Dit is de config.inc.php, het password heb k even weggelaten, wat staat er volgens jullie fout?
<?php
/* $Id: config.inc.php,v 1.80 2002/04/17 01:48:32 lem9 Exp $ */
* phpMyAdmin Configuration File
* All directives are explained in Documentation.html
* Bookmark Table Structure
* CREATE TABLE bookmark (
* id int(11) DEFAULT '0' NOT NULL auto_increment,
* dbase varchar(255) NOT NULL,
* user varchar(255) NOT NULL,
* label varchar(255) NOT NULL,
* query text NOT NULL,
* PRIMARY KEY (id)
* Your phpMyAdmin url
* Complete the variable below with the full url ie
http://riseandshine32.coolfreepage.com/phpmyadmin/
* It must contain characters that are valid for a URL, and the path is
* case sensitive on some Web servers, for example Unix-based servers.
$cfgPmaAbsoluteUri = 'http://riseandshine32.coolfreepage.com/mysql/';
* Server(s) configuration
$i = 0;
// The $cfgServers array starts with $cfgServers[1]. Do not use $cfgServers[0].
// You can disable a server config entry by setting host to ''.
$i++;
$cfgServers[$i]['host'] = 'localhost'; // MySQL hostname
$cfgServers[$i]['port'] = ''; // MySQL port - leave blank for default port
$cfgServers[$i]['socket'] = ''; // Path to the socket - leave blank for default socket
$cfgServers[$i]['connect_type'] = 'tcp'; // How to connect to MySQL server ('tcp' or 'socket')
$cfgServers[$i]['controluser'] = ''; // MySQL control user settings
// (this user must have read-only
$cfgServers[$i]['controlpass'] = ''; // access to the "mysql/user"
// and "mysql/db" tables)
$cfgServers[$i]['auth_type'] = 'config'; // Authentication method (config, http or cookie based)?
$cfgServers[$i]['user'] = 'nacr174'; // MySQL user
$cfgServers[$i]['password'] = ''; // MySQL password (only needed
// with 'config' auth_type)
$cfgServers[$i]['only_db'] = ''; // If set to a db-name, only
// this db is displayed
// at left frame
// It may also be an array
// of db-names
$cfgServers[$i]['verbose'] = ''; // Verbose name for this host - leave blank to show the hostname
$cfgServers[$i]['bookmarkdb'] = ''; // Bookmark db - leave blank for no bookmark support
$cfgServers[$i]['bookmarktable'] = ''; // Bookmark table - leave blank for no bookmark support
$cfgServers[$i]['relation'] = ''; // table to describe the relation between links (see doc)
// - leave blank for no relation-links support
$i++;
$cfgServers[$i]['host'] = '';
$cfgServers[$i]['user'] = 'root';
$i++;
// If you have more than one server configured, you can set $cfgServerDefault
// to any one of them to autoconnect to that server when phpMyAdmin is started,
// or set it to 0 to be given a list of servers without logging in
// If you have only one server configured, $cfgServerDefault *MUST* be
// set to that server.
$cfgServerDefault = 1; // Default server (0 = no default server)
$cfgServer = '';
unset($cfgServers[0]);
* Other core phpMyAdmin settings
$cfgOBGzip = TRUE; // use GZIP output buffering if possible
$cfgPersistentConnections = FALSE; // use persistent connections to MySQL database
$cfgExecTimeLimit = 300; // maximum execution time in seconds (0 for no limit)
$cfgSkipLockedTables = FALSE; // mark used tables, make possible to show
// locked tables (since MySQL 3.23.30)
$cfgShowSQL = TRUE; // show SQL queries as run
$cfgAllowUserDropDatabase = FALSE; // show a 'Drop database' link to normal users
$cfgConfirm = TRUE; // confirm 'DROP TABLE' & 'DROP DATABASE'
$cfgLoginCookieRecall = TRUE; // recall previous login in cookie auth. mode or not
// Left frame setup
$cfgLeftFrameLight = TRUE; // use a select-based menu and display only the
// current tables in the left frame.
$cfgShowTooltip = TRUE; // display table comment as tooltip in left frame
// In the main frame, at startup...
$cfgShowStats = TRUE; // allow to display statistics and space usage in
// the pages about database details and table
// properties
$cfgShowMysqlInfo = FALSE; // whether to display the "MySQL runtime
$cfgShowMysqlVars = FALSE; // information", "MySQL system variables", "PHP
$cfgShowPhpInfo = FALSE; // information" and "change password" links for
$cfgShowChgPassword = FALSE; // simple users or not
// In browse mode...
