[java]Image Scroll Script right-left -> down-up
  • 41 views sinds 30-01-2008
Ik heb een script gevonden dat ik mag aanpassen. Maar hij laat plaatjes scrollen van rechts naar links, kan iemand dat voor mij aanpassen dat ie van beneden naar boven scrolt?
in de body:
<script language="JavaScript1.2">
var sliderwidth="110px"
var sliderheight="182px"
var slidespeed=2
slidebgcolor="#303030"
var leftrightslide=new Array()
var finalslide=''
leftrightslide[0]='<a href="http://">[img]"1.jpg"[/img]</a>'
leftrightslide[1]='<a href="http://">[img]"2.jpg"[/img]</a>'
leftrightslide[2]='<a href="http://">[img]"3.jpg"[/img]</a>'
leftrightslide[3]='<a href="http://">[img]"4.jpg"[/img]</a>'
var copyspeed=slidespeed
leftrightslide='<nobr>'+leftrightslide.join(" ")+'</nobr>'
var iedom=document.all||document.getElementById
if (iedom)
document.write('<span id="temp" style="visibility:hidden;position:absolute;top:-100px;left:-9000px">'+leftrightslide+'</span>')
var actualwidth=''
var cross_slide, ns_slide
function fillup(){
if (iedom){
cross_slide=document.getElementById? document.getElementById("test2") : document.all.test2
cross_slide2=document.getElementById? document.getElementById("test3") : document.all.test3
cross_slide.innerHTML=cross_slide2.innerHTML=leftrightslide
actualwidth=document.all? cross_slide.offsetWidth : document.getElementById("temp").offsetWidth
cross_slide2.style.left=actualwidth+20+"px"
else if (document.layers){
ns_slide=document.ns_slidemenu.document.ns_slidemenu2
ns_slide2=document.ns_slidemenu.document.ns_slidemenu3
ns_slide.document.write(leftrightslide)
ns_slide.document.close()
actualwidth=ns_slide.document.width
ns_slide2.left=actualwidth+20
ns_slide2.document.write(leftrightslide)
ns_slide2.document.close()
lefttime=setInterval("slideleft()",30)
window.onload=fillup
function slideleft(){
if (iedom){
if (parseInt(cross_slide.style.left)>(actualwidth*(-1)+8))
cross_slide.style.left=parseInt(cross_slide.style.left)-copyspeed+"px"
else
cross_slide.style.left=parseInt(cross_slide2.style.left)+actualwidth+30+"px"
if (parseInt(cross_slide2.style.left)>(actualwidth*(-1)+8))
cross_slide2.style.left=parseInt(cross_slide2.style.left)-copyspeed+"px"
else
cross_slide2.style.left=parseInt(cross_slide.style.left)+actualwidth+30+"px"
if (ns_slide.left>(actualwidth*(-1)+8))
ns_slide.left-=copyspeed
else
ns_slide.left=ns_slide2.left+actualwidth+30
if (ns_slide2.left>(actualwidth*(-1)+8))
ns_slide2.left-=copyspeed
else
ns_slide2.left=ns_slide.left+actualwidth+30
if (iedom||document.layers){
with (document){
document.write('<table border="0" cellspacing="0" cellpadding="0"><td>')
if (iedom){
write('<div style="position:relative;z-index:1;left:331px;top:265px;width:'+sliderwidth+';height:'+sliderheight+';overflow:hidden">')
write('<div style="position:absolute;left:0px;top:0px;width:'+sliderwidth+';height:'+sliderheight+';background-color:'+slidebgcolor+'" onMouseover="copyspeed=1" onMouseout="copyspeed=slidespeed">')
write('<div id="test2" style="position:absolute;left:0px;top:0px"></div>')
write('<div id="test3" style="position:absolute;left:0px;top:0px"></div>')
write('</div></div>')
write('<ilayer width='+sliderwidth+' height='+sliderheight+' name="ns_slidemenu" bgColor='+slidebgcolor+'>')
write('<layer name="ns_slidemenu2" onMouseover="copyspeed=1" onMouseout="copyspeed=slidespeed"></layer>')
write('<layer name="ns_slidemenu3" onMouseover="copyspeed=1" onMouseout="copyspeed=slidespeed"></layer>')
write('</ilayer>')
document.write('</td></table>')
</script>
ik heb hem al redelijk aangepast, maar ik kom niet verder met het veranderen van de richting van de scroll!!
  • reskobon
  • Laatst online: 14-08 22:26
Uhm dit klinkt nogal erg als een scriptrequest :)
Geef ook wat duidelijker je probleem aan en dan nog even je code binnen code tags dan is het al wat beter te lezen.
Leeg
ok, sorry, maar het probleem is dat ie nu plaatjes laat zien, scrollend van rechts naar links, maar ik moet de plaatjes scrollend hebben van beneden naar boven. Misschien dat iemand dat zo op het eerste oog ziet. Ik heb al van alles geprobeerd! :?
  • TeeDee
  • Laatst online: 22-08 13:14
TeeDee
CQB 241
Dit lijkt mij ook javascript, dus naar /13?
Heart..pumps blood.Has nothing to do with emotion! Bored
  • Janoz
  • Laatst online: 10:39
Janoz
Moderator Devschuur®
!litemod
1. Java =/= javascript, en Javascript hoort in Webdesign & graphics
2. 't Is hier geen helpdesk. Geef duidelijk aan waar je probleem zit en waar je niet uitkomt. Het is niet de bedoeling om maar een lap source plus je wensen neer te planten
3. Er zijn een aantal tags die de leesbaarheid van sourcecode bevorderen
Kortom. Kijk ff in de faq hier en van Webdesign & Graphics zodat je volgende topic wat meer aan de policies voldoet.
