[Server 2003] SQL Server 2000 installatie hangt
  • AdLentis
  • Laatst online: 27-10-2025
AdLentis
Gadget Inspector
Ik heb hier sinds gisteren Windows Server 2003 draaien. Daar moet ook SQL Server 2000 opkomen. Nou wordt SQL Server 2000 SP2 of eerder niet ondersteund in Windows Server 2003, maar SP3 wel. Voordat je SP3 kan installeren, moet eerst SQL Server geïnstalleerd worden, maar dat wil niet lukken. Na het kopieren van de bestanden wil setup de server starten en de opgegeven configuratie instellen. Verder dan dat komt hij niet, want de service wil niet starten. In de error.log file (datadir\mssql\log) staat het volgende:
2003-05-16 15:34:41.11 server    Microsoft SQL Server  2000 - 8.00.194 (Intel X86)
    Aug  6 2000 00:57:48
    Copyright (c) 1988-2000 Microsoft Corporation
    Personal Edition on Windows NT 5.2 (Build 3790: )
2003-05-16 15:34:41.12 server    Copyright (C) 1988-2000 Microsoft Corporation.
2003-05-16 15:34:41.12 server    All rights reserved.
2003-05-16 15:34:41.12 server    Server Process ID is 2560.
2003-05-16 15:34:41.12 server    Logging SQL Server messages in file 'd:\mssql2k\MSSQL\log\ERRORLOG'.
2003-05-16 15:34:41.16 server    SQL Server is starting at priority class 'normal'(1 CPU detected).
2003-05-16 15:34:41.27 server    SQL Server configured for thread mode processing.
2003-05-16 15:34:41.31 server    Using dynamic lock allocation. [500] Lock Blocks, [1000] Lock Owner Blocks.
2003-05-16 15:34:41.41 spid3     Warning ******************
2003-05-16 15:34:41.41 spid3     SQL Server started in single user mode. Updates allowed to system catalogs.
2003-05-16 15:34:41.44 spid3     Starting up database 'master'.
2003-05-16 15:34:42.79 spid3     Server name is 'RAVELIN2003'.
2003-05-16 15:34:42.79 spid3     Skipping startup of clean database id 4
2003-05-16 15:34:42.79 spid3     Skipping startup of clean database id 5
2003-05-16 15:34:42.79 spid3     Skipping startup of clean database id 6
2003-05-16 15:34:42.81 server    Using 'SSNETLIB.DLL' version '8.0.194'.
2003-05-16 15:34:42.81 spid5     Starting up database 'model'.
2003-05-16 15:34:43.45 spid5     Clearing tempdb database.
2003-05-16 15:34:43.86 spid5     Encountered an unexpected error while checking the sector size for file 'd:\mssql2k\MSSQL\data\tempdb.mdf'. Check the SQL Server error log for more information.
2003-05-16 15:34:43.90 server    SQL server listening on Shared Memory, Named Pipes.
2003-05-16 15:34:43.90 server    SQL Server is ready for client connections
2003-05-16 15:34:44.03 spid5     Error: 823, Severity: 24, State: 6
2003-05-16 15:34:44.03 spid5     I/O error 38(error not found) detected during read at offset 0000000000000000 in file 'd:\mssql2k\MSSQL\data\tempdb.mdf'..
2003-05-16 15:34:44.05 spid5     WARNING: problem activating all tempdb files.  See previous errors.  Restart server with -f to correct the situation.
Ik heb al verschillende dingen geprobeerd. Zoeken met google leverde de volgende url op:
http://dbforums.com/t713100.html
Ik heb reeds een schijfcontrole uitgevoerd op de D: partitie, waar de betreffende file op staat. Die gaf geen foutmeldingen. En bij elke installatiepoging krijg ik dezelfde melding, ook als ik andere directory's opgeef. Verder heb ik reeds 2 verschillende CD's geprobeerd.
Iemand een idee voor een oplossing?
Sorry voor de layout... ;)
[ Voor 3% gewijzigd door AdLentis op 16-05-2003 16:08 ]
Ik ben tenminste niet altijd hypocriet!
  • The Lord
  • Laatst online: 21:52
Wat dan?
Het lijkt erop dat die tempdb corrupt is?
geeft geen inhoudelijke reacties meer
  • AdLentis
AdLentis
Gadget Inspector
The Lord schreef op 16 May 2003 @ 16:17:
Wat dan?
Om te beginnen heb ik de server al verschillende malen proberen te installeren, (en de oude dirs telkens weer verwijderd). Hij probeert die tempdb aan te maken als hij niet bestaat. De file is echter 0kB groot na het afbreken van de hangende install. (De nodige processen zijn ook beëindigd.)
Allerlei instellingen geprobeerd tijdens setup. Ik ga nu nog proberen om de DATA-dir op de default instelling te laten staan, kijken hoe het dan gaat.
Update:
Nou, het probleem is opgelost: ik heb de datadirectory op de default locatie laten staan (C: schijf), en nu gaat de installatie wel goed. Nu moet ik alleen nog uitzoeken hoe je achteraf de databasedirectory kan gebruiken.
[ Voor 22% gewijzigd door AdLentis op 16-05-2003 16:43 ]
Heb je dit al geprobeerd:
  • AdLentis
AdLentis
Gadget Inspector
Verwijderd schreef op 16 May 2003 @ 16:41:
Dat had ik natuurlijk ook al geprobeerd ja. ;)
AdLentis schreef op 16 May 2003 @ 16:43:
Daar hoopte ik al op :+
Helaas kan je verder niet helpen. Ik heb inmiddels 4 maal SQL Server op een Windows 2003 server geinstalleerd. Dit heb ik nooit gehad. Is de installer van SQL Server nog wel goed? Heb je genoeg rechten op het FS?
Verwijderd schreef op 16 mei 2003 @ 18:51:
Ik heb ditzelfde probleem.
En ik vraag me dan af of ik echt MS SQL 2000 met een oudere versie van SP2 op Windows 2003 kan zetten zonder dat hij gaat flippen.
Ik weet het, ik update 'm direct daarna naar SP3a, maar dan nog vertrouw ik 't niet echt.
Kan dit echt geen problemen opleveren?
  • AdLentis
AdLentis
Gadget Inspector
Verwijderd schreef op 16 May 2003 @ 18:51:
Voor de mensen die dit probleem nog tegenkomen, volgt hier de oorzaak, waar we achteraf achterkwamen:
Voorheen stond er op deze machine Windows NT4 Server. De Administrator van die installatie was eigenaar van de D: en E: partities. Met de 'verse' installatie van Windows Server 2003 is het hele domein opnieuw aangemaakt. De originele eigenaar bestond dus niet eens meer. Vanuit de Administrator account kon de eigenaar opnieuw ingesteld worden, wat het probleem verhielp.
  • RobbyNitroz
  • Registratie: Augustus 1999
  • Laatst online: 04-09-2021
ik heb precies hetzelfde probleem, bij mij gaat het echter om een reinstall van SQL2000 op dezelfde windows 2003 installatie. Ik kan me geen veranderingen in het usermanagement herrineren!
Kan ik in registry de passwords van vorige SQL 2000 installatie weghalen??
altijd de laatste AMD-cpu op het laatste mobo met zoveel geheugen als erin past :-)
