WebMessenger en hostname
  • 50 views sinds 30-01-2008
hallo,
ik wil zelf een msn webclient opzetten en heb hier een stukje software voor gevonden (WebMessenger) je moet dan verbinding maken met een "jabber" server. ik heb er een aantal gevonden in een public jabber server list maar geen van alle werken. ik kom wel op het jabber netwerk maar ik wil op de msn server komen en msn-en
weet iemand een oplossing
hieronder de config.php
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
<?php
// Enter your MySQL database settings.
define("DB_HOST","server");
define("DB_USER","root");
define("DB_PASS","");
define("DB_NAME","msn");
// Enter your jabber server and port; if you don't have one,
// visit http://www.jabber.org/user/publicservers.php for a
// list of public servers.
define("JABBER_SERVER","jabber.freenet.de");
define("JABBER_PORT","5222");
// Enter the domain names for each of your transports; this
// is used to determine which IM network a contact is using.
// (eg: if you enter "msn.yourdomain.com" for your MSN
// transport, and a contact's Jabber ID is "john%hotmail.com@msn.yourdomain.com",
// WebMessenger will know that this is an MSN user)
define("TRANSPORT_MSN","msn.freenet.de");
define("TRANSPORT_ICQ","icq.freenet.de");
define("TRANSPORT_AIM","aim.freenet.de");
define("TRANSPORT_YIM","yim.freenet.de");
// Enter the commands used to determine whether or not your
// Jabber server and individual transports are running.
// It doesn't matter what commands you use, nor how they
// determine your Jabber server/transport status, but
// they MUST return one or more characters when running,
// and 0 characters when offline.  If WebMessenger is on
// the same machine as your Jabber server, it's usually
// sufficient to just check the process list, as shown
// below.
define("JABBER_RUNNING","ps ax | grep jabberd");
define("MSN_RUNNING","ps ax | grep msntrans");
define("ICQ_RUNNING","ps ax | grep icqv7ext");
define("YIM_RUNNING","");
define("AIM_RUNNING","");
// Enter the Jabber resource used by WebMessenger.  This
// can be basically anything.
define("JABBER_RESOURCE","WebMsgr");
// Enter the default font face(s)/size used by WebMessenger.
$font_family = "Tahoma,Verdana,Arial,Helvetica,sans-serif";
$font_size = 8;
// Enter the theme you're using for WebMessenger.  Probably
// just "default" for now, as theme support is not yet complete.
$theme = "default";
// Debugging mode; should usually be set to 0
define("DEBUG_MODE",0);
[ Voor 13% gewijzigd door Verwijderd op 17-05-2003 02:55 ]
  • reskobon
  • Laatst online: 14-08 22:26
Je moet je vraag even wat duidelijker formuleren, ik heb nu geen idee wat er wel en niet lukt. Het is dus de bedoeling dat je connect naar de Jabber server en vanaf daar connect naar de msn server?
Leeg
  • whoami
  • Laatst online: 10:17
GoT en P&W zijn geen forums waar er support kan geleverd worden voor software / scripts die door anderen gemaakt zijn.
Ik denk dat je het best eens contact opneemt met diegene die dat script geschreven heeft.
Je kunt ook de support forums van webmessenger gebruiken:
http://webmessenger.sourceforge.net/
Succes. ;)
[ Voor 19% gewijzigd door whoami op 17-05-2003 10:05 ]
https://fgheysels.github.io/
