[DHCP] client specifiek ip adres laten verzoeken
  • vargo
  • Laatst online: 22:03
Is het mogelijk om een DHCP request te laten plaats vinden, waarbij je om een specifiek ip adres vraagt.
Mijn servertje is nl zijn oude lease kwijtgeraakt, maar ik zou graag nog even willen proberen een 'nieuwe lease' te krijgen met het oude ip adres.
/Edit: Os is win2k
/Edit2:
Mijn MAC adres is overigens niet veranderd.
Verder hier nog wat info die ik zelf had gevonden:
DHCP Lease Process
DHCP leases are used to reduce DHCP network traffic by giving clients specific addresses for set periods of time. The DHCP process stages can be remembered using the ROSA acronym:
Request - A broadcast is sent by the client with the client MAC address. This is a DHCP discover message with source IP address of 0.0.0.0 and destination address of 255.255.255.255. The client tries to get its last address. If it is not available, the DHCP server will send a NACK signal. The client state is initialization during the request stage.
Offer - A DHCP offer message is sent from the DHCP server with some or all the optional information as listed above. Information sent includes the IP address of the DHCP server that sent the accepted offer. All offered IP addresses are marked unavailable by the DHCP server when the DHCP server offers them until they are rejected. The client is in the selecting state during this offer stage.
Selection (or acceptance) - The first offer received by the client is accepted. The client broadcasts its selected choice using a DHCP request message which includes the IP address of the DNS server that sent the accepted offer. The client is in the requesting state during this selection stage.
Acknowledgement - The server acknowledges with a DHCP acknowledge indicating the client can use the address or it will send a DHCP Nak instructing the client that the address became unavailable. Other DHCP servers retract their offers and mark the offered address as available and the accepted address as unavailable. Any offered IP addresses not selected are freed to be used again. The client state is the binding state during this acknowledgement stage.
When the client sends the lease request, it then waits one second for an offer. If a response is not received, the request is repeated at 9, 13, and 16 second intervals with additional 0 to 1000 milliseconds of randomness. The attempt is repeated every 5 minutes thereafter. The client uses port 67 and the server uses port 68.
Client systems that are Windows 98 or later attempt to tell if another client is already using the address received from the DHCP server by pinging the address. The DHCP server can be configured to pretest addresses by pinging them, but this will increase overhead and slow server response time.
en verder:
DHCP backup interval
Configured in the registry at:
\hkey\local_machine\system\currentcontrolset\services\dhcp\server\parameters
DHCP files are stored in "SystemRoot\System32\Dhcp
hier heb ik echter niets nuttigs kunnen vinden.
Bron: http://ctdp.tripod.com/os/windows/win2k/index.html
[ Voor 91% gewijzigd door vargo op 18-05-2003 22:32 ]
  • Illegal_Alien
Illegal_Alien
PanzerAirlines.nl Rulezzzz
Er van wie of wat krijgt hij z`n IP? Graag meer info!
Anders zorgen dat hij een vast ip krijgt, (Staat in manual van b.v. je Router (als je die hebt dan))
[ Voor 55% gewijzigd door Illegal_Alien op 18-05-2003 22:27 ]
Officieel AchtbaanFreak ©2004
  • Erkens
Erkens
Fotograaf
Illegal_Alien schreef op 18 May 2003 @ 22:26:
ik denk dat TS bedoeld dat hij van zijn isp een nieuwe lease heeft gehad maar hij het oude ip liever wilt hebben ;)
echter vargo, als dit mogelijk was dan zou je gestuit zijn op de dhcp server van je isp, aangezien deze ip's koppelt aan mac'adressen ;)
en die heeft nu een ander ip eraan gekoppeld.
Van je isp krijg je een willekeurig adres. Soms krijg je dezelfde..soms niet :) Als het een netwerk is waar je het over hebt dan kun je gewoon "reservations" maken. IP adressen worden dan gekoppeld aan namen en/of MAC adressen. (het zijn mac adressen, maar je kan je machine naam opgeven en adh daarvan pakt hij het MAC adres)
Kortgezegd is je lease nu verlopen en je ip is in gebruik door iemand anders. Doe je niks aan.
  • vargo
Erkens schreef op 18 May 2003 @ 22:28:
Precies, ik heb inmiddels een nieuwe lease gekregen met een ander ip adres. Ik weet dat ik zou kunnen proberen het ip adres statisch vast te leggen, maar aangezien dat niet mag doe ik dat ook niet.
Mijn gedachte was echter 'wat als ik nu een nieuwe lease aanvraag met als het ware een voorkeur voor een bepaald ip adres' (nl mijn oude).
Ik snap dat wanneer die lease reeds aan een ander is toegekend dat ik die niet meer kan krijgen, maar het lijkt me toch het proberen waard.
  • Erkens
Erkens
Fotograaf
vargo schreef op 18 May 2003 @ 22:37:
dan zou je moeten klooien in je dhcp client settings, en vervolgens geeft de dhcp server jou gewoon weer het ip wat je al eerder van hem had gehad, wat jij wilt is niet mogelijk zonder de dhcp server aan te passen ;)
maar je kan ook een dyndns naam nemen, zodat je je ip niet meer hoeft te onthouden ;)
