ge-0-0-0.xr1.pbw.xs4all.net   | 12  | XS4ALL Internet BV    |
| 3   | 134.222.199.61  | asd2-rou-1001.NL.eurorings.net   | 229 | 134.222.199.0         |
| 4   | 134.222.96.37   | ledn-rou-1001.NL.eurorings.net   | 235 | 134.222.96.0          |
| 5   | 134.222.96.86   | asd-s4-rou-1001.NL.eurorings.net | 235 | 134.222.96.0          |
| 6   | 213.46.161.62   | nl-ams04a-ri1-pos-6-0.aorta.net  | 841 | Chello Broadband      |
  • kamerplant
Chello -> T.net gaat hier ook traag.
Chello -> xs4all.nl ook, wat normaal retesnel gaat.
maar speedtest.nl gaat wel weer lekker. Tsja, dat wordt niet voor niks in advertenties van Chello gebruikt :X
  • Erkens
Erkens
Fotograaf
Verwijderd schreef op 20 May 2003 @ 17:27:
*knip*
mja, ok, hij wordt dus traag @ AMS-IX, waarom dan in Lieve Adjes heeft toch niets met t.net/GoT te maken dan :?
  • JvS
  • Laatst online: 23:05
JvS
Ik heb hem zelf ook
Heineken schreef op 20 mei 2003 @ 17:37:
Ik heb exact dezelfde resultaten vanaf een planet adsl lijntje, maar wat dat in LA doet is me niet helemaal duidelijk ;).
>> internet en telefonie dus ;)
Het is dus de aorta server van chello die moeilijk doet, misschien meer iets voor het grote chello storingentopci ;).
[ Voor 19% gewijzigd door JvS op 20-05-2003 17:47 ]
  • Pc123
  • Laatst online: 22:03
Ik heb net een topic omhoog geschopt van eerder vandaag over Chello ping problemen, exact dezelfde situatie hier:
5 29 ms 29 ms 29 ms srp0-0.am00rt06.brain.upc.nl [212.142.32.44]
6 30 ms 29 ms 30 ms nl-ams01a-rd1-pos-3-0.aorta.net [213.46.161.53]
7 30 ms 29 ms 29 ms nl-ams04a-ri1-ge-3-0.aorta.net [213.46.161.189]
8 31 ms 29 ms 29 ms nl-ams02a-rd1-10gige-7-0.aorta.net [213.46.161.5
8]
9 30 ms 28 ms 29 ms nl-ams04a-ri1-pos-6-0.aorta.net [213.46.161.62]
10 675 ms 673 ms 675 ms ge0-0-0.ams-ix.ams1.trueserver.nl [193.148.15.16
3]
11 676 ms 683 ms 684 ms www.tweakers.net [213.239.154.35]
Het lijkt niet aan de AMS-IX te liggen, alle andere providers hebben er geen last van.
Pc123 schreef op 20 May 2003 @ 17:50:
8]
3]
nee idd, foutje van mij ik dacht dat het aan ams-ix zou liggen omdat de laatste hop van chello nog wel snel was nl. excuses excuses.... :)
  • Xandrios
  • Laatst online: 30-08 22:59
Blijkbaar heeft de (Aorta?) router van Chello problemen. De AMS-IX heeft iig verder geen problemen :)
Deze dicussie (voor zover er nog wat te discussieren valt ;) ) kan dus worden voortgezet in het algemene Chello problemen topic :)