$cfgShowBlob = FALSE; // display blob field contents
$cfgNavigationBarIconic = TRUE; // do not display text inside navigation bar buttons
$cfgShowAll = FALSE; // allows to display all the rows
$cfgMaxRows = 30; // maximum number of rows to display
$cfgOrder = 'ASC'; // default for 'ORDER BY' clause (valid
// values are 'ASC', 'DESC' or 'SMART' -ie
// descending order for fields of type
// TIME, DATE, DATETIME & TIMESTAMP,
// ascending order else-)
// In edit mode...
$cfgProtectBinary = 'blob'; // disallow editing of binary fields
// valid values are:
// FALSE allow editing
// 'blob' allow editing except for BLOB fields
// 'all' disallow editing
$cfgShowFunctionFields = TRUE; // Display the function fields in edit/insert mode
// For the export features...
$cfgZipDump = TRUE; // Allow the use of zip/gzip/bzip
$cfgGZipDump = TRUE; // compression for
$cfgBZipDump = TRUE; // dump files
* Link to the official MySQL documentation
* Be sure to include no trailing slash on the path
$cfgManualBaseShort = 'http://www.mysql.com/doc';
* Language settings
// Default language to use, if not browser-defined or user-defined
$cfgDefaultLang = 'en';
// Force: always use this language - must be defined in
// libraries/select_lang.lib.php
// $cfgLang = 'en';
// Loads language file
require('./libraries/select_lang.lib.php');
* Customization & design
$cfgLeftWidth = 150; // left frame width
$cfgLeftBgColor = '#D0DCE0'; // background color for the left frame
$cfgLeftPointerColor = '#CCFFCC'; // color of the pointer in left frame
// (blank for no pointer)
$cfgRightBgColor = '#F5F5F5'; // background color for the right frame
$cfgBorder = 0; // border width on tables
$cfgThBgcolor = '#D3DCE3'; // table header row colour
$cfgBgcolorOne = '#CCCCCC'; // table data row colour
$cfgBgcolorTwo = '#DDDDDD'; // table data row colour, alternate
$cfgBrowsePointerColor = '#CCFFCC'; // color of the pointer in browse mode
$cfgBrowseMarkerColor = '#FFCC99'; // color of the marker (visually marks row
// by clicking on it) in browse mode
// (blank for no marker)
$cfgTextareaCols = 40; // textarea size (columns) in edit mode
$cfgTextareaRows = 7; // textarea size (rows) in edit mode
$cfgLimitChars = 50; // max field data length in browse mode
$cfgModifyDeleteAtLeft = TRUE; // show edit/delete links on left side of browse
// (or at the top with vertical browse)
$cfgModifyDeleteAtRight = FALSE; // show edit/delete links on right side of browse
// (or at the bottom with vertical browse)
$cfgDefaultDisplay = 'horizontal'; // default display direction (horizontal|vertical)
$cfgRepeatCells = 100; // repeat header names every X cells? (0 = deactivate)
* MySQL settings
// Column types;
// varchar, tinyint, text and date are listed first, based on estimated popularity
$cfgColumnTypes = array(
'VARCHAR',
'TINYINT',
'TEXT',
'DATE',
'SMALLINT',
'MEDIUMINT',
'INT',
'BIGINT',
'FLOAT',
'DOUBLE',
'DECIMAL',
'DATETIME',
'TIMESTAMP',
'TIME',
'YEAR',
'CHAR',
'TINYBLOB',
'TINYTEXT',
'BLOB',
'MEDIUMBLOB',
'MEDIUMTEXT',
'LONGBLOB',
'LONGTEXT',
'ENUM',
'SET'
// Atributes
$cfgAttributeTypes = array(
'BINARY',
'UNSIGNED',
'UNSIGNED ZEROFILL'
// Available functions
if ($cfgShowFunctionFields) {
$cfgFunctions = array(
'ASCII',
'CHAR',
'SOUNDEX',
'LCASE',
'UCASE',
'NOW',
'PASSWORD',
'MD5',
'ENCRYPT',
'RAND',
'LAST_INSERT_ID',
'COUNT',
'AVG',
'SUM',
'CURDATE',
'CURTIME',
'FROM_DAYS',
'FROM_UNIXTIME',
'PERIOD_ADD',
'PERIOD_DIFF',
'TO_DAYS',
'UNIX_TIMESTAMP',
'USER',
'WEEKDAY'
} // end if
* Unset magic_quotes_runtime - do not change!
set_magic_quotes_runtime(0);
